(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Aug 7, 2014 at 12:39 PM
    #1201
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Tested out the Reese 8'' drop that came in today. I don't tow but hopefully this will work if I ever need to in a pinch. A 10'' drop might be needed though :notsure:
    Also tried to epoxy some cracks in my Satoshi, but I'm not sure if they will hold since I couldn't really get in to the spot that they're at well. We'll see tomorrow after it cures.
  2. Aug 9, 2014 at 10:53 AM
    #1202
    CanisLupus
    Stokesdale | NC
    Simple mod to secure the bed mat today. Drilled through the bed mat and put an extra bolt, large washers, and nylon nut I had laying around through the center drain hole of the bed.
  3. Aug 9, 2014 at 1:37 PM
    #1203
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    My rear squats so much because of the cap (and old suspension) that i almost have to turn my 2" drop upside down to use the trailer :(
  4. Aug 9, 2014 at 1:39 PM
    #1204
    CanisLupus
    Stokesdale | NC
    :anonymous:
    New leaf packs :)
    Also, the epoxy on my Satoshi held miraculously, and the bottom trim piece isn't flimsy and coming apart from the main grill now! :thumbsup:
  5. Aug 9, 2014 at 1:40 PM
    #1205
    AR15xAR10
    No want to spend the money on leafs when i will end up lifting it 2.5 years from now and them i'll put a bigger set of leafs in to go with the rear shocks
    I've been wanting to do stock height 5100s in the rear and 5100s with stock coils set at .85" in the front (to level the truck) and leave the leafs alone.
    But that won't happen until spring (most likely)
  6. Aug 9, 2014 at 4:55 PM
    #1206
    CanisLupus
    Stokesdale | NC
    That's a decent setup; close to what I originally had. Pretty cost friendly too.
    You could even just get a Toytek 1.5'' or 2'' AAL for cheap too.
  7. Aug 9, 2014 at 6:48 PM
    #1207
    AR15xAR10
    I no likey AAL.
  8. Aug 9, 2014 at 7:23 PM
    #1208
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Why not? Some of the best riding Tacos I have ever been in had an AAL. *Paging Colin*
  9. Aug 9, 2014 at 7:54 PM
    #1209
    AR15xAR10
    I'd rather not add to my rusty crusty old leafs when i can replace them with bigger or better
    Just a personal preference
  10. Aug 9, 2014 at 7:56 PM
    #1210
    memario1214
    Colton
    Missoula, MT
    That's a fair enough reasoning.
  11. Aug 15, 2014 at 7:01 PM
    #1211
    CanisLupus
    Stokesdale | NC
    Second Pelican case in today. Maxtrax's are still on backorder, so it will probably be another two or three weeks to get them.
    Also swapped out the ball handle pin for the T-handle pin on the latch side of my Pelfrey swingout so it's a lot easier to use, especially when the pin gets a little "sticky."
  12. Aug 15, 2014 at 7:13 PM
    #1212
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Truck's looking great Matt. anything particular living in the pelicans, or just some extra storage?
  13. Aug 15, 2014 at 7:17 PM
    #1213
    AR15xAR10
    I wish i was as cool as you Matt
  14. Aug 15, 2014 at 7:33 PM
    #1214
    CanisLupus
    Stokesdale | NC
    Thanks Colin!
    Box on the driver side has emergency stuff...MRE's, extra jacket, socks, boxers, shirt, pants, shoes, webbing and rope, and hand warmers. I have the other emergency stuff like fire extinguisher, gloves, medical gloves, CPR barrier mask, road flares, and traffic vest behind the rear driver side passenger seat, since it's better to have those things more on hand instead of in the box.
    Box on the passenger side has all my recovery and camping stuff. ARB tree protector strap, Hi-Lift base, Ames E-tool shovel, camper's axe, ARB synthetic snatch block, bolt cutters, tow strap, (gonna upgrade to ARB snatch strap in the relatively near future) Reese 8'' drop hitch, shackles, and leather gloves.
    :anonymous:
  15. Aug 17, 2014 at 4:27 PM
    #1215
    CanisLupus
    Stokesdale | NC
    Relocated the OEM reverse camera today to the license plate. Eventually I'd like to somehow put it on the right side in between the license plate indent and the Rigid lights for a more finished look, but this suits my needs right now.
    The ideal location would be in the center hub of the spare tire, but I'm not sure if I want to drill a hole with all the gussets and studs that are there. There's not really a good way to route the wires either, unless I run the wire from the bottom of the tiregate by the spindle through the tiregate square tube up to the tire mount like me and Skygear initially discussed. It's always an option, but those are thoughts for down the road.
    I realize it looks a little ghetto :anonymous: but I mainly just wanted to be able to see what was behind me below the tailgate.
  16. Aug 17, 2014 at 5:45 PM
    #1216
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Looks good! I still need to do this :anonymous:
  17. Aug 17, 2014 at 5:59 PM
    #1217
    CanisLupus
    Stokesdale | NC
    Took maybe ten minutes. Just un-routed the wires from under the tailgate trim, back through to under the bed, ran the connecter through the OEM spare tire hole, and then attached the camera with a bolt and nut I had laying around.
  18. Aug 17, 2014 at 6:28 PM
    #1218
    AR15xAR10
    Looks like its covering your license plate sticker doe
    :eek:
  19. Aug 17, 2014 at 6:46 PM
    #1219
    skygear
    skygear                    
    We can make a bracket for that. I found more aluminum.
  20. Aug 17, 2014 at 6:57 PM
    #1220
    CanisLupus
    Stokesdale | NC
    Yep...luckily I shouldn't get much hassle as I have firefighter plates. Will likely move the stickers to the bottom corners if I still have the camera there when the plate expires.
    Yeah I thought about that, as the OEM camera slides out of the little angled bracket that it's in right now, but didn't want to do anything too crazy right now. Might start planning how to attach and make a bracket for it.
