-SOLD Bilstein 5160 Rear Shocks
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by NCtaco914, Dec 16, 2019.
Thread Status:
Not open for further replies.
  1. Dec 16, 2019 at 6:32 PM
    NCtaco914
    NCtaco914 [OP] MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    SOLD
    Bilstein 5160(25-242539) includes brake line extension kit. Asking $200 plus shipping (ups ground)
    Setup removed from 2017 Tacoma. Roughly 10k miles, installed new. No leaks, damage, etc. Very clean setup. Located in kannapolis, nc area. Will entertain shipping offers, but local buyers will have first priority
    MAG GRY TACO15 likes this.
  2. Dec 16, 2019 at 6:55 PM
    justinh
    justinh Well-Known Member
    Canton, GA
    2009 Tacoma TRD Offroad 4x4
    Can you get a shipping quote to 30115?
  3. Dec 16, 2019 at 7:11 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    Shipping to 08302 please
  4. Dec 16, 2019 at 7:21 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    About $20 ups ground to either zip codes
  5. Dec 17, 2019 at 6:16 AM
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    Good price.
  6. Dec 17, 2019 at 7:10 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Anywhere in the southeast these can be shipped at $20. Prices increase tremendously to west coast
  7. Dec 17, 2019 at 2:59 PM
    Hiyudurin
    Hiyudurin Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    Bilstein’s website shows different part numbers for driver and passenger side. Are these both the same part numbers or no? The website also shows the driver side reservoir mounts toward the rear of the truck and passenger side reservoir mounts toward the front of the truck, is that correct? Sorry for the confusion but I’m interested in these.
  8. Dec 17, 2019 at 4:05 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Yes, you are correct are the reservoir mounting orientation. Also the drivers side included the brake line extension kit. I'm including everything just as you bought them per part # for each side
  9. Dec 18, 2019 at 7:14 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
  10. Dec 19, 2019 at 4:34 AM
    halfnattyvictor
    halfnattyvictor Active Member
    Was the brake line extension kit required? I'm about to install 6112/5160s with SPC UCAs and wondering what little shit i need or I'm going to run into.
  11. Dec 19, 2019 at 4:43 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    The brake line extension kit is needed on the drivers side due to the length if the stock "flexable" rubber brake lines being too short. If you ordered the 5160's, it should come with the "brake line spacer block" to take some pressure off of the stock brake lines. A lot of us that have the 5160 setup, just installed +2 or +4 aftermarket extended brake lines and replaced the factory ones. It is a great investment if you are going to lift the rear of your truck and go wheeling. Plus a $65 investment into extended aftermarket brake lines to make sure that you brake lines dont break and you can't stop is a small price to pay.
  12. Dec 19, 2019 at 4:52 AM
    halfnattyvictor
    Gotcha. So it would require bleeding the brakes then, and removing stock lines, etc. Wonder if I should let the shop do it now... lol I got quoted $1000 to have my 6112/5160 and ucas, add a leaf installed and aligned. Seems ridiculously high.
  13. Dec 19, 2019 at 4:57 AM
    crashngiggles
    Jared
    That quote is high yes. The block that comes with the 5160's would not require bleeding the brakes but adding new extended brake lines would yes. You may be able to hook up with a couple of other TW members in your area to see where they got their lift installed. If you are mechanically inclined you can do it but you should be able to get it done cheap than that. Search out the regional forums for your area and put out a feeler of places that others have used to get their lifts done or if others can help you with it. An alignment will need to be done either way though.
Thread Status:
