Sold! Dynomax 39447 stainless 2-1/2" cat-back exhaust (NJ)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by JL8Jeff, Apr 19, 2021.
Thread Status:
Not open for further replies.
  1. Apr 19, 2021 at 10:17 AM
    JL8Jeff
    JL8Jeff [OP] Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Sold!
    I have a new Dynomax 39447 stainless steel cat-back exhaust. It's 2-1/2" piping and comes with a welded Ultra Flo muffler. It's listed as 2005-2015 4.0 V6 Access Cab or Double Cab Tacoma but it can be used with the 2.7 if you elongate the holes in the intermediate pipe. I'm also including a short flanged 2-1/2" pipe with a 2 bolt flange and gasket that lines up with the 2.7 cat-pipe. I'm also including a 90 degree rubber hanger insulator for the tailpipe since the 12-15 exhaust is different from the 05-11. You could also bend the hanger on the tailpipe if you wanted to for the 12-15 trucks. I also painted the tailpipe and front section of the intermediate pipe with high temp clear just to help it stay nice a little longer. $225 Local pickup only in central NJ due to size.
  2. May 1, 2021 at 4:34 AM
    Gopher TRD
    Gopher TRD Well-Known Member
    Justin
    New Jersey
    2014 TRD Sport
    I am interested. Going to look for some soundclips. Also local here in Hopewell township.
  3. Jun 15, 2021 at 10:47 AM
    clovretin
    clovretin New Member
    Connor
    2015 Tacoma
    None
    Avail still?
  4. Jun 19, 2021 at 7:08 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Yes, I still have the exhaust, intake, injectors and auto trans cooler setup.
  5. Aug 20, 2021 at 7:17 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
  6. Aug 26, 2021 at 3:51 PM
    acas
    acas Well-Known Member
    adam
    14 double cab short bed 6 speed manual!! save the manuals
    where in central jersey are you?? Im in north jersey and am thinking about buying this from you.
  7. Aug 27, 2021 at 7:11 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    I'm in Ewing just north of Trenton off I295.
  8. Aug 28, 2021 at 4:19 PM
    Blackfreighter
    Blackfreighter Member
    Ben
    2006 4cyl Tacoma AWD extended cab
    Hey Jeff, Do you still have those injectors?
  9. Aug 28, 2021 at 5:10 PM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
  10. Aug 29, 2021 at 6:25 AM
    WRDD Taco
    WRDD Taco Big Hobby Guy
    Jake
    Delco, PA
    ‘11 TRD Sport DCLB LT 1G3 Moto Express
    TC Mid Travel +2, TC SUA, king shocks, Swamp Donkey/Rigid lighting, Mechman alt, SOS/Boztek armor, ATH Fab tiedown, full active JL/Audiofrog sound system, NOICO sound deadening EVERYWHERE. Up next: roof/bed rack + dry storage, skids, bumpers, fiberglass, power wire upgrade + frame grounds, LTO battery swap, air compressor, on board pressurized water, powered cooler, suspension seats, frame reinforcement, solid motor/trans mounts.
    Can’t believe you’re still holding onto these :ballchain: thanks again for the scan gauge !
  11. Aug 30, 2021 at 7:43 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    I've had a lot of people interested but nobody has showed up yet to buy the parts. I just put a 3" Dynomax/Cherry Bomb exhaust on my Silverado and it sounds great, a nice deep rumble. I do miss the Scangauge, I got a Diablosport I2 tuner for the Silverado but it takes several minutes for it to load up to be able to watch the different sensors, the Scangauge pops up right away for watching things like the fuel trims.
    WRDD Taco[QUOTED] likes this.
  12. Aug 30, 2021 at 7:45 AM
    WRDD Taco
    Jake
    Delco, PA
    Awesome I’ll have to pass on that info to some friends with GM rides
  13. Sep 4, 2021 at 7:27 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    The exhaust has been sold. I still have the injectors and intake.
Thread Status:
