SOLD Custom Turn Signal/Puddle Light Heated Mirrors
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by nzbrock, Jun 28, 2019.
Thread Status:
Not open for further replies.
  1. Jun 28, 2019 at 5:58 AM
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    These mirrors are direct bolt on for 96-04 Tacomas. I built these from OEM 4Runner internals and bases, with Revier turn signal housings from Japan.
    The housing is chrome and the bases are textured black.
    They have the stock 3 wire connector, and are plug and play with your existing power mirror circuit.
    They have 3 other leads as follows:
    R/B/BL = Turn/Ground/Running Light
    W/B = Puddle/Ground Light
    P/GR or BR/GR = Heater/Ground
    They come with enough wire to run from the mirror to inside of the cab. After that you must tap into existing circuits or run new ones for the heater, etc.
    I built these as a test to see how complicated it would be. Eventually I will probably make more when I have time.
    SOLD
    EDIT:
    Here is my personal set that I made to match my truck.
    STNSFNST, Dalandser, RtacomaN and 9 others like this.
  2. Jun 28, 2019 at 6:06 AM
    cali04intx
    cali04intx Hung like Einstein, smart as a horse
    Djesse
    Left Coast!..The Best Coast.
    '04 DC V6
    As always Brahda, quality work.
    FirstTimeFirstGen likes this.
  3. Jun 28, 2019 at 6:11 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Nice job. I love the custom 3rd gen mirrors I build for my truck. These should go over well.:hattip:
  4. Jun 28, 2019 at 8:51 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Someday I'll get mine put on. LOL only had the dam things about a year. LOL!
    They look good buddy. Great find.
    tony2018 and cali04intx like this.
  5. Jun 28, 2019 at 11:35 AM
    nzbrock
    Noah
    San Marcos, TX
    I believe that you have to use 4Runner mirrors. I never had an OEM set of 01-04 Tacoma mirrors, but the 4runner ones are slightly different then the aftermarket ones that I had. They have an extra screw to mount the internals to the case from the outside, and the base also has a tab that needs to be trimmed off to mate with the door.
    Also, be careful taking the base screws out when separating the case. They tend to corrode and have loctite on them. I highly suggest heating them with something before trying with an impact driver. They are very easy to strip.
  6. Jun 28, 2019 at 11:40 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I dealt wit all that before when I had mine apart.. Allen heads in them now.
    nzbrock[QUOTED][OP] likes this.
  7. Jun 30, 2019 at 5:56 AM
    blind_1560
    blind_1560 Well-Known Member
    nick
    Any chance these would fit on a 3rd gen runner?
  8. Jun 30, 2019 at 7:26 AM
    nzbrock
    Noah
    San Marcos, TX
    They will, but I changed the wiring so it wouldn’t be plug n play. I also trimmed off the “retaining screw” since it doesn’t work on Tacoma’s.
  9. Jun 30, 2019 at 12:15 PM
    blind_1560
    nick
    Any chance you could build one for a 3rd gen 4 runner that’s plug and play? Pm inbound
  10. Jul 2, 2019 at 4:55 PM
    willz503
    willz503 Well-Known Member
    Las Vegas
    2001 Xtra Cab V6 4x4 M/T (Impulse Red)
    @nzbrock I've been considering building something like this for a while now and stumbled across this post! (even have the same color truck!) I'd still like to build my own, but I was wondering if you could tell me where you sourced your marker lights? I tried a couple searches using your "Revier turn signal housing" and found overseas websites, but couldn't find the same lights that you used. Thanks!
  11. Jul 3, 2019 at 5:58 AM
    DawsonDestroyer
    DawsonDestroyer Well-Known Member
    Dawson
    Oklahoma City, Oklahoma
    2002 Tacoma Prerunner Double Cab
    Wow those look great
  12. Jul 3, 2019 at 10:29 AM
    nzbrock
    Noah
    San Marcos, TX
    You can only get them from Japan. I got these from global rakuten https://global.rakuten.com/en/store/revier/item/lm-k009f-sp-sp/
    EDIT: you can get them on eBay but they are overpriced.
    https://www.ebay.com/itm/4Runner-97...Signal-Light-Position-Lamp-Paint/263162099431
  13. Jul 4, 2019 at 5:55 PM
    willz503
    Las Vegas
    @nzbrock - gotcha!!! That's why I couldn't find them. I thought you just bought the lights and built a custom housing for the mirror covers... Thanks for the links!! Much appreciated!
  14. Jul 9, 2019 at 8:43 AM
    nzbrock
    Noah
    San Marcos, TX
    Still have these, lots of interested but no one committed yet. Make me a reasonable offer and I might just take it.
  15. Jul 9, 2019 at 8:30 PM
    veleno
    veleno Well-Known Member
    Is it easy to replace the side and puddle bulbs if they fail?
  16. Jul 10, 2019 at 6:29 AM
    nzbrock
    Noah
    San Marcos, TX
    To do that you have to remove the mirror housing. First you pop the mirror off and disconnect the heater wiring.
    Then remove 4 screws holding the mirror motor to the housing plus one screw on the outside.
    Then remove 3 screws that mount the motor to the base.
    After that both lights can be removed, the puddle lights just snap in. The signal lights are held in with 3 screws.
    The problem is then you need to get those lights from Japan, and you'd most likely need to get all new housing in order to get them.
    I doubt the LEDs will die anytime soon though. If you don't wire up the running light, then these really aren't on that frequently.
  17. Jul 10, 2019 at 6:40 AM
    BeardedTacoma
    BeardedTacoma Well-Known Member
    Justin
    Hotlando
    2000 Tacoma x-cab 4x4 (SOLD)
    Do you have options, to make them work without factory power mirrors?
    You have beautiful art work, Noah! WoW!!
    jackn7 likes this.
  18. Jul 10, 2019 at 6:45 AM
    nzbrock
    Noah
    San Marcos, TX
    They are the powered mirror version, but you could simply just push on the glass to aim them if you wanted. Wiring in the lights is up to the user since you'd need to decide where to tap in (and it may be different for different years). For example, if you have 95.5-00 you can wire the puddle lights into the door courtesy light so they come on when you open the door. That circuit is always hot and uses a switched ground, so you can't just tap into a 12v+ line, you have to wire both hot and ground to that circuit.
    I chose not to wire the running lights on mine since I didn't feel like having them on all the time, but there is a wire to tap into in the driver kick panel where I tapped into the turn signal.
  19. Jul 17, 2019 at 4:42 AM
    nzbrock
    Noah
    San Marcos, TX
    BUMP, lowered to $375!
  20. Jul 22, 2019 at 1:00 PM
    nzbrock
    Noah
    San Marcos, TX
    Bump, you know you want this!
Thread Status:
