Sold- Navigation Map Update 0E184
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by zinger, Jun 2, 2018.
  1. Jun 2, 2018 at 10:17 AM
    zinger
    zinger [OP] Well-Known Member
    2016 Silver Sky Tacoma SR5
    For sale is a Navigation Map Update 86271-0E184 SD Card. Very simple to update, with the engine off just pop out your old SD Card and install this one. Will sell for $48 including shipping. Payment by PayPal only please. Let me know if you have any questions.
  2. Jun 2, 2018 at 10:20 AM
    Guapo Taco
    Guapo Taco Yut life!
    SoCal
    '17 Taco OR 4x4 Tortilla Tansand
    Serious question, forgive my ignorance. Why would one need this, exactly? Update to roads or software?
  3. Jun 2, 2018 at 10:26 AM
    zinger
    It's a map (roads, etc.) update if you have the Entune Navigation system. Toyota usually comes out with a new map update once a year and will cost ~$170 at the dealer.
    Guapo Taco likes this.
  4. Jun 2, 2018 at 10:36 AM
    robstitzer
    robstitzer Well-Known Member
    Rob
    2018 Tacoma TRD Pro - Calvary Blue
    How do we know if we need this or not?
    corgimas likes this.
  5. Jun 2, 2018 at 10:42 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    When you’re using your nav and you come across a dead end road that it’s taken you down. With as much construction that goes on yearly it needs updates. My 4Runner is a year old and already I’ve come across at least 1/2 dozen instances where construction has completely changed the roads or layout of interchanges.
  6. Jun 2, 2018 at 10:44 AM
    zinger
    If you have a 2018 Tacoma with Navigation you should already have this or a more recent update. Easiest way to check is to remove your SD Card and check the number on the back, if you have 0E184 or 0E185 then you won't need this update. This update should help those with a 2016 or older Tacoma and the (0E183 or lower) SD Card.
  7. Jun 2, 2018 at 1:42 PM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    "hypothetically" asking for a friend can you make a copy of this if say someone wanted to use it in two vehicles?
  8. Jun 2, 2018 at 2:34 PM
    zinger
    Not to my knowledge, Toyota uses some type of security that requires their SD card. This was discussed on a thread in the 3rd Gen forum, several tried it but with no success.
  9. Jun 2, 2018 at 2:43 PM
    XrunnerCO
    XrunnerCO Well-Known Member
    Colorado
    2016 Tacoma TRD OR - DCSB
    No, IIRC that can't be done without some CID/serial number manipulation per here.
  10. Jun 2, 2018 at 3:51 PM
    robstitzer
    Rob
    I'm running 0E185. Thanks for the heads up.
  11. Jun 2, 2018 at 6:40 PM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Also hypothetically asking...
    Can you update then remove the sd card and resell it? Ya know, pass it around?
  12. Jun 2, 2018 at 6:51 PM
    zinger
    No, the SD Card needs to be installed for Navigation to work.
  13. Jun 3, 2018 at 6:55 AM
    corgimas
    corgimas Well-Known Member
    rob
    North Shore of Massa-who-setts
    0rangeSeventeenShortSportStick
    uhhhh....dog fur?
    Any version description online that lists the changes between files? Wonder if there are certain regions that would benefit from this than others.
  14. Jun 3, 2018 at 1:30 PM
    zinger
    I've never seen anything that shows what the changes are from one map update to the next, probably too numerous to list. I've had stand alone Navigation units (TomTom, Garmin) and don't recall them listing the changes in their updates either.
