(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Aug 4, 2014 at 4:07 PM
    #1181
    Large
    Large Red
    Thanks, it's a money pit for sure. :eek:
  2. Aug 4, 2014 at 4:09 PM
    #1182
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    You know i'm teasing! I may go....probably be too busy :(
  3. Aug 4, 2014 at 4:12 PM
    #1183
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    :) It sure is...
    Just messing...I should be able to go unless anything unforeseen comes up. Excited to meet some other TW dudes and actually wheel. GWNF was ok, but I would mainly classify it as dirt roads with some rocky portions.
  4. Aug 4, 2014 at 4:13 PM
    #1184
    la0d0g
    running for the hills
    For crawling not hauling
    I got in on the group buy and they were here right quick. Hit up box rocket and he should be able to connect you to the 'local to the states' guy.
    I'll see if I can find it too.
    Edit: It was Kurt at Cruiser Outfitters. I know you can't get in on the GB but here are the details http://www.tacomaworld.com/forum/off-roading-trails/313243-maxtrax-group-buy.html
  5. Aug 4, 2014 at 4:20 PM
    #1185
    CanisLupus
    Stokesdale | NC
    Damn, I don't even remember seeing that thread.
    PM'd BoxRocket, but maybe I can look around for some deals. Might actually get these sooner rather than later, as well as the Pelican case, since I'm impatient. This might just be a test for me though :)
  6. Aug 5, 2014 at 2:13 PM
    #1186
    CanisLupus
    Stokesdale | NC
    Put in the order for a 5W 20'' spot lightbar from Vivid Illumination (Colton) for his group buy. I was pretty set on getting a Rigid E2 20'', but it would've been over $700, whereas the VIP bar will be about $215.
    The VIP lightbar from Colton puts out 16K lumens, while the Rigid puts out 18K, which I figure is pretty negligible. Although Rigid has a lifetime warranty, it is "limited" and I would rather deal with a TW member who has a 5 year warranty instead of a company who may just say I was being negligent or something and not help me.
    So in short, I'm getting a lightbar that has virtually the same output, but for $550+ cheaper; and I'm helping out a TW member and vendor.
  7. Aug 5, 2014 at 2:25 PM
    #1187
    AR15xAR10
    That is why you are one of the good guys :thumbsup:
    On my list is either a satoshi grill and a bamf behind the grill mount with a 20"
    Or
    An avid front light bar with a 20"
    Totally undecided on the bar brand but as for type, i'd like to have a combo.
  8. Aug 5, 2014 at 2:29 PM
    #1188
    CanisLupus
    Stokesdale | NC
    I use to have an Avid. I would recommend a Satoshi and the BAMF BTG bracket, purely because of what I think looks good :rolleyes:
    I think Avid's look pretty slick bare, but I think putting lights on the Avid lightbar (ironic, yes, I know) makes it look a little goofy.
    As far as the pattern...Colton says in his GB thread that he "...will almost always recommend spot as even they have a bit of flood light by default due to shallow reflectors."
    I was thinking about a combo as well, but going off what he said, I'm just gonna get the spot.
  9. Aug 5, 2014 at 2:34 PM
    #1189
    AR15xAR10
    Believe me, he is definitely worth consulting before any light purchase :)
    I had a used BAMF lined up but knew if i bought it, that i'd be buying another grill and satoshi-ing it (probably just mess it up) and it would cost me a good bit of money. :eek:
  10. Aug 5, 2014 at 2:51 PM
    #1190
    CanisLupus
    Stokesdale | NC
    You on the list with Homer?
    The BAMF brackets are definitely not cheap, I can tell you that :rolleyes:
  11. Aug 5, 2014 at 3:03 PM
    #1191
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    with multiple spot beams, you can always am a couple of them outward to get a wider field of view........but there's nothing you can do to a driving or fog beam (easily) to makie it project farther. unless you have a lot of lights, allowing you to vary the beams acordingly, you'll almost always want to go with spot.
  12. Aug 5, 2014 at 3:07 PM
    #1192
    CanisLupus
    Stokesdale | NC
    :thumbsup:
    Sweet!
  13. Aug 5, 2014 at 3:23 PM
    #1193
    la0d0g
    Not to thread jack but... remember if you do this, do a thin lip satoshi or you will need to cut part of your vertical support to fit the light bar.
  14. Aug 5, 2014 at 3:26 PM
    #1194
    CanisLupus
    Stokesdale | NC
    :thumbsup: ^
    I like the look of my thin-lip much better than full depth, I'm glad I got it. I kind of like the flush look over full depth too.
  15. Aug 5, 2014 at 3:27 PM
    #1195
    la0d0g
    I'm the opposite of you and like the deeper look, to each their own :) but I had to cut a lot out for it to fit.
  16. Aug 5, 2014 at 3:29 PM
    #1196
    CanisLupus
    Stokesdale | NC
    Speaking of Satoshi's, I need to do some epoxy work on my grill...some of the inner trim pieces are starting to crack.
    I'll probably do that on Friday...
  17. Aug 5, 2014 at 3:42 PM
    #1197
    AR15xAR10
    EEWWWWWWWWWWW :( didn't know that.
    Thank you for the info :eek:
    No but i damn sure should be.
  18. Aug 5, 2014 at 3:50 PM
    #1198
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    cut that shit out and redo it with carbon fiber :cool:
  19. Aug 5, 2014 at 5:55 PM
    #1199
    CanisLupus
    Stokesdale | NC
    :eek:
    Epoxy is already pushing it for me... :)
  20. Aug 5, 2014 at 6:26 PM
    #1200
    CanisLupus
    Stokesdale | NC
    Second Pelican case (1700NF black) and Maxtrax's (black) on the way! Used the last of my birthday money as well as the "payment" for housesitting and six pets sitting the past week for my parents. :)
    No more stuffs for a while :(
