(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Jul 17, 2013 at 5:45 PM
    #261
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    That would be sweet. My brakes feel kind of lacking right now. Not like they won't stop when I really need to, but less than I would like.
  2. Jul 18, 2013 at 10:46 AM
    #262
    CanisLupus
    Stokesdale | NC
    REAR DIFFERENTIAL BREATHER MOD
    Got the rear differential breather relocated today. Put it in the driver side close-able bed compartment.
  3. Jul 18, 2013 at 10:56 AM
    #263
    la0d0g
    running for the hills
    For crawling not hauling
    :thumbsup: safe and sound
  4. Jul 18, 2013 at 11:45 AM
    #264
    CanisLupus
    Stokesdale | NC
    Yeah, I think it needed to be done. When I pulled the stock breather off, it had some nasty dirt and grime around the threads. I feel better going through a little water/mud now. Not sure if I'll ever get the snorkel like you, though. I don't think I have the balls to cut a 4'' hole in my fender...
  5. Jul 18, 2013 at 11:53 AM
    #265
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That's exactly what mine looks like :)
  6. Jul 18, 2013 at 2:05 PM
    #266
    CanisLupus
    Stokesdale | NC
    I did it correctly??? :eek:
  7. Jul 19, 2013 at 10:22 AM
    #267
    CanisLupus
    Stokesdale | NC
    Adding to the parts pile...Just waiting on the rear SuperBumps now. The fronts will have to wait until Wheeler's gets them back in stock, unfortunately.
    [​IMG]Matt
  8. Jul 19, 2013 at 10:24 AM
    #268
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    :woot:
  9. Jul 19, 2013 at 10:26 AM
    #269
    SconnieHailer
    Marc
    Just a heads up, those toplock nuts on the ap ubolts take some wrenching to torque down. May want to trim your ubolts before you try and thread on the nuts so you only have to turn those nuts as far as you need to.
  10. Jul 19, 2013 at 10:40 AM
    #270
    CanisLupus
    Stokesdale | NC
    :confused: Maybe I'm just a moron, but I don't really get what you're saying. I really don't want to trim the u-bolts now since I plan on getting Expo's in the future and I don't think they would be long enough.
  11. Jul 19, 2013 at 11:35 AM
    #271
    SconnieHailer
    Marc
    Just make sure the excess bolt doesnt hit your frame at bump out then. You might have to trim and grt new ubolts when u get expos...
  12. Jul 19, 2013 at 1:08 PM
    #272
    CanisLupus
    Stokesdale | NC
    The rear SuperBumps are pretty tall, so hopefully I won't have that issue. Won't the U-Bolts not stick out as far on the Expo's anyway since it's a taller leaf pack?
  13. Jul 19, 2013 at 1:33 PM
    #273
    SconnieHailer
    Marc
    Yea with the expo leaf pack you'll use all of the AP u bolt. But the stock pack with an aal is pretty thin and you'd likely run into problems with that much extra bolt sticking up (unless your bump is long enough to bump out before the bolts hit the frame). How long until you put the expos on? Sorry if i'm just ignorant and don't remember what you said about them. With the expo pack you will not need the extra clearance the rear super bump pedestal gives you (depending on shock), you can run just the super bump and it works out to about 16.25 shock mount to shock mount if i remember correctly.
  14. Jul 19, 2013 at 1:48 PM
    #274
    CanisLupus
    Stokesdale | NC
    I'm shooting to hold off on the planned big purchases for 2 years, but it will probably be more 1.5 years since I'm impatient. I might end up just getting another set of the front SuperBumps like you when I get the Expo's anyway.
    I think the rear SuperBumps are tall enough to stop compression before the bolts hit the frame, but we will see.
  15. Jul 22, 2013 at 12:49 PM
    #275
    CanisLupus
    Stokesdale | NC
    Rear SuperBumps are in, but I realized today that my flip kit did not come with the bolts for the pre-tapped plates for the bump stops. Called AP and they said they would send out some soon.
  16. Jul 24, 2013 at 1:50 PM
    #276
    CanisLupus
    Stokesdale | NC
    Bump stop hardware that AP forgot to send with original flip kit order came in today. Should have everything installed within a week or two with the help of a local member. (Skygear)
    [​IMG]Matt
  17. Jul 24, 2013 at 2:09 PM
    #277
    SconnieHailer
    Marc
    :woot: I'm loving my superbumps! No more slam under bottoming conditions lol.
  18. Jul 24, 2013 at 3:00 PM
    #278
    CanisLupus
    Stokesdale | NC
    Yeah, I'm excited to start slowly getting some more "real" modifications instead of the other aesthetic, etc type of mods.
    I did a quick check to see how far the bolts would stick up beyond the bump stop and it was making me a little nervous. They were looking pretty tall...I really don't want to cut them but it may be necessary.
  19. Jul 25, 2013 at 7:56 PM
    #279
    CanisLupus
    Stokesdale | NC
    Updated the OP with a Photoshop of what my future plans are with the truck!
    Picture includes IVD/AP lift, Baja Rack, Airflow snorkel, Pelfrey H/C rear with swingout/Rotopax, VR8000S winch, and stock wheel look. Some of these mods are still up in the air, and the picture obviously doesn't include skids and other mods like a bed mat.
    [​IMG]Matt
  20. Jul 25, 2013 at 9:13 PM
    #280
    SconnieHailer
    Marc
    I hear ya, I didnt like cutting mine either. I've got spare u-bolts up the waz now... I picked up some 5/8" u-bolts from ruffstuff instead of the ap bolts to try something different and get a beefier bolt, same price too. The 5/8" bolt is definitely beef ha and fits thru the AP plate with less wiggle room so the seem to tighten down better.
    Nice photoshop too by the way, looks pert sweet :D
