SOLD - Bussmann RTMR 15303-2-2-4, pre-wired and loaded with relays and fuses
Discussion in 'Buy / Sell / Trade - Canada' started by elclem21, Jun 3, 2018.
Thread Status:
Not open for further replies.
  1. Jun 3, 2018 at 5:52 PM
    elclem21
    elclem21 [OP] Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    SOLD !!!!!!
    Selling one Bussmann 15303-2-2-4, build based on tacozord's thread. The lead for the switches is 6 ft long.
    Relay #2 is restricted to 20 amps, as the tab to hold the connector is broken in B-3, but will not affect the overall functionality. I was able to source a relay who uses rows D and E as a way around the issue and will work just like the other relays.
    Asking $100, includes shipping to Canada, pre-wired as pictured, including the relays and fuses. For shipping to USA, PM me and I will figure out the cost
  2. Jun 4, 2018 at 3:54 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    FYI .... Used auto part/Made in USA = no customs fees
    Train and tacoma16 like this.
  3. Jun 4, 2018 at 11:33 AM
    elclem21
    Clément
    Alberta, Canada
    Good to know, I wasn't aware. I guess it opens the door to more members.
    Thanks.
    taczilla[QUOTED] likes this.
  4. Jun 18, 2018 at 8:06 AM
    elclem21
    Clément
    Alberta, Canada
    Still available, bump !
  5. Jul 10, 2018 at 8:09 AM
    EatsInPDX
    EatsInPDX Well-Known Member
    Sweet set up!
  6. Jul 20, 2018 at 4:55 PM
    elclem21
    Clément
    Alberta, Canada
    Still for sale !!!
  7. Aug 24, 2018 at 8:58 AM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
  8. Aug 24, 2018 at 10:28 AM
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    I just hooked up a bluesea block last night just need to organize the wiring for my lights.
    foxrcing07[QUOTED] likes this.
  9. Nov 17, 2018 at 12:29 PM
    elclem21
    Clément
    Alberta, Canada
    Bump and price drop, $100.
  10. Jan 3, 2019 at 10:40 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    @Canoehead
    a lot easier then making your own....:poking:
  11. Jan 8, 2019 at 7:50 PM
    Iamstutter
    Iamstutter Member
    2011 Trd sport tacoma
    Still avalible? Also in Alberta. Do you have the platform as well?
  12. Jan 9, 2019 at 11:35 AM
    elclem21
    Clément
    Alberta, Canada
    Yes it is still available. If you also need connectors and pigtails for your accessories I can make them as well.
    By platform, I assume you mean mounting bracket? In this case no it does not come with one. There is some vendors here selling them, perhaps you can find what suits you best. I got mine from TacomaPros, compact but also have a spot for a circuit breaker.
  13. Jun 1, 2020 at 10:01 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I don't suppose this is still available?
  14. Jun 2, 2020 at 7:04 AM
    elclem21
    Clément
    Alberta, Canada
    It is still available. To be honest I had forgot about this post for quite a while!
    If you are interested, I have some supplies on hand. I could provide some connectors with pigtails for an extra $$$. It could also be customized a bit, depending on what you need. The 5x fused leads are 14ga wires, they could be upgraded to 12ga. the other 5 going through the relays are all 12ga already.
    Let me know !!!
  15. Jun 2, 2020 at 8:17 AM
    TodayWasTHeDaY
    Russ
    Calgary
    I'll take it off your hands then! Where are you located? I have to check the ratings of what I need to run but would be interested in a couple of pigtails
  16. Jun 2, 2020 at 11:18 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Looking at things I'll need to use three relays, two under 20A and one over 20A preferably so pigtails made up for those would be awesome. Let me know what it'll cost.
  17. Jun 2, 2020 at 11:25 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Just to clarify, a pigtail would be the output plug and wiring coming from the box or is that already existing?
  18. Jun 2, 2020 at 11:50 AM
    elclem21
    Clément
    Alberta, Canada
    By pigtail, I mean the following: The wire comes out of the box, goes through a plug (both male and female), then another length of wire to splice into your needed accessory. Basically, You get a quick disconnect at the RTMR if needed.
    If you wish something different, we can discuss about what exactly you need and I can see how I can make that for you, as long as I have the supplies.
    Send me a PM if you wish to discuss further more. I am located north of Edmonton (St. Albert).
    P.S. All relays included are good for up to 35 amps, but the standard for a 280 series connector (which is what this unit uses) is rated at 30 amps. Only 1 relay is different due to a small issue, as I have mentioned in my original post. That one is 20 Amps max due to the reduced size.
  19. Jun 6, 2020 at 12:59 PM
    OverlandTRD
    OverlandTRD Active Member
    Sold or still up for grabs? been on the fence with these...
    TIA
  20. Jun 6, 2020 at 1:19 PM
    elclem21
    Clément
    Alberta, Canada
    Literally just sold this week, In fact I just shipped it away.
    Sorry.
Thread Status:
