(SOLD) FUMOTO F-103 quick drain oil valve
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by OhioTaco68, Sep 27, 2019.
Thread Status:
Not open for further replies.
  1. Sep 27, 2019 at 10:51 AM
    OhioTaco68
    OhioTaco68 [OP] John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    BRAND NEW, NEVER USED
    FUMOTO F103
    $21 SHIPPED IN THE USA
    FUMOTO ENGINE OIL DRAIN VALVE
    Fumoto Valve will bring your oil changes to new levels of efficiency. Install the Fumoto Valve and you can drain your engine oil without tools and without mess. Just lift the lever out of its seating and give a quarter turn to open the valve. To close the valve, return the lever to it's original position. The Fumoto Engine Oil Drain Valve is made from corrosion resistant forged brass and stainless steel. The patented design provides a straight flow for efficient drainage and a perfect seal when closed. Frozen drain plugs and stripped threads are eliminated forever. Drawing samples for oil analysis is as easy as one-two-three. Sizes are available for all cars, light trucks, vans, heavy-duty trucks, buses, marine and industrial engines .
    • Tool-Free, One Touch Operation
    • No Messy Hands or Cloths
    • Avoid Contact with Hot Oil
    • No More Stripped Threads or Frozen Drain Plugs
    • Life Time Durability
    HOW TO INSTALL:
    1. Remove the original drain plug from your oil pan and drain oil completely.
    2. Insert Fumoto Valve with a gasket (except for NPT threads). Use a crescent wrench to install the valve. *Do not over tighten it. Make sure Fumoto Valve is closed before refilling oil.
    HOW TO USE:
    • To open, lift the lever completely out of its seating and turn counter-clockwise 90 degrees.
    • To close, return the lever to the original position, making sure the lever is fully seated
    Xx_Evilvirus_xX likes this.
  2. Sep 27, 2019 at 2:41 PM
    OhioTaco68
    Central Ohio
Thread Status:
