SOLD -- Instrument Panel Cover (Lower) 55434-04070-C0
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by TacoMan408, Mar 28, 2022.
  1. Mar 28, 2022 at 4:56 PM
    TacoMan408
    TacoMan408 [OP] Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    Brand New, never installed.
    Located in SF Bay Area (Morgan Hill, CA 95037)
    $100
    ED578142-284F-4112-85D2-3EBB8F1D25A8_1_201_a.jpg D354A244-3C0D-456A-B38F-02A668CB0AF5_1_201_a.jpg EBF4F383-0A50-4ADD-BE32-F5BCA706F655_1_201_a.jpg D5AB89F4-90FF-4E40-988C-4B012F27653E.jpg
  2. Mar 28, 2022 at 5:38 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Interested! Would you happen to know off hand if this carried over to later models like my '21?
    I'll be checking and comparing in the meantime. Got a project that I could carry out on this and do a quick change on my rig.
    PM coming in just a bit....
  3. Mar 28, 2022 at 8:18 PM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    assuming you have your power rear window switch in the middle like my TRD OR does, this will not be a direct swap in for you.
  4. Mar 28, 2022 at 8:28 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    Good point, I didn't catch that in the pic but it's not an issue as that entire portion will get cut out leaving a lip around the circumference to attach the new MeSo 7 switch panel. I'm figuring it would be much easier and a faster change to get the dirty work done and panel mounted and glued in, then do the teardown, exchange it, and slap it back together. If that's the only difference between '16 and '21, this can work.
  5. Mar 28, 2022 at 8:35 PM
    TacoMan408
    CA
    I’m pretty sure the only difference is the middle switch plate. I would imagine all the clips are the same.
  6. Mar 28, 2022 at 11:42 PM
    TacoMan408
    CA
