(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Feb 14, 2016 at 10:07 AM
    #1901
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    24F: no towing package
    27F: towing package
    I guess I will go to Autozone and get a 27F whenever the time comes. I'm nearing 40K and I'm not sure if it's just the cold, but it definitely takes an extra second to start the truck when it's anywhere below ~30*
  2. Feb 14, 2016 at 11:24 AM
    #1902
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    O. Oops. They don't have a 27f platinum so I got a 24f. Hope that doesn't come back to bite me later.
  3. Feb 14, 2016 at 11:27 AM
    #1903
    CanisLupus
    Stokesdale | NC
    I think the 27F is only needed if you're doing a lot of towing with electric trailer brakes. Research told me 24F was fine for V6's, even if it came with towing package and 27F.
  4. Feb 14, 2016 at 11:28 AM
    #1904
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    You're going to want the most capacity with a winch. Tow package or not.
  5. Feb 14, 2016 at 11:30 AM
    #1905
    TacoFMS
    Justin
    Louisa County, VA
    Well great now you two have skeered that I don't have enough battery since switching...
  6. Feb 14, 2016 at 11:53 AM
    #1906
    TacoFMS
    Justin
    Louisa County, VA
    So I know this completely takes all my street cred away automatically by asking this, but apparently I do not know anything about batteries (even though I thought I did). What are you using to judge battery capacity? Cranking amps? Doesn't the fact that it is an AGM battery, and in essence a dual purpose (not a true deep cycle though) make up for some capacity? Or does that not mean anything?
  7. Feb 14, 2016 at 11:56 AM
    #1907
    ckeene9
    Chesterfield, VA
    See Build Thread
    You need reserve capacity (RC) for high amp draw or constant draw equipment. The winches we use have the ability to pull up to 500 amps. The 140 or 160 amp (can't remember which) alternator won't be able to keep up and require battery capacity for those kinds of pulls.
  8. Feb 14, 2016 at 12:01 PM
    #1908
    TacoFMS
    Justin
    Louisa County, VA
    Well I'm stupid. :pout:
  9. Feb 14, 2016 at 12:16 PM
    #1909
    CanisLupus
    Stokesdale | NC
    24F has less reserve capacity but more CCA, 27F has more reserve but less CCA...at least, from what I've read.
    So it seems 27F (or others with more RC) are best with a winch. My truck started to die when I was doing a particularly hard pull of another Tacoma through a snow drift during this last storm. Repositioned so it wasn't as hard of a line but my lights and truck started to die when it was a pull through ~1.5' of snow.
  10. Feb 14, 2016 at 12:23 PM
    #1910
    TacoFMS
    Justin
    Louisa County, VA
    So I will be heading back to autozone shortly to swap the platinum out for a 27f gold.
    That the correct one right? I'm just frustrated and confused now and a little angry with myself.
  11. Feb 14, 2016 at 12:33 PM
    #1911
    CanisLupus
    Stokesdale | NC
    :laughing: Relax my friend. I'm learning about batteries now, I really don't know much. I think the Duralast 27F Gold is the correct one from VatoZone since I don't think they have a 27F Platinum.
  12. Feb 14, 2016 at 12:37 PM
    #1912
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    That was how mine started. Then it would take two cranks (turns of the key) to start. So its probably due. I got 3.5 years out of the toyota battery.
  13. Feb 14, 2016 at 12:46 PM
    #1913
    CanisLupus
    Stokesdale | NC
    Found this post from another forum:
    Not sure if AGM is needed though because it looks like the 34R has more cranking amps but less reserve than even the 24F.
  14. Feb 14, 2016 at 12:50 PM
    #1914
    CanisLupus
    Stokesdale | NC
    Updated all dead links from the OP.
  15. Feb 14, 2016 at 12:55 PM
    #1915
    CanisLupus
    Stokesdale | NC
    :der: You already posted this
  16. Feb 14, 2016 at 12:56 PM
    #1916
    TacoFMS
    Justin
    Louisa County, VA
    I don't know what you are talking about. :wink:
  17. Feb 14, 2016 at 12:57 PM
    #1917
    TacoFMS
    Justin
    Louisa County, VA
    Very good breakdown of the AZ batteries. Thank you.
  18. Feb 14, 2016 at 12:57 PM
    #1918
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    I've been looking at replacing my stock battery this summer with a 200A alternator and the Interstate 31-agm7 battery. IIRC it has 830 CCA, 190 minutes, and 100 AH, seems like it's the best I've seen since the Sears platinums are discontinued. It's also 6# lighter than the platinum at 69#. Dimensions are similar.
    CanisLupus[OP] likes this.
  19. Feb 14, 2016 at 1:29 PM
    #1919
    CanisLupus
    Stokesdale | NC
    The toys
    AR15xAR10 and fatfurious2 like this.
  20. Feb 14, 2016 at 4:00 PM
    #1920
    TacoFMS
    Justin
    Louisa County, VA
    Yep, I'm jealous of you too.
    Battery is officially swapped out to a 27f and I got $68 back on the swap. That will go towards my first bottle of welding gas. Of course the way I'm going I will probably buy the wrong kind of gas.
