*SOLD*FOR SALE Iggy LED 20w flush mount
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by bski22, Apr 11, 2017.
Thread Status:
Not open for further replies.
  1. Apr 21, 2017 at 9:33 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    not for nothing but at the OPs asking price, these would be the cheapest thing to knock off your list of mods first... just saying
    bski22[OP] likes this.
  2. Apr 21, 2017 at 9:36 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Is this your grill? If so they should be able to surface mount right on them. The grill is whats carrying the weight of the pods anyways.
    If not then you would want to reenforce the where the mesh mounts to the grill. The mesh itself should be tough enough to hold the lights.
  3. Apr 21, 2017 at 9:42 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    No that's just from Google. Mine is 14 gauge mesh but only supported around the perimeter by some 1" L brackets, has more flex front to rear than I'd like for these pods. I could probably run some 1/2" angle aluminum and screw it into the top/bottom of the grill surround, then rivet some aluminum around the hole to mount the lights to. Do the pods weigh about the same as the 40w floods I got? See y'all have me thinking about this instead of work :pccoffee: LALALALA :lalala: I'm not thinking about this any more!!
    Edit: of course they're about the same weight, minus the threaded post but add the flush bezel.
    Iggy[QUOTED] and bski22[OP] like this.
  4. Apr 21, 2017 at 9:46 AM
    uurx
    '12 t|x pro
    :sadviolin::ohsnap:
  5. Apr 22, 2017 at 10:11 AM
    bski22
    bski22 [OP] Shaka Zulu \000/
    Rob
    Toyota
  6. Apr 23, 2017 at 6:26 AM
    bski22
    Rob
    Toyota
  7. Apr 24, 2017 at 7:15 AM
    bski22
    Rob
    Toyota
  8. May 4, 2017 at 5:44 AM
    bski22
    Rob
    Toyota
  9. May 4, 2017 at 2:13 PM
    Bat Taco
    Bat Taco Well-Known Member
    Phong (like Fong except with a Ph)
    Orange County, CA
    2015 DCSB 4X4 Dark Knight Edition
    You wouldn't happen to have pics of these in action or mounted on a bumper?
  10. May 4, 2017 at 2:48 PM
    bski22
    Rob
    Toyota
    @Iggy would
  11. May 4, 2017 at 3:09 PM
    Iggy
    Northern CA
    Check out the build
    Let me see if I can find something. They mount just like a Rigid flush mount, so googling that would give you a pretty good idea.
    bski22[QUOTED][OP] likes this.
  12. May 4, 2017 at 9:04 PM
    Bat Taco
    Orange County, CA
    Plug and play if I decide to mount them as fog lights?
  13. May 5, 2017 at 4:45 AM
    bski22
    Rob
    Toyota
    Yes sir comes with its own switch, fuse, and connectors. I would suggest using the hot leg of the oem wiring to trigger. Connect the ground, neutral and hot leg to battery and presto you're in
  14. Aug 1, 2017 at 12:29 PM
    bski22
    Rob
    Toyota
  15. Aug 23, 2017 at 6:32 PM
    #35
    bski22
    Rob
    Toyota
  16. Sep 5, 2017 at 5:14 PM
    #36
    bski22
    Rob
    Toyota
    Still available
  17. Oct 16, 2017 at 6:38 PM
    #37
    bski22
    Rob
    Toyota
    Still here
  18. Oct 26, 2017 at 3:46 PM
    #38
    bski22
    Rob
    Toyota
    Dropped price
  19. Nov 1, 2017 at 11:43 AM
    #39
    Tacolover1904
    Tacolover1904 Member
    Zach
    2010 gray tacoma
    Do you still have these?
  20. Nov 1, 2017 at 12:29 PM
    #40
    bski22
    Rob
    Toyota
    Yes
Thread Status:
