(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Apr 14, 2014 at 5:22 PM
    #681
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Anyone have insight into this?
  2. Apr 14, 2014 at 5:54 PM
    #682
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    shouldnt have any affect on ride height, maybe was the angle, like parking lot slopped maybe :notsure:
  3. Apr 14, 2014 at 5:59 PM
    #683
    CanisLupus
    Stokesdale | NC
    I measured on semi-flat road and it looked like it went down about 1/2''-3/4''. When I was in my garage yesterday (flat) I was sitting at about 23.5'' up front, and now I'm around 22.5-22.75''.
    I'm going to wait until next Monday, crank them back up to where I want them and then go into Firestone and get the lifetime alignment.
  4. Apr 14, 2014 at 6:22 PM
    #684
    superwhite10
    Garner, NC
    as long as your alignment is good i would be willing to chaulk it on just settling of the springs. truck is coming together nicely though man, needa come down to uwharrie and test it all out!
  5. Apr 14, 2014 at 7:17 PM
    #685
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Being careful with dem brakes?
  6. Apr 15, 2014 at 8:05 AM
    #686
    CanisLupus
    Stokesdale | NC
    Thanks! I need to find some time to come down and do some actual wheeling.
    Yep, only got about 10 miles so far but keeping pressure light. I think I'll do 200 mi with light pressure, then another 100 of medium, then do the ten 60-10 mph stops.
  7. Apr 15, 2014 at 8:50 AM
    #687
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Are they stiffer or still spongy like before?
  8. Apr 15, 2014 at 9:04 AM
    #688
    CanisLupus
    Stokesdale | NC
    I can't really tell so far because I have been barely touching the brakes. I'll have to wait until I start putting more pressure on in 150 miles or so.
  9. Apr 15, 2014 at 10:53 AM
    #689
    AR15xAR10
    Sounds gud
  10. Apr 15, 2014 at 1:29 PM
    #690
    CanisLupus
    Stokesdale | NC
    Are you still in the first stage of bedding?
  11. Apr 15, 2014 at 2:43 PM
    #691
    CanisLupus
    Stokesdale | NC
    :spy:
  12. Apr 15, 2014 at 3:00 PM
    #692
    AR15xAR10
    I'm at 148 miles
    Just starting the medium pressure
  13. Apr 16, 2014 at 4:40 AM
    #693
    TacoCat
    Johnny-5
    Chantilly, VA
    I wanna be there to see you cut your bedsides to see the expression on your face. I think it will be priceless given the amount of care you put into the truck :laughing:
    Just make sure not to sneeze in the process.
  14. Apr 16, 2014 at 5:40 AM
    #694
    superwhite10
    Garner, NC
    first cut is the hardest, after that its cake
  15. Apr 16, 2014 at 6:25 AM
    #695
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    it's possible for an alignment to alter height a little. how did your alignment numbers change?
    toe in can force the suspension up, while toe out can pull the suspension down. lessening the castor can raise the trucks a little, and even extreme amounts of camber can change height. none of these will have too much of an affect on it's own, but it'd be possible to see a small change with all of them combined.
    I thought the EBC stuff had a 1000 mile break-in? are the yellows just a shorter period?
  16. Apr 16, 2014 at 6:45 AM
    #696
    CanisLupus
    Stokesdale | NC
    :anonymous:
    I don't think it will be too bad. I'm just going to make a test cut maybe a 1/2'' below what will be the final cut, and just slowly make cuts going up while test fitting.
    Final numbers were 0* toe, -1* camber, and 3* caster. They said they couldn't get camber closer to 0* without going way over.
    My height went down maybe 3/4'' after alignment... :notsure:
    From the EBC site, if you have both new rotors and pads, it's 100-200 miles of light pressure, 100-200 miles of medium pressure, then you do 10 consecutive stops from 60 mph to 10 mph, then let cool. Then it is just normal braking from there.
    They say you need a lot more miles to bed if the rotors are not new.
  17. Apr 16, 2014 at 7:02 AM
    #697
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    So if you had a net of negative toe before hand, and a lower castor number, it's feasable that with the new numbers, that it's causing you to ride lower. ther other potential is that they checked your tire pressure before the alingment to make sure they were all at the same pressure, and dropped them all down to the factory 32 psi or whatever it is. can't hurt to check you rpressures.
  18. Apr 16, 2014 at 7:28 AM
    #698
    CanisLupus
    Stokesdale | NC
    Hmm. I will check my tire pressure. I think I'm still going to wait till maybe Monday or so and crank them back up to what I want them and then take it in and get the lifetime alignment.
  19. Apr 22, 2014 at 9:11 AM
    #699
    AR15xAR10
    About Time for my 10 60-10mph stops
  20. Apr 22, 2014 at 9:59 AM
    #700
    CanisLupus
    Stokesdale | NC
    I am now at about 340 miles total and I have full pad contact. Started the medium pressure at 200 miles and will probably keep doing it until I get to 400 miles total, then do the 60-10 stops.
