SOLD: Meso Total Tail Stage 1
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by BLtheP, Oct 26, 2022.
Thread Status:
Not open for further replies.
  1. Oct 26, 2022 at 4:19 PM
    BLtheP
    BLtheP [OP] Constantly Tinkering Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    $110 shipped.
    Installed end of May 2022. No issues whatsoever. Just went a different route so I no longer need.
    Includes some optional resistor splitters (the Y-shaped piece threaded onto the switchback bulb harness). That Y piece gives you the ability to add on a 15 ohm resistor from VLEDS or similar if you so choose. The purpose to doing so is to eliminate turn signal hyperflash when in reverse (aka parallel parking). If you don’t care about that then you can simply remove the Y’s and leave them off.
    Located in Plano, TX if wanting to pick up.
  2. Oct 26, 2022 at 6:10 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Great deal! These should go quickly
    BLtheP[OP] likes this.
  3. Oct 26, 2022 at 7:27 PM
    timmy_7x
    timmy_7x Well-Known Member
    EB
    Long Beach, CA
    19 Tacoma SR5
    tempting :rolleyes:
  4. Nov 4, 2022 at 4:33 PM
    BLtheP
    Plano, TX
    Bump and lowered price.
  5. Nov 4, 2022 at 4:58 PM
    SmileyGuy
    SmileyGuy Well-Known Member
    Darrin
    Nova Scotia
    20 Tacoma Off Road Voodoo Blue DC SB TRD Premium CAN
    Good price! Hard to get as they sell out fast. I have a set and they are a lot brighter. I have 2020 TRD OR DC SB in Canada and did not need resistors for hyperflashing.
  6. Nov 4, 2022 at 5:10 PM
    BLtheP
    Plano, TX
    Thanks. Nobody really “needs” the resistors on a TRD model; the only situation with any hyperflashing is when in reverse and using the turn signal (aka the parallel parking situation). For me the only reason I wanted the resistors was because they’re super cheap, plug and play, and because in the back of my head I knew they would HF in that specific situation which I never really even end up in. So for $15 I threw them in the cart when I was buying some other stuff from VLEDS.
  7. Nov 4, 2022 at 5:24 PM
    SmileyGuy
    Darrin
    Nova Scotia
    Just tried the reverse signal combo, and the left signal did hyperflash, right signal no issue. Haven't paralleled parked on left side of road with the truck lol! Odd only on one side? Still a good deal with resistors!
  8. Nov 4, 2022 at 5:28 PM
    BLtheP
    Plano, TX
    Weird for sure. I’m pretty sure mine does it on either side. Did you have the truck running when you did it? That will affect it due to alternator voltage.
  9. Nov 4, 2022 at 5:49 PM
    SmileyGuy
    Darrin
    Nova Scotia
    Yes I started the vehicle and tried switching in and out of reverse trying each side with left first then right and right first then left.
  10. Nov 6, 2022 at 6:57 AM
    BLtheP
    Plano, TX
    Sold.
Thread Status:
