SOLD - Factory Exhaust Manifolds 2012-2015
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by WOODEX M.E., Aug 2, 2016.
  1. Aug 2, 2016 at 4:17 PM
    WOODEX M.E.
    WOODEX M.E. [OP] Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Sold.
    Factory exhaust manifolds with cats. Everything in good working order. Removed for URD headers. Have 60k miles on them. Will need new studs for y pipe ends. Looking for $300 plus shipping.
  2. Aug 12, 2016 at 3:25 PM
    WOODEX M.E.
    Corey
    Maine
  3. Aug 28, 2016 at 7:41 PM
    WOODEX M.E.
    Corey
    Maine
  4. Aug 28, 2016 at 8:07 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    @Ryjk1003
    Not sure if there is a difference between these & ones from an 06.
  5. Aug 28, 2016 at 8:14 PM
    WOODEX M.E.
    Corey
    Maine
    They have a little additional flange on the back side for air injection on 2012 and up. I assume you could cap them off or cut them off and weld them shut and they would fit fine.
    Someone else may be able to correct me on that if I am wrong.
  6. Aug 28, 2016 at 8:26 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The o2 ports are at different angles, which matters because wire length.
