(SOLD) CanisLupus Ninja 300 Build
Discussion in 'Other Builds' started by CanisLupus, Jun 6, 2015.
  1. Jun 6, 2015 at 9:45 AM
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    VEHICLE IS SOLD
    CanisLupus 2013 Ninja 300 Build Page
    Updated 04/11/17
    GENERAL
    --- 2013 Kawasaki Ninja 300
    --- Pearl Stardust White
    --- Fuel Injected Non-ABS
    --- Six Speed Transmission
    RECORDS
    --- Purchased: 8,500 Miles (06/24/15)
    --- Current: 13,500+ Miles (04/15/17)
    --- VA Inspection Due: 08/31/17
    --- County Tag Due: 11/15/17
    --- Registration Due: 06/31/18
    --- Body Washed: 02/27/16
    --- Chain Clean & Lube: 13,575 Miles
    --- Chain Adjustment: 11,950 Miles
    --- Oil Changed: 12,xxx Miles
    RIDING GEAR
    --- Balaclava: Schampa Warmskin Balaclava
    --- Boots: Alpinestars SMX Plus Boots
    --- Gloves: Scorpion SGS Gloves (Hi-Viz)
    --- Glove Liners: Arctiva Thermolite Glove Liners
    --- Helmet: Shoei RF-1200 Beacon (Hi-Viz)
    --- Jacket: Joe Rocket Phoenix Ion Jacket
    --- Pants: Klim K Fifty 1 Riding Jeans
    --- Shoes (Spares): TCX X-Square Sport Shoes
    --- Shoes (Spares): TCX X-Steet Waterproof Shoes
    MISCELLANEOUS
    --- Drift Stealth 2 Helmet Camera
    --- Helmet Butler Gear Rack
    --- Kriega R20 Riding Backpack
    --- Kriega US-10 Tailpack Bag
    --- Sena SMH10R BT Headset
    MAINTENANCE
    --- K&N KA-2508 Air Filter
    --- K&N KN-303 Oil Filter
    --- Maxima Chain Wax
    --- Maxima Chain Cleaner
    --- Mobil 1 R4T 10W40 Oil
    --- Motul Helmet Cleaner
    --- Pit Bull Hybrid Forklift Front Stand
    --- Pit Bull Spooled Rear Stand
    --- Revzilla Chain Grunge Brush
    BIKE MODIFICATIONS
    --- Bridgestone Battleax BT090 (Rear)
    --- Bridgestone Hypersport S20 (Front)
    --- Deltran Battery Tender (PO Installed)
    --- DID 520VX2 X-Ring Chain (Gold)
    --- EBC Double-H Sintered Brake Pads
    --- Front Side Reflector Delete
    --- JT 14T / 42T Sprocket Set
    --- Pit Bull 10MM AL Spool Kit
    --- Pro Grip Tank Protector Pad
    --- Pro Grip Wheel Tape (White)
    --- RamMount U-Bolt/Phone Mount
    --- Removed Under Seat Storage Tray
    --- Spy 5000m Alarm (PO Installed)
    --- TopMaxMotor CNC Shorty Levers
    --- Yoshimura Fender Eliminator Kit
    --- Yoshimura Steering Bolt (Grey)
    FUTURE BIKE RESEARCH
    --- KTM 350-EXCF - ($10,200)
    --- Yamaha FZ-09 - ($8,200)
    --- Yamaha WR250R - ($6,700)
    BUILD REFERENCE LINKS
    --- How-To: Adjust Gauge Clock (DST)
    --- How-To: Chain Adjustment Video
    --- How-To: Oil Change Video
    --- How-To: Oil Change Sticky
    --- How-To: Remove Rear Fairings
    --- How-To: Yoshimura Exhaust Install
    --- How-To: Yoshimura FEK Install
    --- Kawasaki OEM Parts Finder
    --- Kawasaki OEM Specifications
    --- Kawasaki Owner's Manual
    --- N3F: DIY Maintenance Thread
    --- N3F: Winterization Discussion
    BUILD REFERENCE
    --- Brake Size (Front): 290mm
    --- Brake Size (Rear): 220mm
    --- Chain Slack Range: 20mm-30mm
    --- Fuel Capacity: 4.5G
    --- Oil Capacity: 2 qts / 2.4 L
    --- Oil Drain Bolt Torque: 14.5 ft/lbs
    --- Oil Filter: K&N KN-303
    --- Oil Type: SAE 10W-40
    --- Rear Axle Nut Torque: 72 ft/lbs
    --- Steering Stem Torque: 32 ft/lbs
    --- Tire Pressure (Front): 28 psi
    --- Tire Pressure (Rear): 32 psi
    --- Tire Size (Front): 110/70-17
    --- Tire Size (Rear): 140/70-17
    ChadsPride and AR15xAR10 like this.
  2. Jun 6, 2015 at 9:45 AM
    CanisLupus
    Stokesdale | NC
    BUILD PICTURES
    HJC HELMET, JR JACKET, EVS GLOVES, KLIM RIDING JEANS, TCX RIDING SHOES, HELMET BUTLER RACK
    06/17/15
    ROUTINE MAINTENANCE & CLEANING PRODUCTS
    06/17/15
    PITBULL SPOOLED REAR STAND
    06/17/15
    PURCHASED!
    06/24/15
    INSTALLED PIT BULL 10MM SPOOL KIT
    06/25/15
    REMOVED FRONT SIDE REFLECTOR
    06/27/15
    RECEIVED DELTRAN BATTERY TENDER SYSTEM
    06/27/15
    INSTALLED REAR BRIDGESTONE HYPERSPORT S20 EVO (8,650 MILES)
    07/02/15
    RECEIVED KRIEGA R20 RIDING BACKPACK
    07/8/15
    RECEIVED BIKE MASTER CARGO NET (REMOVED)
    07/15/15
    FRONT FORK REBUILD & FRONT BRIDGESTONE HYPERSPORT S20 EVO (8,860 MILES)
    07/16/15
    INSTALLED PROGRIP TANK PROTECTOR
    07/16/15
    REMOVED REAR SIDE REFLECTOR (REMOVED)
    07/17/15
    INSTALLED RAM HANDLEBAR PHONE MOUNT
    07/20/15
    INSTALLED WHITE PROGRIP WHEEL TAPE
    08/4/15
    RECEIVED SCORPION SGS GLOVES (HI-VIZ) & MOTUL HELMET CLEANER
    08/12/15
    REMOVED STORAGE TRAY UNDER REAR SEAT
    08/16/15
    INSTALLED YOSHIMURA FENDER ELIMINATOR KIT
    08/21/15
    INSTALLED KRIEGA US-10 TAILPACK BAG
    08/27/15
    REPLACED OEM FILTER WITH K&N KA-2508 (9,000 Miles)
    09/08/15
    INSTALLED YOSHIMURA STEERING STEM BOLT
    09/08/15
    PLASTI-DIPPED FRONT WINDSCREEN (REMOVED)
    10/20/15
    RECEIVED SHOEI RF-1200 BEACON & CHROME MIRROR VISOR
    11/23/15
    MOUNTED UCLEAR HD HELMET SPEAKERS (REMOVED)
    12/10/2015
    MOUNTED DRIFT STEALTH 2 HELMET CAMERA
    12/11/2015
    INSTALLED SHOEI PINLOCK INSERT
    12/31/2015
    INSTALLED SENA SMH10R BLUETOOTH SYSTEM
    12/31/2015
    RECEIVED ARCTIVA GLOVE LINERS
    12/31/2015
    INSTALLED TOPMAXMOTORS SHORTY LEVERS
    01/21/2016
    INSTALLED DIDVX2 CHAIN & JT F/R SPROCKETS (11,350 MILES)
    02/27/2016
    RECEIVED ALPINESTARS SMX PLUS VENTED BOOTS
    03/20/2016
    PLASTI-DIPPED LOWER FAIRINGS WHITE (REMOVED)
    04/19/2016
    INSTALLED BRIDGESTONE BATTLEAX BT090 REAR TIRE (13,000 MILES)
    09/08/2016
    THANKS FOR READING! FEEL FREE TO POST IN THIS THREAD OR PM FOR QUESTIONS!
  3. Jun 6, 2015 at 9:45 AM
    CanisLupus
    Stokesdale | NC
  4. Jun 6, 2015 at 10:44 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Schweeet. Congratulations dude!
    Now i need to make one of these
  5. Jun 6, 2015 at 1:07 PM
    CanisLupus
    Stokesdale | NC
    It may be one of the happier days of my life when I actually get to ride it :)
    Get on it!
  6. Jun 6, 2015 at 4:39 PM
    AR15xAR10
    We'll see :cool:
  7. Jun 7, 2015 at 2:15 PM
    CanisLupus
    Stokesdale | NC
    Just ordered some more stuff in preparation. Klim K Fifty 1 armored riding jeans, TCX Waterproof riding shoes, Pit Bull Spool Kit, Pit Bull Rear Stand, RevZilla Grunge Brush, Maxima Chain Cleaner, and Maxima Chain Wax.
    May be a lot of money right now, but I would rather spend a couple hundred bucks armoring up head to toe and be better protected in a crash, especially since I am a new rider and will most likely have a drop at some point in the future. Other maintenance parts will also help me as I start learning more about motorcycle maintenance.
    Excited as hell to start my riding career!
    AR15xAR10 likes this.
  8. Jun 9, 2015 at 9:18 AM
    CanisLupus
    Stokesdale | NC
    Picked up some Mobil 1 Racing 4T 10W-40 synthetic oil, K&N KN-303 oil filter, an oil drip pan, and a funnel in preparation.
    I'll have to ask the current owner when his last oil change was when I buy it, but I like to be ready just in case :)
  9. Jun 11, 2015 at 8:03 AM
    CanisLupus
    Stokesdale | NC
    Ordered a Helmet Butler gear rack today to help keep my gear organized and from just sitting on shelves in my garage (takes up a lot of space).
    Seems like a really cool product.
  10. Jun 11, 2015 at 7:40 PM
    CanisLupus
    Stokesdale | NC
    Current owner looking to sell in about a week!!!
    Should have the rest of my gear and maintenance stuff in by Monday and Helmet Butler sometime after that.
  11. Jun 11, 2015 at 9:39 PM
    AR15xAR10
    Get on it! Not much of a build without a bike! :p
  12. Jun 11, 2015 at 10:30 PM
    CanisLupus
    Stokesdale | NC
    I know :oops: I feel kinda stupid updating this thing with no bike, but I'm just excited :anonymous:
    AR15xAR10[QUOTED] likes this.
  13. Jun 16, 2015 at 5:01 PM
    CanisLupus
    Stokesdale | NC
    Last of my gear, Helmet Butler, and maintenace stuff showed up today.
    I'm gonna have to try and get my Klim jeans hemmed tomorrow as they're pretty long since I'm a short bastard.
    There's probably about three to four inches of just jeans at the bottom before the mesh liner starts. Hopefully that will be enough to make them fit better. They will also fit better on the bike with me in riding position I think.
  14. Jun 17, 2015 at 9:58 AM
    CanisLupus
    Stokesdale | NC
    Installed the Helmet Butler and took my Klim jeans to the cleaners to get hemmed. I asked them to tailor 2'' off, leaving about 1/4''-3/8'' of jean material past the mesh liner.
    I know this stuff is probably boring to everybody considering I don't even have the bike yet, but I can't contain myself... :anonymous:
    Hopefully will be buying the bike at the end of this week or beginning of next, then will have to get all the registration and insurance sorted out, then I will finally get to ride!
  15. Jun 17, 2015 at 10:52 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I did the exact same thing before I bought my bike. Bought a helmet, summer mesh jacket, winter jacket, gloves, and other various things right when I was done with the class. Felt dumb because I didn't have a bike and all this gear but a month or so after, found a bike. At least you have a bike lined up!
  16. Jun 17, 2015 at 1:37 PM
    CanisLupus
    Stokesdale | NC
    Yes, I'm glad that as soon as I have the bike, I'll be ready to ride and not vice versa. It would be torture having the bike here and not being able to ride without gear or anything.
  17. Jun 17, 2015 at 5:23 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Yeah exactly! That helmet butler is cool, never seen that before. Does it stay on there pretty sturdy?
  18. Jun 17, 2015 at 5:39 PM
    CanisLupus
    Stokesdale | NC
    Helmet Butler is definitely cool. I wouldn't say it's rock solid (bracket is plastic) but it is actually pretty sturdy. It can hold up to 50lbs of gear.
  19. Jun 17, 2015 at 6:22 PM
    AR15xAR10
    I had my gear before i had my bike. Chain lube too.
  20. Jun 17, 2015 at 8:13 PM
    CanisLupus
    Stokesdale | NC
    Forgot I had a picture of the actual bike I'm buying. Posted in OP.
    Also found out the current owner just replaced the shifter lever (was a little rusty) and also put in a new battery, so this bike is going to be a great deal.
