(SOLD OUT) Discounted Price on TRD Pro Suspension Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SighOn, Feb 15, 2018.
  1. Mar 30, 2019 at 3:53 PM
    #2121
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I used the Headstrong 1/4 inch spacer.
  2. Mar 30, 2019 at 4:32 PM
    #2122
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I used the 1/4 top plate spacer which gives you approx. 1/2 inch lift.
    Thinking about swapping it for the Baja 1 inch spring seat spacer
    Georgeth1022 and NorthCountryTRD like this.
  3. Mar 30, 2019 at 5:17 PM
    #2123
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
    I did the Headstrong 1/4" spacers but I'm planning on taking them out. It's fine without anything in the bed, but with all the camping gear in the back, it gets a bit of a squatty rear.
  4. Mar 30, 2019 at 5:44 PM
    #2124
    BigE taco
    BigE taco Well-Known Member
    Eric
    Sarasota, FL
    19 TRDOR DCSB
    19 TRD OR DCSB Cement Falken Wildpeak AT3W 275/70/17 TRD Sema Pro TRD Pro Fox Shocks with Wescott lift Icon AAL progressive leaf pack Freedom Off Road UCA ECGS Bushing SSO slimline hybrid bumper in Zeak 12000lb winch Rigidhorse 20" led combo light bar Taco Garage "TRD Pro" Grill RC TuningFL OTT mild/medium tune Rav4 blindspot mirrors Seat Jackers driver seat Tri fold hard bed cover...came with truck Magnus side steps...came with truck, don't like them Tufskinz Inferno various interior items Auxbeam led low beam headlights "TRD PRO" style fog lights "TRD PRO" style skid plate Meso Custom Total Tail Stg 1 OEMAudio speakers Multi Ch amp, Sub amp and Toyota Gain Knob 09 TRD OR DCSB....sold Falken wildpeak at3w 265/75/16 TRD Pro Kit with Headstrong Prog. AAL TRD Seat Covers TRD Drop filter TRD Exhaust Led headlights and fogs Hidden light bar Led interior lights Pioneer Avic-F900BT Kicker speakers swap Kicker Solo 10" Kicker kx400.1 misc..$$$ spend on unnecessary things AVS in channel visors Trifecta tri fold Toyota Bed Extender Toyota Skid plate
    Hi guys need to ask a question. I installed a pro kit on my prerunner. I know overkill but mainly because I found cheap deal on a used set instead of using 5100's.
    Installed it today and its nose high... a lot. 23" frt center hub and 21" rear center hub. I thought it would level out like everyone was stating but I think I forgot to account my missing frt diff, axles and transfer case. Is this why I am so bro lean right now?
  5. Mar 30, 2019 at 6:25 PM
    #2125
    dome
    Joel
    California
    I test drove a couple of Baja TX Pros when I was shopping around and they both had the bro lean going on. I think this setup as it is stock just levels the truck and after the rear wears, the lean starts showing more. Keeping this in mind, I added the 3 leaf AAL when I did this kit. I'm sure the weight you're missing up front also contributes to more bro lean.
  6. Mar 30, 2019 at 7:02 PM
    #2126
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Thank you for your responses, I appreciate it.
    Taco-Grinder[QUOTED] likes this.
  7. Mar 30, 2019 at 7:02 PM
    #2127
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    I didnt use one ,and ended up not needing a spacer,truck is level.
  8. Mar 30, 2019 at 8:39 PM
    #2128
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I installed a fresh OEM leaf pack with an AAL when I put the kit in and after a year it's sagging so it's now level. Had a nice 2" rake before.
  9. Mar 31, 2019 at 5:28 PM
    #2129
    litolapid
    litolapid Well-Known Member
    Fayetteville, NC
    2011 MGM TRD OFF-ROAD DCSB
    What Brand AAL do you have?
  10. Mar 31, 2019 at 5:50 PM
    #2130
    Sharpish
    Brian
    Trail Gear maybe? I can't remember. It's a single AAL that you install into the pack. I did the entire suspension for almost exactly $1000 Canadian in parts ($750 US) and the labor was done by me. I am a very cheap person.
    If I could do it again I would just get a Dakar pack for the rear.
  11. Apr 2, 2019 at 1:01 PM
    #2131
    MancoFett
    MancoFett Active Member
    CA
    2007 TRD OR Access Cab Superwhite
    Still loving this set up, but getting a good alignment has been a pain. I’m in spec, but not the best numbers. Installing new UCAs this weekend.
    ALL, what ideal alignment specs have you been shooting for with this kit?
    I am leaning towards 0 or slight negative camber, ~2.5 caster
  12. May 3, 2019 at 2:11 PM
    #2132
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Planning on installing my kit soon, been sitting on it for a while. How long did you guys let everything settle prior to getting an alignment? Is it necessary to wait
  13. May 3, 2019 at 3:05 PM
    #2133
    MancoFett
    CA
    Ideally, I would do alignment with install and then again after a reasonable break-in period. Definitely do one with or after install for your safety.
    Also, following up on my above post, I got SPC UCAs and WOW it made such a huge difference in getting good alignment stats/ride quality. Don’t cheap out like I did.
    Important to acknowledge i may have gotten more lift than others report, but upgrading from stock UCAs was a night and day difference and I’m not OCD about ride quality (it’s a truck!)
  14. May 4, 2019 at 7:39 AM
    #2134
    NorthCountryTRD
    NorthCountryTRD Well-Known Member
    Patrick
    New Hampshire
    2015 Tacoma TRD Off Road V6 Manual
    Current Mods: - Locking Lug Nuts - Weather Tech floor Liners - N-Fab light bar - 32” Led Light bar - TRD skid plate - Leer Cap (Pyrite Mica) - Rigid TSM-22 Tow Strap Shackle Mount - Rigid Orange Shackle - @ACEkraut License plate bracket - Flashwolves LED reverse bulbs - TRD Stainless Cat Back - AFE Pro Dry S drop in filter - Glove box organizer - Center Console organizer - Bed Stiffeners - Color match grille - Custom Car Grills Perf SS Mesh flat black - Thule Cap roof rails - TRD PRO Suspension - Wheelers 2" Add a Leaf - HS 1/4 inch strut spacers - SCS Ray 10's in Brushed Copper - Cooper Maxx St's 275's - Under hood Led Light Kit Future Mods (as of right now): - 20inch LED Bar (Caliraised,Rigid, Baja) - 32inch LED Bar (Caliraised,Rigid,Baja) - LED Pods Side Projecting (Caliraised, Rigid) - Toyota Bed Matt - Quick fist Axe and Shovel mounts in Truck Bed - Cap mounted Awning - 100% No Drill Bolt on sliders - Wet Oak Seat covers (All black with TRD in them) - VooDoo Bed Bars/Basket that works under a cap
    As stated above get an alignment right after your lift is installed. The place I went to warrantied my alignment for 3 months. After 2 1/2-3 mouths I went back and they tweaked it. At that point everything seemed to have settle. I ended up get 2 alignments for the price of one.
    FastEddy59 likes this.
  15. May 4, 2019 at 8:15 AM
    #2135
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Pretty Decent for the Shop to play ball like that. Sounds like they strive to get it right & keep customers not like the "good as we can get it", then punt you out the door.
    LarryDangerfield likes this.
  16. May 4, 2019 at 8:25 AM
    #2136
    NorthCountryTRD
    Patrick
    New Hampshire
    They were great I explained to the manager I just put a lift in and he hooked me up. Town Fair Tire is where I went
    FastEddy59[QUOTED] likes this.
  17. May 4, 2019 at 8:41 AM
    #2137
    FastEddy59
    Eddie
    I got it good. Can't complain. I use a rural shop so I show up around lunchtime, give the Shop guy $20 & tell 'em to go for lunch. When he returns i'm usually done so no bitchin if it got done right as i'm the one doin' it.
  18. May 4, 2019 at 8:51 AM
    #2138
    NorthCountryTRD
    Patrick
    New Hampshire
    That's awesome !, I have access to a lift but dont know anyone with an alignment machine.
  19. May 4, 2019 at 10:55 AM
    #2139
    Ares
    Ares Well-Known Member
    Darek
    Hamilton , ON
    2015 LTD DCLB
    Just a quick question for those that have been rocking this suspension for a while...is the taco lean still present? I'm about to install mine and wondering if i should add a 1/4" spacer on the driver side.
  20. May 4, 2019 at 10:59 AM
    #2140
    FastEddy59
    Eddie
    It all depends on the actual Truck. The Kit somewhat compensates for that with drivers & passengers sides bein' different. Drive it. wait for things to settle, then decide for yourself. Some guys need it, some don't. Sorry, not much of an answer.
