(SOLD OUT) Discounted Price on TRD Pro Suspension Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SighOn, Feb 15, 2018.
  1. Feb 20, 2018 at 12:19 PM
    #481
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Received my shipping notification today! Cant wait to install!
  2. Feb 20, 2018 at 12:20 PM
    #482
    MattDaddy
    MattDaddy Well-Known Member
    Matthew
    So-Cal
    2015 TRD OR AC 4x4 6MT
    I’m curious about adding the 1/4” spacers. Is that just to get additional 1/4” lift? Would it be easy enough to move the passenger side ring to get the extra 1/4”, and then just put one spacer on the driver side? Maybe not with the effort, but was just curious.
  3. Feb 20, 2018 at 12:24 PM
    #483
    vertrx7
    vertrx7 Well-Known Member
    Rolf
    Just received tracking as well. Ordered last Friday. Was told that it would be 3-5 days for them to come in from Toyota to OEM and here we are!
  4. Feb 20, 2018 at 12:25 PM
    #484
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    A 1/4” spacer will give an extra ~1/2” lift.
    Both mentioned approaches will produce similar results. The spacer on each side is just the easier method.
    MattDaddy[QUOTED] likes this.
  5. Feb 20, 2018 at 12:38 PM
    #485
    Stanky taco
    Stanky taco Well-Known Member
    Auburn
    16 Tundra 1794 CM / 11 FJC / 19 GX460 / prev 13 TACO DCSB OR
    will the 1/4 spacer fit? measuring the studs its pretty damn close
  6. Feb 20, 2018 at 12:43 PM
    #486
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
    It fit fine for me, sure there wasn't a ton of stud sticking out the other side of the nut as without out, but there was still enough that I felt good about it.
  7. Feb 20, 2018 at 12:47 PM
    #487
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    FOR THOSE THAT ORDERED AND STILL WAITING FROM OEMPARTSWORLD:
    I posted this on the 3rd gen section, but here you go:
    I was able to get hold of someone on the phone from OEMPARTSWORLD after being on hold for 2-3 hrs. I have confirmed that orders will be fulfilled. They had 15 sets arrived today (the latest confirmation I heard is someone that ordered Saturday morning). There will be another 25 sets arriving later this week (guaranteed since they said it’s already being shipped from Toyota to them). There was around 20 orders they had to fill when I called, so I guess 5-10 orders were not filled today since they only received 15.
    BWilley and AFPhi404 like this.
  8. Feb 20, 2018 at 1:26 PM
    #488
    Taco TRQ
    Taco TRQ Well-Known Member
    TuRDTaco
    PSA: If you bought these, they should work nicely with Dakar leafs. The Dakar/OME leaf springs were intended to work together with the OME Nitrocharger 60091 shocks. The Nitrochargers are 14.17" compressed and 23.93" extended. No mention of non-oem bumpstops or brake lines with OME kits. The 5160's are 14.22" compressed and 24.06" extended. I'm betting there is more than a 0.05" margin on those Nitrochargers, if one is truly paranoid, stick some pennies (0.058" thickness, dimes will work too, but cost 10 times as much :) ) under your bumpstops :). Confirmed on the TRD Baja/Pro owners thread with stock bump stops and lines; however people do comment brake lines, while trouble-free look a bit unnerving under hard articulation.
    TACOVRD likes this.
  9. Feb 20, 2018 at 1:34 PM
    #489
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    How much better are these over BILSTEIN 5100’s? Is it worth replacing my BILSTEINS?
  10. Feb 20, 2018 at 1:40 PM
    #490
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    Based off just the size, holding them and then my 5100's, they should be a good upgrade. Its a pretty substantial difference in build, but i'm not running them yet to compare. I got some other things to acquire before i do. I dont like my 5100's set at 1.75. Maybe they wouldn't be so bad if i had set them at .85
  11. Feb 20, 2018 at 2:44 PM
    #491
    007WillyWoo
    007WillyWoo Well-Known Member
    TJ
    2012 DCSB TRD OffRoad
    Any new reports of installs? So far I think I'd seen one set of "after" pictures (for 2nd gen) and they used a 3 leaf aal.
  12. Feb 20, 2018 at 3:05 PM
    #492
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    From a technical standpoint; Compare the 6112 and 5160 to the 5100, and you'll have your answer as to how much better they are.
    Only you can answer the "is it worth it" question. It's your truck, your wallet.
    FastEddy59 likes this.
  13. Feb 20, 2018 at 3:10 PM
    #493
    Taco TRQ
    TuRDTaco
    No, but an old shock has no difference in length from a new one.
  14. Feb 20, 2018 at 3:26 PM
    #494
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Good point. Do you work in the industry or specifically in suspension design? Your comments make me think you do, since you quantify the upgrade over stock Bilsteins as "a little bit". I'd like to pick your brain a bit if so because, I don't want to waste time/money on these if they are pretty inferior to other offerings.
    BWilley likes this.
  15. Feb 20, 2018 at 3:28 PM
    #495
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    I’m in for $575 though which is what I just paid to pick mine up. Dachshund for scale.
  16. Feb 20, 2018 at 3:30 PM
    #496
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    These are very good shocks/springs
    To say they are "only bilsteins" is misleading. Bilstein makes some very high end stuff.
    The factory bilsteins are their weakest fleet offering. 5100 would be a small step up.
    These are big, beefy digressive valved custom tuned coilivers with eibach coils.
    I think this is a giant leap up from stock and certainly not far below FOX. I would rather these 2.5 over FOX 2.0 and reservoir over FOX non-reservoir.
    BWilley and NMTrailRider like this.
  17. Feb 20, 2018 at 3:35 PM
    #497
    TegoTaco
    Ontario, Canada
    It’s what I’m thinking, they’re only about 1.5 years old.
  18. Feb 20, 2018 at 3:44 PM
    #498
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Yes, they do it for the lift. Often because if you install a full leaf pack or (AAL+overload) with 2"+ of lift in rear, there will be too much rake. The front spacers bring rake back into a more reasonable 1-1.5" range.
  19. Feb 20, 2018 at 3:45 PM
    #499
    Adrian.Brewster
    Adrian.Brewster Well-Known Member
    Adrian
    2020 trd off road
    This is simply incorrect. There are a number of people who upgraded to this kit prior to it being marked down. And plenty of people sprung for buying the TRD Pro with this suspension being a driving component in making their decision. If you have any sort of type technical data to legitimize your comment saying this kit is "a little better" than other bilstein kits, please share. If not, it kind of sounds like you are just being a hater.
    kryten, BWilley and FastEddy59 like this.
  20. Feb 20, 2018 at 3:46 PM
    #500
    NMTrailRider
    New Mexico
    No right answer for this one. Personally, I'd consider this a great upgrade over 5100's at the $600 price. Depends on what you're goals are I guess.
    blu92in99 likes this.
