SOLD - 2018 TRD DCSB FULLY BUILT OVERLAND RIG
Discussion in '3rd Gen Tacomas For Sale (2016-2023)' started by Overland&UpMoutains, Aug 25, 2022.
Thread Status:
Not open for further replies.
  1. Aug 25, 2022 at 7:40 PM
    Overland&UpMoutains
    Overland&UpMoutains [OP] Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    2018 TRD Pro MT Calvary Blue w/ 46k miles
    WILL DELIVER ANYWHERE IN USA
    *tons of pictures keep scrolling*
    *270 awning recently built so it’s only in some of the picture but will be included*
    This is a turn key overland rig. If you bought it todays all you’d have to do is put your clothes in it and you could roam. I’m even including most of my recovery gear so it’s truly ready to go. This rig can off-road hard but just as easily be a home. I’ve taken it on multiple 30-45 day trips all out of the rig and loved it. Selling because I have a remote job and moving to full time travel life and want a van. This thing has been my baby, I for sure use it but it’s also been cared for. All the regular maintenance, fluid film treatment every winter, etc. Most of the work done by me but will stop at a shop if I’m on the road when I hit an interval.
    Armor:
    • Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after)
    • Victory 4x4 Strike Steel Rock Sliders
    • Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver
    • RCI Full Aluminum Skid’s
    • 34” BFG KO2 (Full size spare on swing out)
    • 17” KMC Impact (black)
    • Fox 2.5” Front Coilovers w/ DSC Adjuster
      • Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs
    • Total Chaos Upper Control Arm
    • Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster
    • ICON RXT Leaf Spring (Option 3/Heavy Setting)
    • Wheeler Superbump Front + Rear Bumpstops
    • ICON U-Bolt Flip Kit
    • Body Mount Relocation
    • ECGS 8” Clamshell Bushing (Eliminates Needle Bearing)
    • Nitro 4.88 Regear installed by ECGS
    • Dobson 4x4 Snorkel
    • Differential Breather
    • 10k lb winch (Smittybuilt)
    • Extended rear brake lines
    • Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out)
    • Air Compressor and Air Hoses
    • 4 ton jack stand included
    • Tree saver winch strap
    • D-Ring Shackle x 2 included
    • Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End
    • Custom Rear Seat Delete Platform
    • Dashtop Multi-Mount (DMM),
      • Will include 3 RAM mounts, one radio mount and two phone mounts
    • iPad Mount, attached to passenger seat bracket, used for navigation
    • Headrest Velcro Pouch Kit (Blue Ridge Overland)
    • Overhead Storage Attic (Blue Ridge Overland)
    • Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat)
    • Fire Extinguisher Mount
    • Prinsu Cab Rack
    • Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack)
    • Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases)
    • Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear.
    Overland/Camping:
    • Camper Custom (see details below)
      • Bed light
      • Bed lighting
      • Domestic Fan
      • Swing Up Rear/Side Panels with Locks
      • Roof Rack
      • 200 watt solar panel
      • LED Third Brake Light
      • Rear View Camera (connects to video rear view mirror in cab)
      • Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!)
    • Bed Buildout/Living System
      • Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating)
      • Trunk Cabinet
      • Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers)
      • Elevate Fridge Cabinet w/ under storage for stove/cooking gear
      • Custom 8020 build - strong enough to sit/stand on
    • Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed
    • 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd)
    • Drop down table (attached to swing out)
    • Rear Seat Delete (custom)
    Lighting:
    • Rigid Adapt 30” Light Bar
    • Rigid Ditch Lights
    • Quad LED Headlights
    • Meso Dual Red/White Interior Lights (Map + Dome)
    • Camper interior lighting
    Electric
    • Dual Battery System
      • RedArc BCDC 25a Controller
      • 90 Ah AGM Secondary/House Battery
      • 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed)
      • Extra fuses included
    Comms:
    • Midland Micromobile GMRS
    • WeBoost w/ extended antenna on a RAM pivoting mount
    Other
    • Fumoto Oil Change Valve
    • Bike Rack (Tire Mounted)
    98DA0AC3-AC5F-4A61-803D-C0F7CA61CB2D.jpgE64911FD-4CC3-42E2-AB17-438E38207440.jpg B72CEA95-D1FD-47E8-8870-176374B80D0D.jpg E42C89B3-F632-4E5E-887B-AA74AE0C9934.jpg F06E86EF-FB7B-405E-9C7F-C7F630A5E73B.jpg
    Here is the 270 awning. Recently built based on the OverlandUnderbudget design.
  2. Aug 28, 2022 at 1:49 PM
    flatironsoverland
    flatironsoverland @FlatironsOverland
    Erie, Colorado
  3. Oct 2, 2022 at 3:00 PM
    Overland&UpMoutains
    Parker
    Deleware
  4. Feb 27, 2023 at 1:24 PM
    Overland&UpMoutains
    Parker
    Deleware
    Camper
    Camper Set Up
    (Message me for the video)
    Less than 1 min set up, super easy! I didn’t put the tent poles in the side flaps but you can and you’ll see them propped open in the next picture.
    Camper w/ Front Window Closed
    The main front window has three layers: Solid outer canvas (that connects on the exterior to prevent rain getting in), roll away mesh layer, second inner solid canvas layer.
    Camper w/ Front Window Open
    The main tent window is rolled away. It rolls up and has ties that keep it held up. You might notice that you can’t see the fridge in the bed (usually on the right side). I took it out so I had more bed access to haul some stuff recently. All of the cabinets are bolted to the base board (3/4 birch w/ rubberized coating) so it’s very easy to take them out if you need the bed.
    Camper Sleeping Platform
    (photo taken standing on tailgate)
    The sleeping platform is three parts. One large platform (the foam mattress is sitting on). It swings up on a gas strut. In the front are two smaller blacks which just rest on supports (you can see one in the photo the other is under the mattress so it’s out of the way). When I want to just hang in the camper I take the two small blocks and put it on/under the mattress and move the whole thing out of the way (see photo below). Also note the open windows, plenty of air of there. The side walls a solid flap which is unzipped in this photo, and then a layer of bud mesh. The solid window flaps are just tucked next to the mattress but there is also some clips so if you want it nice and tidy you can roll it and clips it away.
    Storing the Small Sleeping Blocks
    Sleeping Platform w/ Small Blocks Removed
    Sometimes I use this set up. It can be nice to just have the blocks out of the way all the time. The sleeping platform is long enough to use this way but your toes might be tight. With the blocks in there is plenty of room to stretch out.
    Full Sleeping Platform
    airmax233 likes this.
  5. Feb 27, 2023 at 1:28 PM
    Overland&UpMoutains
    Parker
    Deleware
    Sleeping Platform
    Viewed From Below
    Cool features unrelated to the sleeping system. I’ve added bungees to the inside of the doors and bottom of the platform. Great place to throw clothes, shoes etc. Seems like those loose items always messy up a van/camper so it’s nice to have them up off the ground. You can see my shoes on the left side. Under the sleeping platform I have a big gym/yoga mat. Great for camp to stretch after a hike, spot for dog or kids to sit that’s not the dirt, etc. I’ve also kept thin camp chairs, up there without any effect on raising the sleeping platform.
    Standing in the Camper
    w/ Sleeping Platform Raised
    As you can see plenty of space. Another person (or two can fit) comfortably. You can sit on the bunk cabinet in the back no problem. The lids on that bunk lift off (no hinge). I have eye bolts attached the the bunk cabinet so you can strap down bags to it as well.
    Standing in Camper
    w/ Platform Down
    This is me standing in the camper with the platform down. The smaller blocks have been removed so this is how you get in the bed. I usually just step up on the side of the bed and jump in.
    Camper with Side Walls Closed
    This shows the camper all zipped up. Also note how the pillows are arranged. You can fit four pillows and sleeping bags in with the roof closed. You just need move the pillows to the center and the sleeping bags to the foot of the bed so the camper canvas has space to fold in. I’ve never had an issue with water. The canvas is super solid so even if the canvas is wet on the outside when you close up the tent your bedding won’t get wet . I advise always closing the inner flaps before packing up, it helps to protect the big mesh from tearing on something.
  6. Feb 27, 2023 at 1:52 PM
    Overland&UpMoutains
    Parker
    Deleware
    Rear Seat Delete
    Here you can see the rear seat delete. Overhead is a blue Ridge Overland attic. I have two jackets stuffed in there but it can fit more. I have anchors and bungees set up to hold stuff against the wall. At the moment there are some blackout window shades (made of reflectix) and a camp chair. The 10 gal water tank is in the foot well . There is access to the two under platform storage compartments as well. On the backs of the seats are Blue Ridge Overland Velcro pouches and a mini trash container.
    Storage Compartment Driver Side
    I keep a large tool roll and other random stuff in here. Empty to show the space.
    Storage Compartment Passenger Side
    This is where the water filter for the tank is housed. There is enough space in to keep a few other item. I keep some D-Ring shackles and other small items here.
    Blue Ridge Overland Headrest Velcro Pouch and custom Fire Extinguisher Mount
    Electrical Outlet/Control Panel
    This panel is on the driver side of the rear seat delete. It has two outlets, a battery monitor, and a kill switch. To the left you can see a button to turn on the water. There is a second control for water in the bed as well with plumbing and outlets in both locations.
    Ram Mount on Drivers Side Vent
    Ram Mount x 4 over center media console
    This has five mounts. There is a USB behind the dash wired to the house battery (always on) with two charging cables that peak out near the ram mounts for easy charging. The radio is GMRS. It’s wired to the house battery. The box is under the passenger seat but everything can be controlled from the handheld unit on the dash.
  7. Feb 27, 2023 at 1:58 PM
    Overland&UpMoutains
    Parker
    Deleware
    Exhaust Reroute (skids removed obviously)
  8. Feb 27, 2023 at 2:00 PM
    Overland&UpMoutains
    Parker
    Deleware
    Engine Bay with Painted Engine cover and house battery wiring shown. The house battery is controlled by a RedArc BCDC which is housed inside the passenger glove compartment box. Wire go through the firewall so it’s a very short run.
  9. Feb 27, 2023 at 2:05 PM
    Overland&UpMoutains
    Parker
    Deleware
    Fox Front Coils and Total Chaos UCA
  10. Feb 27, 2023 at 2:09 PM
    Overland&UpMoutains
    Parker
    Deleware
    Skid Plates Action shot
  11. Mar 1, 2023 at 6:19 AM
    Overland&UpMoutains
    Parker
    Deleware
    Alright let’s bump this :) went off the market for a while but now I’m getting the van itch again, see if anyone wants it
  12. Mar 9, 2023 at 4:26 AM
    Overland&UpMoutains
    Parker
    Deleware
  13. Mar 25, 2023 at 10:47 PM
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
  14. Apr 4, 2023 at 3:25 AM
    Overland&UpMoutains
    Parker
    Deleware
    270 awning finished up, this will be included in the sale
    Xtremsiege2 likes this.
  15. Apr 25, 2023 at 2:58 PM
    Overland&UpMoutains
    Parker
    Deleware
  16. May 3, 2023 at 7:05 AM
    Overland&UpMoutains
    Parker
    Deleware
  17. May 15, 2023 at 12:36 PM
    Overland&UpMoutains
    Parker
    Deleware
  18. May 17, 2023 at 12:07 PM
    Doc's Rig
    Doc's Rig Your opinion is not statistically significant
    Doc
    The Natural State
    2016 4x4
    OP, did I miss the price? Thx.
  19. May 20, 2023 at 3:57 AM
    Overland&UpMoutains
    Parker
    Deleware
    no you didn’t miss it, firm at $50k.
    I took the price down cus I have a really busy June so wasn’t going to pay attention here for a bit. But if you’re interested and serious I’m sure I can find the time. Feel free to text me 215-738-4069 and sorry for the delayed response had a pretty busy last couple weeks
  20. Jul 2, 2023 at 7:35 AM
    Overland&UpMoutains
    Parker
    Deleware
    SOLD FOR $50k in mid 2023, posting price for reference for other sellers/buyers
Thread Status:
