(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Jul 20, 2014 at 7:20 PM
    #1121
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I imagine if you make some sort of override switch.....its possible. But i'm not wiring person so BUMP! :eek:
  2. Jul 20, 2014 at 7:22 PM
    #1122
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    You can get a 3 position switch (on-off-on with reverse), with a relay, wire into the reverse circuit with a diode, that diode keeps your reverse lights from coming on when your lights are on, and keeps the R lights off on the dash when your switch is on the "on" position, then just wire up the switch as normal with a 12 volt source either on with ignition or always on. I don't have a diagram but I think a few on here have done it. Hope that helps.
  3. Jul 20, 2014 at 7:28 PM
    #1123
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I already have my OTRATTW switch, and its a normal SPST rocker. This couldn't be used then? I don't mind having to hit the rocker whenever I reverse, I was just curious if you could do this easily.
  4. Jul 20, 2014 at 7:44 PM
    #1124
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    I think you can, I'm by no means very well versed in this but if you get a relay then put pin 86 to a diode to reverse circuit, pin 87 to aux lights, pin 85 to ground, pin 30 to fuse to battery. Switch goes to pin 86 and then a 12v source either ignition or battery
  5. Jul 20, 2014 at 9:01 PM
    #1125
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    I used a SPDT switch to wire mine up like that. 3 position switch that is on with reverse lights, off all together, or on all the time. With a SPST switch I don't think you can do it though but let me think about it.
    Edit: Wrote down how I did mine and showed it would be relatively simple to do it with a SPST switch. My setup on the left (SPDT center off switch) and a SPST switch shown on the right. No diode needed as the OTRATTW switches are break before make. If your reverse lights have a large current draw, you could wire the output to a relay coil and power the lights seperately
  6. Jul 20, 2014 at 10:06 PM
    #1126
    CanisLupus
    Stokesdale | NC
    Thanks for the help, although I will have to show this to the local member who's going to help me with the install considering I have the wiring skill of a box of rocks.
  7. Jul 21, 2014 at 4:35 AM
    #1127
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
  8. Jul 21, 2014 at 9:38 AM
    #1128
    CanisLupus
    Stokesdale | NC
  9. Jul 21, 2014 at 2:19 PM
    #1129
    CanisLupus
    Stokesdale | NC
    Rigid SR-M FM back up light kit is here! Hopefully install will be soon...
  10. Jul 21, 2014 at 2:26 PM
    #1130
    AR15xAR10
    Install ANNNNNND review :boink:
    :D
  11. Jul 21, 2014 at 4:13 PM
    #1131
    CanisLupus
    Stokesdale | NC
    Soon, my friend :)
  12. Jul 21, 2014 at 4:27 PM
    #1132
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    What wire did you tap under the dash? I had it saved in a thread preban then it dissapeared...
  13. Jul 21, 2014 at 6:58 PM
    #1133
    CanisLupus
    Stokesdale | NC
    So, since the rocker only has an "off" and "on," how would that work with turning the lights on when the truck is not in reverse?
    You would have to have a 3 position switch, correct? i.e. Off, (not on, not in reverse) on, (lights on, not in reverse) and on (lights on, in reverse)?
  14. Jul 21, 2014 at 8:16 PM
    #1134
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    :spy:
    You coulda just asked me about wiring lol but I think you're getting there. Not doable with a rocker like you have. At least not to my knowledge.
  15. Jul 21, 2014 at 8:46 PM
    #1135
    CanisLupus
    Stokesdale | NC
    I literally just saw this link as I checked my build. I have no idea what I'm looking at with wiring diagrams, but this makes it seem like it is possibly with a SPST?
    Second Diagram
  16. Jul 21, 2014 at 9:29 PM
    #1136
    memario1214
    Colton
    Missoula, MT
    It sure looks that way! I have not personally done it that route, but it looks like it works.
  17. Jul 21, 2014 at 9:31 PM
    #1137
    CanisLupus
    Stokesdale | NC
    Hmm...
    I now pose you the same question from the previous page:
  18. Jul 21, 2014 at 10:02 PM
    #1138
    memario1214
    Colton
    Missoula, MT
    Sent you something... I am not 100% positive.
  19. Jul 21, 2014 at 10:20 PM
    #1139
    CanisLupus
    Stokesdale | NC
    I tried to watch it but it's basically Russian to me :eek: so I will have to seek the advice of the local member who will be "helping" install it for me to see what we can do.
    Thank you though :)
  20. Jul 21, 2014 at 10:26 PM
    #1140
    memario1214
    Colton
    Missoula, MT
    When are you doing the install?
