[SOLD] M.O.R.E. ARB Compressor Mount Colorado
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by TheIncredibleTaco, May 1, 2022.
  1. May 1, 2022 at 3:26 PM
    TheIncredibleTaco
    TheIncredibleTaco [OP] Well-Known Member
    Denver, CO
    2021 TRD OR DCSB
    Exhaust reroute RCI steel full skid plates (front, transfer case, transmission) Front camera (anytime backup camera) RCI rock sliders AC Drip mod OEM locking tailgate Brite box fogster anytime fogs Backwoods adventure mods hi-lite front bumper with Baja designs squadron pros ARB single OBA Fox 2.5 PES DSC 2-3” Wheelers superbumps + ubolt flip kit Deaver stage 1 u402 Cab mount chop+fender trim Rrw RR-7 -12 offset with 315/70r17 5.29 regear ARB front air locker Z precision big cupholder
    MORE ARB Compressor mount 2016+ (see last paragraph)
    Louisville, Colorado
    $120 obo
    Brand new, all instructions and hardware included
    Product page of listed product https://mountainoffroad.com/products/arb-twin-compressor-and-tank-mount-for-toyota-tacoma-gen-3
    Local pickup preferred or will ship for no added cost (shipping price taken into consideration for obo). Willing to meet halfway within reason and help test fit if you’re concerned about fitment issues
    Selling a MORE ARB compressor mount for 2016+ Tacomas. Selling because if you have “50 State Emissions” then it doesn’t fit so it doesn’t fit my truck but is absolutely brand new. Past 30 day return period
  2. May 1, 2022 at 5:23 PM
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    Aren't all 3rd gens 50 state emissions vehicles? What would be blocking this mount?
    Benny blanco and SR-71A like this.
  3. May 1, 2022 at 6:11 PM
    TheIncredibleTaco
    Denver, CO
    2021 TRD OR DCSB
    That’s what I thought too but the mention of it not fitting by MORE is what led me to believe that was the difference. See the note on their website that’s the only thing they note that makes it not fit
    there’s an abs module (? It’s a puck likely could be bent away) on the passenger side of the mount and on the other side there’s another tube that doesn’t exist on models I see in YouTube videos. See my truck below
    2:59 here https://youtu.be/_FXFKxtV9FU
    LLOD runs this in a 2016 so guessing 2020 is when they changed some things since the truck on unchanged basically the rest of the years
    this is the 2016 engine bay with a different hose setup on the driver side of this empty space
    BlarBlarjosh[QUOTED] likes this.
  4. May 1, 2022 at 6:14 PM
    BlarBlarjosh
    Josh
    Southern California
    Looks like I'd have the same issue. Thanks for the detailed response. Glws
  5. May 2, 2022 at 3:35 AM
    SpyGoat
    SpyGoat I miss you Hobbs
    Tom
    Long Island, NY
    2021 TRD Off Road MGM DCSB, 2025 Land Cruiser
    A bunch..and no build thread!
    Same reason I did not go with this mount. I wanted to, but it wouldn't work on my 21 OR.
    GLWS!
  6. May 2, 2022 at 11:35 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    My 2019 had those two items. Install wasn't a problem. The main thing to look our for is the ABS module in that location. OffRoad and Pro models have the electronic brake booster located on the driver side. :thumbsup:
  7. May 2, 2022 at 11:59 AM
    TheIncredibleTaco
    Denver, CO
    2021 TRD OR DCSB
    see you don’t have the rubber hose on the driver side in your second photo. For you it’s metal and takes a more parallel route to the metal hose above it with the T fitting that looks capped
  8. May 2, 2022 at 12:12 PM
    RyanDCLB
    4/19 DCLBOR
    Got it. The corner of the MORE bracket is about 1.5" from the small pipe, and 5.25" from the firewall if that helps, but you may have already tried fitting it. :confused:
  9. May 2, 2022 at 1:15 PM
    TheIncredibleTaco
    Denver, CO
    2021 TRD OR DCSB
    Well maybe I should ask this. You had the vertical sides going left to right of the truck correct and not front to back?
    this is how it appeared to fit to the mounting holes I had just that one piece nothing on it. It was simultaneously hitting the rubber hose and ABS module with the two sides. I didn’t think there was any way to force it in there. I think the angles are messing with you as the small hose is like underneath the other metal hose on your truck where mine comes out towards the passenger a bit. It’s such a short hose with metal on both ends that makes it impossible to bend at all
  10. May 2, 2022 at 2:05 PM
    RyanDCLB
    4/19 DCLBOR
    Yup, left to right. Here's another writeup, but he doesn't show a good picture of the driver's side.
    Bummer, it sounds like MORE will need to redesign this part if they want it to work with the newer trucks. :notsure:
  11. May 2, 2022 at 2:41 PM
    TheIncredibleTaco
    Denver, CO
    2021 TRD OR DCSB
    Yea I was hoping to have the space to add storage or something underneath the compressor. Was still undecided since air tools aren’t needed with batteries these days.
    i have a technical inquiry with them to stop advertising it’s compatible for 2020+ trucks and maybe I’ll find my way into letting them measure my engine bay and giving me an updated prototype. We only live like 4 hours away. :fingerscrossed:
    would be easy to do just make a cutout right side so you have legs instead of a solid wall. It’s not worth my time re-engineering it. Hoping someone else could use it and help me recoup most of the cost.
    RyanDCLB likes this.
  12. May 2, 2022 at 11:52 PM
    TheIncredibleTaco
    Denver, CO
    2021 TRD OR DCSB
    Remembered this video of a 2020 and his has the metal hose so the rubber hose that is the main culprit must have started in 2021. So I’d imagine 2020s could fit it easily
    https://youtu.be/cI1SRj6ubHM
    If anyone is local I’m willing to help test fit it before purchasing.
  13. May 6, 2022 at 5:05 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Is that what that puck thing is? An ABS module of sorts? I thought it was like another horn and was bending it as I was making my own mount for my Viair compressor last weekend LOL.
  14. May 6, 2022 at 6:20 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    its the horn for the alarm. Nothing to do with ABS. The ABS module that would be there for any model except the OR or Pro is large ABS module that is very hard to miss.
  15. May 26, 2022 at 12:09 PM
    Robb_D
    Robb_D Well-Known Member
    Robb
    FoCo
    2016 BBP Tacoma DCSB TRDOR
    285/70 17 BFG AT KO2
    Might be willing to help lighten your load. I'll let you know later this evening.
    TheIncredibleTaco[OP] likes this.
  16. Jul 13, 2022 at 8:49 AM
    TheIncredibleTaco
    Denver, CO
    2021 TRD OR DCSB
  17. Aug 9, 2022 at 12:15 AM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    You’re absolutely correct. I found this same issue with my 2020.
    However, I removed that puck thing, which I thought might be a horn and shoved it was down low out of the way and I had to drill new holes because it wouldn’t line up because of the blockages. I managed to get two of the 3 bolts in with the new holes but since the fit is so tight, it’s not moving anyways. But I fit the air tank, dual compressor and a custom set up with check valves all connected to the air tank. It’s such a tight fit I can’t believe it worked. But it does.
