(SOLD OUT) Discounted Price on TRD Pro Suspension Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SighOn, Feb 15, 2018.
  1. Feb 18, 2018 at 5:27 PM
    #321
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    That looks totally awesome!
  2. Feb 18, 2018 at 5:27 PM
    #322
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
    Yup, to level it out a bit more after the 3 leaf + overload.
    The logic was, the kit would lift the front 1.75", and I didn't want a bro lean. So then I would add the 3 leaf to bring the rear up too, but I do still plan to haul stuff once in a while so I wanted to leave the overload, which would mean that the rear would go up 2". The 1/4" spacers up front were brought in so that it would be a close to 2" lift all around after it was all done (in theory at least, the spacers probably bring the front to shy of 2.25" of total lift).
    sioux[QUOTED] likes this.
  3. Feb 18, 2018 at 5:35 PM
    #323
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    Ok, so it sounds like my plans are about right. I tow, so I want near the factory rake. No spacers + overload should get me there.
  4. Feb 18, 2018 at 5:41 PM
    #324
    Greg3492
    Greg3492 Well-Known Member
    Leadville, CO
    2012 White Access Cab TRD Off Road
    I have a shell, sleep platform, tools and dog platform on back seats. I estimate that's about 200ish lbs maybe more. I'm doing aal w/overload and no front spacers. Right now it sits 1/2" high in back on stock suspension, I want more rake I don't want mine level.
    Jared8907 and sioux like this.
  5. Feb 18, 2018 at 5:55 PM
    #325
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    The 3 leaf aal with overload removed is 1.5" lift? Correct?
    How much lift with the overload left in place?
  6. Feb 18, 2018 at 5:57 PM
    #326
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I'm looking to have like 1inch rake max
    1.5 no overload, about 2 with it
    NMTrailRider[QUOTED] and dome like this.
  7. Feb 18, 2018 at 5:57 PM
    #327
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I did the 3 leaf with overload in and got 2" 2011 OR dc
  8. Feb 18, 2018 at 6:00 PM
    #328
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    Looks hot. Just curious, why the 1/4" spacers up front?
  9. Feb 18, 2018 at 6:02 PM
    #329
    BWilley
    Brian
    Seattle
    Good to know, thanks for the hope.
  10. Feb 18, 2018 at 6:03 PM
    #330
    BWilley
    Brian
    Seattle
    Sorry just saw the answer above...
  11. Feb 18, 2018 at 6:04 PM
    #331
    dome
    Joel
    California
    :thumbsup:
  12. Feb 18, 2018 at 6:07 PM
    #332
    BWilley
    Brian
    Seattle
    Yeah looks pretty dang level, you might get a little bro lean with a load huh.
    I think I'm going no spacers, triple leaf in back with overload. I have an aluminum shell on mine and carry stuff fairly often.
    sioux likes this.
  13. Feb 18, 2018 at 6:08 PM
    #333
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Heres a photo of @2004TacoBill rig, progressive aal, no overload, and a 1/2inch top spacer. Might help someone out
  14. Feb 18, 2018 at 6:12 PM
    #334
    dome
    Joel
    California
    I'm hoping the AAL will keep the sag minimal thanks to a firmer spring, but yea if it gets out of hand and the bro lean is crazy when hauling gear, I'll probably pull the spacers out -- fortunately the fronts were super easy compared to the AAL!
    BWilley[QUOTED] likes this.
  15. Feb 18, 2018 at 6:19 PM
    #335
    BWilley
    Brian
    Seattle
    Yeah man it sounds like you only want to mess with the rear one time. Nice to know the fronts are easy. Sure is some eye candy under the fenders.
  16. Feb 18, 2018 at 6:23 PM
    #336
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
    +1
  17. Feb 18, 2018 at 6:23 PM
    #337
    dome
    Joel
    California
    Honestly, the kit by itself isn't a bad install. I'm not too experienced with mechanical stuff outside of the usual oil changes, brakes, etc. and I thought the TRD kit stuff wasn't too bad after my dad walked me through what I needed to do. Rears shocks were less work than the fronts just cause there's a lot less to disassemble to get them out/in, but leafs... Different story.
  18. Feb 18, 2018 at 6:25 PM
    #338
    Guat
    Guat Well-Known Member
    The Big NC
    Will someone explain "the rake"? I'm unfamiliar with the term, thanks.
  19. Feb 18, 2018 at 6:29 PM
    #339
    BWilley
    Brian
    Seattle
    The height difference between the front of the truck and the rear. Most people here refer to a lower back end as "bro lean". Most here like it level or the rear a little higher than the front (rake).
  20. Feb 18, 2018 at 6:30 PM
    #340
    BWilley
    Brian
    Seattle
    You want a little rake so that when you load up the bed a bit it doesn't go all bro on you.
    sioux and dome like this.
