SOLD-FS: 2002 Tacoma TRD Off-Road Ext Cab 5 Speed MT Red 201k
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by acs118, Apr 9, 2025.
  1. Apr 9, 2025 at 6:13 PM
    acs118
    acs118 [OP] Well-Known Member
    Pittsburgh, PA
    2002 4WD V6 TRD Tacoma
    SOLD
    2002 Toyota Tacoma
    TRD Off-Road 4WD
    5-Speed Manual Transmission
    Radiant Red
    201,XXX Miles
    Has its small knicks and scratches as an old daily driver would however good condition overall, well maintained and kept clean. Runs and shifts very well.
    Pennsylvania Inspection and Emissions thru 1/2026
    New Frame (+ Lower Control Arms) 2017 – Fluid Filmed inside and out every fall since purchase in 2018. Very good condition.
    Michelin Defender LTX 70%+ even tread depth
    Toyota OEM Lower Ball Joints, Left and Right – November 2024, 197,500 miles
    Clutch kit, spark plugs and wires – October 2023, 188, 700 miles
    Water pump, timing belt, alternator belts, thermostat – September 2021, 171,300 miles
    Magnaflow OE spec front and rear catalytic convertors – December 2021, 173,600 miles
    Charcoal Canister, Rollover valve, fuel pump, fuel filler neck, gas gap, purge control valve – 160,000 miles
    Fuel tank, Bilstein 4600s all round, upper ball joints, inner and outer tie roads January 160,000 miles
    Additional maintenance under ownership: Diff and transfer case fluids, muffler, o2 sensors, axle seal, head lights, rear bumper, roll up tonneau cover
    Stack of receipts
    Minor paint chips and scratches typical of older daily driver. Some paint bubbling and rustabove windshield – was there when I bought it, have maintained with small bits of fluid film and hasn’t progressed. EVAP related parts mentioned above related to common EVAP check engine codes – light is still intermittently on and off, currently off. Common ABS light is currently on. Clock rarely works. Hood latch is sticky.
    PM with any questions or requests for additional info or pictures.
    Pittsburgh, PA
    IMG_2597.HEIC.jpg IMG_2598.HEIC.jpg IMG_2605.HEIC.jpg IMG_2599.HEIC.jpg IMG_2600.HEIC.jpg IMG_2601.HEIC.jpg IMG_2602.HEIC.jpg IMG_2603.HEIC.jpg IMG_2604.HEIC.jpg IMG_2639.HEIC.jpg IMG_2662.HEIC.jpg IMG_2596.HEIC.jpg IMG_2592.HEIC.jpg IMG_2595.HEIC.jpg IMG_2611.HEIC.jpg IMG_2615.HEIC.jpg IMG_2620.HEIC.jpg IMG_2624.HEIC.jpg IMG_2625.HEIC.jpg IMG_2629.HEIC.jpg IMG_2638.HEIC.jpg IMG_2643.HEIC.jpg IMG_2642.HEIC.jpg IMG_2637.HEIC.jpg IMG_2641.HEIC.jpg IMG_2647.HEIC.jpg IMG_2648.HEIC.jpg
  2. Apr 11, 2025 at 10:25 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Wish this would’ve come up for sale last year when I was looking. Pretty good price. How are the rocker panels?
  3. Apr 11, 2025 at 11:20 AM
    acs118
    Pittsburgh, PA
    Rocker panels are solid and straight, no issues.
