(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Jun 27, 2013 at 4:53 PM
    #221
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    Do like homer taco did. It is removable since it cannot be cut in PA so he can take it off on the trails.
  2. Jun 27, 2013 at 4:56 PM
    #222
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I just looked at his setup. Not sure if it's something I could do. I'm a little confused as to how his bracket keeps the two edges of the pipes connected well.
    I think I will be fine for now if I dump it, but I can always figure something out if a shop gives me crap for it.
  3. Jun 27, 2013 at 5:01 PM
    #223
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    I haven't done mine yet but as far as I can see you should have no problem
  4. Jun 27, 2013 at 5:07 PM
    #224
    CanisLupus
    Stokesdale | NC
    I'm planning on cutting mine Saturday at the firehouse. I will be keeping the cut portion (unsure if I will try and sell it) and the exhaust hanger just in case. You can check back here if you're interested. Should have pictures up Saturday evening or Sunday.
  5. Jun 27, 2013 at 7:37 PM
    #225
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    fwiw i didnt chop the hanger off...couldve but honestly didnt even cross my mind at the time. wont hurt anything either way.....well i guess it would if you ever wanted to put it back
  6. Jun 29, 2013 at 5:07 PM
    #226
    CanisLupus
    Stokesdale | NC
    DUMPED EXHAUST AFTER AXLE
    Chopped my exhaust after the axle today. Hit it with a couple shots of rust reformer spray paint to prevent any rust issues if you are wondering what the black color is. It definitely changed the sound of the TRD exhaust. It lost its "aftermarket" sound, if that makes sense. Sounds much more like a stock vehicle's exhaust now, but I really like the clean look of no exhaust tip hanging out. It was a necessity anyway for when I get a H/C rear.
  7. Jun 29, 2013 at 5:29 PM
    #227
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Made it sound more quiet? Hmm, thought it would do the opposite.
  8. Jun 29, 2013 at 5:36 PM
    #228
    CanisLupus
    Stokesdale | NC
    It seemed to have just changed the normal sound if that makes more sense. I wouldn't really say it's all that more quiet, but it sounds less like the normal TRD sound and more just like a stock V6 exhaust.
    I wouldn't mind letting you drive around in mine before you chopped yours if you wanted to make sure you liked it. Just let me know a time and I should be able to do it.
  9. Jul 9, 2013 at 2:47 PM
    #229
    CanisLupus
    Stokesdale | NC
    Might be getting Wheeler's SuperBumps for the front and rear, as well as a AP U-Bolt Flip Kit soon. Got some money for my birthday that's begging me to spend it.
  10. Jul 9, 2013 at 3:18 PM
    #230
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Like my front superbumps. Easy to install too.
  11. Jul 9, 2013 at 3:47 PM
    #231
    CanisLupus
    Stokesdale | NC
    I saw that on the Wheeler's page. Do the stock ones just screw off and the new screw on? That easy?
  12. Jul 9, 2013 at 4:03 PM
    #232
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    Yessir! Stock ones come off with vice grips and then you just throw the new ones on. You will need to cut an inch or two off of the allen wrench they send you.
  13. Jul 9, 2013 at 4:15 PM
    #233
    CanisLupus
    Stokesdale | NC
    :confused:
  14. Jul 9, 2013 at 4:18 PM
    #234
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    You will see when you go to install them. Its too long so you cant turn it cause the LCA is in the way.
  15. Jul 9, 2013 at 4:20 PM
    #235
    CanisLupus
    Stokesdale | NC
    I figured that's what you meant. Thanks.
  16. Jul 9, 2013 at 4:25 PM
    #236
    la0d0g
    running for the hills
    For crawling not hauling
    Yeah, I had to hack mine off too. I was like WTF, if you have your suspension torn apart it would work but not with it all buttoned up.
  17. Jul 9, 2013 at 4:30 PM
    #237
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    Yeah same I thought I was the retard but no the key just needs to be cut.
  18. Jul 9, 2013 at 5:31 PM
    #238
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Superbumps front and rear for me. Love them! I ordered two front kits and used one for the rear since I didnt need the extra height of the rear kit. I just bolted it to the frame mount and let it strike the AP flip plate. Depending on your leaf pack that may not work for you though.
    I had to use a big pipe wrench to get the front stockers off fyi.
  19. Jul 9, 2013 at 6:35 PM
    #239
    CanisLupus
    Stokesdale | NC
    I will be ordering the AP kit with the pre-tapped holes and then drill matching holes on the SuperBump rear brackets. The only worry I have is the U-Bolts being a little long for my leaf pack. I only have the stock 4 leaf plus the Toytec 1.5'' AAL. From AP's pictures, though, it looks like the U-Bolts have threads going down pretty far, so I hope that's not a problem.
    And then just put some ass into taking off the stock fronts. Should be easy enough.
  20. Jul 9, 2013 at 7:21 PM
    #240
    SconnieHailer
    Marc
    yea, ap's ubolts will be fine. I used them with the 3leaf pack and an aal so your's should fit.
