SOLD DELETE PLEASE
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Babish_SD, Aug 31, 2020.
  1. Sep 10, 2020 at 12:54 PM
    Babish_SD
    Babish_SD [OP] Well-Known Member
    Brian
    2016 Quicksand Tacoma TRD Sport
    price drop $450....bump
  2. Sep 10, 2020 at 3:06 PM
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    Tempting...
    Babish_SD[OP] likes this.
  3. Sep 10, 2020 at 3:24 PM
    Babish_SD
    Brian
    its well under the price of ordering them + shipping. sadly they are just too big for my set up.
  4. Sep 12, 2020 at 10:16 AM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    Not to talk you out of a sweet deal before I can convince my new wife to let me buy these, but were you running into overall length or travel length issues?
    Shortening the travel just requires adding/replacing an $11 shaft spacer: hate to see you take this big a loss on a simple fix.
  5. Sep 12, 2020 at 11:07 AM
    Babish_SD
    Brian
    Yeah I was under the impression that since my rear lift is going to be 2-3 inches with some weight in the back (putting camper on) that this overall stroke length would not work and would be to long to squeeze in the back on my 3rd gen short bed....am I under the incorrect impression? I had a feeling we could make it work, but with some major manipulation....
  6. Sep 12, 2020 at 11:46 AM
    MuddySquirrel
    Will
    Phoenix
    No worries, the work needed isn't too bad if you do your own, but is probably prohibitive if you're farming it out. Either way, free bumps.
    With that set-up, yes: a 4" bump is likely to be engaging frequently and you'll want to shorten the stroke/travel. You can shorten the stroke by adding a shock spacer; this is a cheap part but does require tearing down the shock.
    The shock body length you're stuck with. I think your dimensions should be close to mine: I have 6.5" under the bed and 16" if I go slightly outboard. These bumps would have to be slightly outboard or through the bed (9.75"): a smaller set with 2" of travel would pretty well fit under (6.75").
    You can also see what you're routinely cycling by throwing a zip tie around the top of your shaft and seeing how far it gets pushed down.
  7. Sep 12, 2020 at 12:00 PM
    Babish_SD
    Brian
    Yeah unfortunately I'll be paying some one else to do it. womp womp. Figured hoping to just put this money towards that.
  8. Sep 12, 2020 at 12:00 PM
    Babish_SD
    Brian
    Thanks for the bumps!
  9. Sep 13, 2020 at 11:43 AM
    Babish_SD
    Brian
