SOLD - New leaf pack center pins
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mattygaff, Apr 24, 2017.
  1. Apr 24, 2017 at 4:52 PM
    mattygaff
    mattygaff [OP] Beat em
    SOLD
    Didn't end up needing these - bought these from HeadStrong. Here's what their website reads:
    These center pins are used as a replacement when adding an add-a-leaf or axle shim to an existing leaf pack. Pins come in a pair and measure 3/8" x 4".
    Leaf Pack Center Pins (PAIR) - CB380400FT
    SKU: CB380400FT
    Quantity: 1
    Total: $19.99
    http://www.headstrongoffroad.com/store/p121/Leaf_Pack_Center_Pins_(PAIR)_-_CB380400FT.html
    I'll sell them for $15 shipped. You save $5, I unload them, and the pins get another chance to do their job. Everyone wins! Please PM me for PayPal. Thanks.
  2. Jun 30, 2017 at 4:33 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Are these 4" total length or 4" of thread?
  3. Jun 30, 2017 at 5:12 PM
    mattygaff
    4" of thread
  4. Jun 30, 2017 at 5:13 PM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
  5. Jun 30, 2017 at 5:29 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Im not sure these are needed for Dakars
  6. Jun 30, 2017 at 5:35 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    If you are breaking down your pack to add a Leaf or installing a new pack you might need these I think. The bolt in your pack was likely cut just above the nut and will not be long enough unless removing an overload when adding the AAL. I might want em, interested in hearing if they work with dakars +aal. I'm probably going to have the shop that drilled my dakars and added isolators do the same to the d29xl, and have them add the leaf while I'm there tho... they only charge a few buck for these, they specialize in building custom packs and commercial suspensions.
  7. Jun 30, 2017 at 5:40 PM
    fatfurious2
    David
    Ashburn, VA
    @HeadStrong Off-Road are these needed when adding D29xl? I never modified the original pin when I installed the Dakars a year ago.
    They are probably needed when adding AAL to stock leafs
    HeadStrong Off-Road likes this.
  8. Jun 30, 2017 at 5:47 PM
    IronPeak
    AuggieX
    Back to Back
    Is your stock bump on top of it? you could probably look and see if there is 5/8th" extra clean threads available
  9. Jun 30, 2017 at 5:51 PM
    fatfurious2
    David
    Ashburn, VA
    No, i have Wheelers Super bumps
    IronPeak[QUOTED] likes this.
  10. Jul 5, 2017 at 6:00 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Sorry it took me awhile to get back to you, I am getting caught up from the holiday. The center pins should be long enough to accommodate the aal providing you didn't trim them to fit the bumps.
    fatfurious2[QUOTED] likes this.
