(SOLD OUT) Discounted Price on TRD Pro Suspension Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SighOn, Feb 15, 2018.
  1. Jul 20, 2019 at 7:22 PM
    #2161
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Except that the kits are not made anymore,so your point is mute.
  2. Jul 20, 2019 at 7:30 PM
    #2162
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    Have you seen this https://www.tacomaworld.com/threads/fs-2015-trd-pro-shocks.573360/
  3. Jul 20, 2019 at 7:38 PM
    #2163
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I like mine for the sale price I paid a lot. I got the kit, new take off TSB spring and an add a leaf and installed it all myself for around $1100 CAD. ($850 USD)
    But when they wear out in a few years it's Kings and Dakars all day long.
    E-Paz 732NJ and backcountryj like this.
  4. Jul 20, 2019 at 7:40 PM
    #2164
    lynlan1819
    Tacoma
    Lifted
  5. Jul 20, 2019 at 7:52 PM
    #2165
    STAGE 2
    STAGE 2 Well-Known Member
  6. Jul 20, 2019 at 7:52 PM
    #2166
    STAGE 2
    The kits aren’t made but the individual parts are which is why I was asking my original question if anyone had a part number list for the individual components.
  7. Jul 21, 2019 at 7:21 AM
    #2167
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    That's all the Pro "kit" was; front & rear shocks and a rear brake line spacer. The front shocks came pre-assembled, and rear shocks came with reservoir mounts.
    There's no special swaybar, leaf springs, control arms or anything like that in the Pro suspension. The Baja kit did come with shorter front bumpstops, but they're just 2wd/5-lug standard issue bumpstops. Pro "kits" didn't even get different bumpstops.
    I love my Pro kit, but if it wasn't for Toyota clearance sale I would've bought the non-TRD branded 6112/5160.
    Good luck in your searching.
  8. Jul 21, 2019 at 7:22 AM
    #2168
    blu92in99
    Justin
    Elk Grove, Ca
    P/N list is included in the installation instructions; available for free online from Toyota. There's links to that all over the place (including in this very thread), assuming your Google-Fu isn't weak.
  9. Jul 21, 2019 at 7:27 AM
    #2169
    Taco-Grinder
    Dan
    Fond du Lac, WI
    The price was the only reason I got the Pro kit. Plus I was able to get a 3 leaf progressive pack new in box for only $100.00. With all that savings the hit I took replacing LCA bushings didn't feel so bad.
  10. Jul 21, 2019 at 10:48 AM
    #2170
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
    IA Mike likes this.
  11. Jul 22, 2019 at 10:22 AM
    #2171
    STAGE 2
  12. Jul 22, 2019 at 11:06 PM
    #2172
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    I have a set of Baja's im interested In selling
  13. Jul 22, 2019 at 11:08 PM
    #2173
    Georgeth1022
    Shaun
    West Hills CA
    Too many to list
    I have a gently used set for sale
  14. Jul 23, 2019 at 5:16 PM
    #2174
    STAGE 2
  15. Jul 23, 2019 at 6:47 PM
    #2175
    dome
    Joel
    California
  16. Jul 23, 2019 at 7:07 PM
    #2176
    lynlan1819
    Tacoma
    Lifted
    Its a $1000.00 right now which is cheap,for a kit considering some guys pay $4000.00 on up for Fox or Kings.If someone wanted a kit as bad as Stage2 says he wants one,you would think they would grab it.
  17. Jul 23, 2019 at 7:43 PM
    #2177
    STAGE 2
    If it was a complete kit and undamaged I would, but I’ve played the broken part game before and I’m not interested in doing it again.
  18. Dec 16, 2019 at 6:44 AM
    #2178
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Going to get my alignment done soon. What numbers should I be aiming for with caster with this kit? Right now I'm on 265/70r16 and plan on bumping up to 265/75r16. Would OEM specs be fine?
  19. Dec 16, 2019 at 8:38 AM
    #2179
    Sharpish
    Brian
    Aim for 2-2.5. I told the tech as high as possible while keeping camber close to spec
  20. Dec 30, 2019 at 9:51 AM
    #2180
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    Thanks all, getting my alingment done this week.
    What are you all doing to combat taco lean with these kits? When I installed it I had my OEM leafs and everything was perfectly level. I just recently switched to Deaver U402 from Dakars and both had about 0.75" of taco lean with a full tank. Should I run a 1/4" spacer up front or a 0.5" block above my rear axle even though the TRD Pro suspension is supposed to accommodate for this?
