(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Aug 31, 2016 at 12:15 PM
    #2061
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I'm thinking plate alumium, full hoops, 8k warn winch
  2. Aug 31, 2016 at 3:11 PM
    #2062
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Exactly what I have, M8000S (synthetic line)
    AR15xAR10[QUOTED] likes this.
  3. Aug 31, 2016 at 3:17 PM
    #2063
    AR15xAR10
    Some people say the synthetic isn't worth it. Because it can freeze and be useless. Or when you break or frey it, you can't just chop it down and crimp a new end on it like you can the cabel. I have no experience with the synth line. Only with cable. I know i can fix cable
  4. Aug 31, 2016 at 3:27 PM
    #2064
    la0d0g
    running for the hills
    For crawling not hauling
    When it freezes, you piss on it. You can cut the shit parts off too just not as simple to do. Synthetic is worth it IMO since the possibility of decapitation is slightly reduced.
  5. Aug 31, 2016 at 3:30 PM
    #2065
    AR15xAR10
    But "can i still repair it?" is what i'm curious about
  6. Aug 31, 2016 at 3:31 PM
    #2066
    la0d0g
    Like if it frays?
  7. Aug 31, 2016 at 3:32 PM
    #2067
    AR15xAR10
    Yuh.
    Some times the crimps get messed up near the hook/pin on a cable line, would that same thing happen on the synth line? And could it be recrimped in the field?
  8. Aug 31, 2016 at 3:37 PM
    #2068
    la0d0g
    I've never experienced synthetic crimping like that. Worst case, in the field scenario, I would cut off the messed up part and tie a figure eight knot to hold my hardware until I could get home and properly fix it.
  9. Aug 31, 2016 at 3:40 PM
    #2069
    AR15xAR10
    Fair enough.
  10. Aug 31, 2016 at 4:29 PM
    #2070
    CanisLupus
    Stokesdale | NC
    I would never go with cable, mainly for safety's sake, and also for obvious weight savings.
    Cable will seriously kill you if it breaks whereas synthetic will be a little safer (obviously not great) especially if you put a heavy coat or blanket over the middle of the line.
    I used my synthetic line in freezing temperatures and 3' of snow this past winter and had no issues with the actual line. And the inside of my bumper and winch spool had been packed with snow from the 3' blizzard that came through.
    AR15xAR10 likes this.
  11. Aug 31, 2016 at 5:01 PM
    #2071
    AR15xAR10
    As infrequently as i'd likely be using it. Synth seems to be more worth it.
  12. Sep 1, 2016 at 1:14 PM
    #2072
    CanisLupus
    Stokesdale | NC
    Got the Panavise / RAM phone mount in today. But while doing so, I left my truck on "ON" power to charge my phone. Only took about 15 minutes to install the mount but I got out and noticed my headlights were flashing/flickering. Sure enough, battery was dead so I jumped it with my house's owner's car. Drove down the street to the Advance Vato and picked up a Autocraft 27F silver. Same CCA and RA as the 27F Duralast Gold I was looking at and didn't want to drive to the closest VatoZone so I just went with the Autocraft.
    Truck started up so my first battery install went well :laughing: I needed a new battery anyway and I'm glad I got this in before winter.
    New battery in at 42,766 for my reference.
  13. Sep 1, 2016 at 1:53 PM
    #2073
    CanisLupus
    Stokesdale | NC
    Also just ordered the Salex glovebox organizer. Tired of just throwing everything in the glovebox in a mess.
  14. Sep 3, 2016 at 11:36 AM
    #2074
    CanisLupus
    Stokesdale | NC
    Salex glove box organizer in.
    fatfurious2 likes this.
  15. Sep 4, 2016 at 11:32 AM
    #2075
    CanisLupus
    Stokesdale | NC
    Noticed these weird cracks all around the sidewall of my spare. Sun damage to just outer skin or something to worry about?
  16. Sep 4, 2016 at 4:32 PM
    #2076
    AR15xAR10
    Its sun dried.
    Happens to all tires. Do you rotate it in?
  17. Sep 4, 2016 at 4:59 PM
    #2077
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Dry rot, get some Aerospace 303 to protect it from the sun. Works well on other plastic and rubber items as well.
    TacoCat likes this.
  18. Sep 4, 2016 at 5:01 PM
    #2078
    CanisLupus
    Stokesdale | NC
    Haven't rotated it with this set, it was brand new when I got this last set which was used.
    Might rotate it in with this set now if it's safe to do so. Think they're still good to run?
  19. Sep 4, 2016 at 5:26 PM
    #2079
    AR15xAR10
    Again, all tires crack. I would either rotate it in, or get a set of 5
  20. Sep 4, 2016 at 9:06 PM
    #2080
    CanisLupus
    Stokesdale | NC
    I think I'll be rotating in the spare with this new set, but I'll try out the 303 before the next rotation.
