Sold!! NIB (opened) AEM Water/Methanol Injection Kit w/ Internal MAP Sensor 30-3302
Discussion in 'Buy / Sell / Trade' started by DesertRatliff, Apr 1, 2019.
Thread Status:
Not open for further replies.
  1. Apr 1, 2019 at 8:06 AM
    DesertRatliff
    DesertRatliff [OP] Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    *****SOLD***********
    I planned on installing and tuning my 'charged 5VZ-FE with this kit but am getting rid of the truck and need this to go. New in box, although I did open it at the time to read the install instructions but never installed it. Universal, tankless application that lets you tap into your washer fluid reservoir for a clean install.
    Here's the manufacturers info. Cheapest I could find it for is $388 on Amazon.
    Asking $325 PayPal F&F including shipping to you in the lower 48.
    AEM (30-3302) V2 Water/Methanol Injection Kit with Internal MAP Sensor
    • Boost Dependent controller features on-board MAP sensor with large adjustment knobs, integrated plug for harness connection, integrated fuse, covered status light and test button for enhanced splash resistance and mounting tabs
    • Wiring harness is terminated with a positive-lock connector on one end with color-coded wires to ease installation, power and ground wires for the pump and additional wire for optional on/off fluid solenoid
    • Pump does not cycle on/off and provides quiet, smooth operation; it features robust construction including integral hose fittings, EPDM seals and a Santoprene diaphragm that provides consistent and reliable fluid delivery
    • Precision-machined billet-aluminum injector with integral check valve; three interchangeable injector nozzles to cover a wide variety of HP levels (250cc/min, 500cc/min and 1,000cc/min); tank-less 35 PSI Boost dependent gas water/methanol system
  2. Apr 7, 2019 at 10:22 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Too bad I’m not in Durango right now. I’m assuming you could add another tank and not use the washer reservoir.
  3. Apr 7, 2019 at 9:05 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Of course! Any tank, including just using a washer fluid bottle. Lol! Thanks for the interest.
  4. Apr 11, 2019 at 8:39 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    SOLD please delete. Thanks
Thread Status:
