SOLD: Custom bed divider
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by tacotroy17, May 1, 2019.
Thread Status:
Not open for further replies.
  1. May 1, 2019 at 7:12 PM
    tacotroy17
    tacotroy17 [OP] Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Have a bed divider I built out of 80/20 extrusion. Mounted my traction boards, shovel and axe to it and haven't had any problems with it. It's pretty modular as well. I see the OEMs going for about 150+ so $100 seems like a good starting point. Quick fist not included. SOLD
    Located in West Covina, CA. Pefer local, but if someone wants to pay shipping I could even break it down and save on the cost. 20190501_190256.jpg 20190501_190330.jpg
  2. May 2, 2019 at 7:24 AM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
  3. May 2, 2019 at 8:01 AM
    shawn3210
    shawn3210 Well-Known Member
    california
    2018 turd offroad 2wd
    stock
    does it fit under a cover?
  4. May 2, 2019 at 9:03 AM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    It sits just about flush with the bed rails. If you cover doesn't interfere with the rails it should not interfere with this.
  5. May 2, 2019 at 10:17 AM
    GoldenBeard
    GoldenBeard Member
    2016 TACOMA INFERNO RED
    Interested... Im Local!
    tacotroy17[OP] likes this.
  6. May 2, 2019 at 11:10 AM
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    messaged
  7. May 3, 2019 at 2:31 AM
    Hiapo808
    Hiapo808 New Member
    Bryan
    Tacoma off road
    Is this still available?
  8. May 3, 2019 at 3:28 AM
    .223Taco
    .223Taco Well-Known Member
    Austin, Tx.
    '18 Cement DCSB OR
    I could use something like this
  9. May 3, 2019 at 6:17 AM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    How did you have it mount to the rails? I've been looking for something like this that can be moved around the rails with out have to slide them to move. Something with a design sort of like the bed cleats.
    I have a topper with mount points that wont let something this slide freely.
  10. May 3, 2019 at 10:22 AM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Sold it last night
  11. May 3, 2019 at 10:22 AM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    It worked out great for me. Pretty easy to build as well.
  12. May 3, 2019 at 10:26 AM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    It was mounted to the rails by t-slot nuts. It would have to be unscrewed to be moved. 8020 has some good options for mounting stuff like this. Maybe you could come up with something custom to work with your topper.
Thread Status:
