SOLD: 8.4” 3rd Member - 5.29 Ratio & Eaton Detroit TrueTrac
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by BLtheP, Jan 28, 2024.
Thread Status:
Not open for further replies.
  1. Nov 18, 2024 at 12:22 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Would gladly take this if it was an 8" with e locker. Free bump for you sir!
  2. Nov 18, 2024 at 12:31 PM
    BLtheP
    BLtheP [OP] Constantly Tinkering Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It’s using a solid spacer, so I can just swap the yoke pretty easily with a new nut. I just didn’t want to buy a flange.
  3. Dec 2, 2024 at 9:15 PM
    BLtheP
    Plano, TX
    Sure you wouldn’t prefer 60% lower gear with 5.29s? :cool:;)
  4. Dec 2, 2024 at 10:42 PM
    BLtheP
    Plano, TX
    That’s…not how that works.
    Oreo Cat likes this.
  5. Dec 29, 2024 at 2:14 PM
    BLtheP
    Plano, TX
    Bump and price drop. Someone buy this!
    daveeasa likes this.
  6. Dec 29, 2024 at 2:18 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    What size tire would I need to get the same ratio as 4.56 on my stock tires? 6" lift? :p
  7. Jan 9, 2025 at 8:22 PM
    Pigpen
    Dan
    Northwest Montana
    Hows the 4.56 on stock tires? I'm on 33s (33.5") with stock gears. Regear and lockers are in my near future. Was planning on 4.30 or 4.10 with 33s and a set of 35s for wheeling trips. 4.0 MT
    Also, free bump for seller! I'd love to have the balls, or at least the tires, to need these gears!
  8. Jan 20, 2025 at 7:19 PM
    BLtheP
    Plano, TX
    Man, this project is by far the biggest regret I have over the ownership of this truck. What a giant waste of time and money.
  9. Mar 4, 2025 at 9:52 PM
    BLtheP
    Plano, TX
    Sold.
    jjgandarillas and daveeasa like this.
Thread Status:
