SOLD ADS Coilovers/Rear shocks w/remote resi and adjustersSOLD
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by jgang, Aug 20, 2020.
  1. Aug 20, 2020 at 1:35 PM
    jgang
    jgang [OP] Well-Known Member
    ***Can deliver anywhere between Cincinnati/Indy/Quad Cities/Des Moines/Omaha/Cheyenne just after Labor Day weekend.***
    These came straight from Headstrong and I've had them on my 2013 DCLB for less than 7000 miles. Includes everything seen plus two 5/16" pin punches for adjusting the spring collar and a full compliment of ADS stickers. Also includes the neoprene Toytec Shock Covers that have been on the coilovers since mile one (AWESOME covers....really kept things clean!). Only thing you'll need is 4 screws to mount the rear reservoir and I'd recommend 4 new clamps for the reservoirs just to be safe. There's one stud on each tophat that came loose from the tophat when I removed them. All you need is to locktite it back in when you do the installation. I never did any offroading with these at all. There's some obvious corrosion of some of the fittings and other exposed parts from the salty Ohio winter, but it's light and only cosmetic. Might be a small nick or two from the install/removal process, but tip top otherwise. Everything functions as it should. This setup was just way overkill for my purposes as my move from Colorado to Ohio has made my truck a flatland grocery getter and furniture hauler.
    Headstrong SKUs:
    Fronts: HS-TT055-25CCA-600
    Rears: HS-TT055-R25RRCCA
    Asking $2200.
    We can talk shipping costs if you're interested. Priority goes to someone wanting the full set. If you want just the fronts or just the rears, you'll need to wait until the other half is also spoken for. That means someone could come along and buy the full set before someone else buys the other half.
    Located in SW Ohio and am not above a short road trip to meet if it works for both of us.
  2. Aug 21, 2020 at 10:02 AM
    brwntms
    brwntms Well-Known Member
    Hey would you happen to have the sku number for reference?
    thanks.
  3. Aug 23, 2020 at 5:09 AM
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    They are in the description
    TOP TACO likes this.
  4. Aug 24, 2020 at 4:55 AM
    jgang
    Price drop to $2200.
  5. Aug 24, 2020 at 12:27 PM
    ekliptiko
    ekliptiko Well-Known Member
    Portland, OR
    I assume these are not extended since I see you have them mounted with the stock UCA...
    I am not familiar with ADS - can these be rebuilt in an extended configuration?
  6. Aug 24, 2020 at 1:55 PM
    jgang
    They are not extended. From what I understand though, they can be made to be extended travel shocks by simply removing an internal bushing. At least that's what I heard. You would have to verify with ADS. Depending on who you ask, ADS shocks are at least as good, if not better, than Kings.
  7. Aug 25, 2020 at 5:36 AM
    jgang
    Come on guys....this package is $3500 Headstrong these days. I thought $2200 was a pretty fair steal. Somebody needs these!
  8. Aug 28, 2020 at 5:56 PM
    jgang
    I'm traveling from Cincinnati/Indy/Quad Cities/Des Moines/Omaha/Cheyenne just after Labor Day weekend if that helps anyone out.
  9. Aug 29, 2020 at 12:19 PM
    jgang
  10. Aug 30, 2020 at 4:14 AM
    Piffcentral
    Piffcentral Well-Known Member
    Garner, NC
    2014 TRD Sport DCLB
    Hey, which coils are those? 650#? I might be interested. I'm in Richmond, VA though. Would you be open to shipping?
    Dirk Diggler likes this.
  11. Aug 30, 2020 at 5:08 AM
    jgang
    600lb coils and i would consider shipping for sure. Send me a pm.
  12. Oct 1, 2020 at 12:50 AM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Still available?
  13. Oct 1, 2020 at 4:36 AM
    jgang
    Sorry, sold. Headline updated.
