(SOLD OUT) Discounted Price on TRD Pro Suspension Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SighOn, Feb 15, 2018.
  1. Feb 20, 2018 at 6:23 PM
    #521
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Higher spring rate on the Baja kit, and the Baja front coils aren't assembled
  2. Feb 20, 2018 at 6:23 PM
    #522
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Wanting to replace this:
    With the TRD PRO kit, will I lose height? I’ll measure the spacer after while. Do these spacers have a part number on them? Bought the truck new with this lift on it, but the window sticker does not show the Toytec part numbers for the lift.
  3. Feb 20, 2018 at 6:26 PM
    #523
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Yeah you will lose about a 1" in height, but will have a Lot smoother ride. Not sure about the part #'s
  4. Feb 20, 2018 at 6:30 PM
    #524
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Baja is tuned for speed performance, stiffer springs 650lbs vs 600lbs Pros, and Baja has firmer shocks. The Pro is softer setup better tuned for lower speed off road. The Pro shocks are coated to prevent corrosion whereas the Baja is raw aluminum. Pro struts come assembled, Baja struts require assembly.
    Baja kit part number is: PTR13-35120
  5. Feb 20, 2018 at 6:39 PM
    #525
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If your truck is level, and doesn't have any rear lift, you likely have the 2" spacer. So you'd lose 0.25" in lift and gain a significant suspension upgrade that rides and performs way better.
  6. Feb 20, 2018 at 6:42 PM
    #526
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Any idea which years?
  7. Feb 20, 2018 at 6:48 PM
    #527
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Which years? Was the Baja offered? I think 2012-2014. It proceeded the Pro, similar concept with same lift height, same shock bodies, tuned differently, same TRD exhaust but lacked the cosmetic changes the Pro had other than having a massive Baja decal on the side. Built in far lower numbers.
    I put the Baja setup on my truck:
    https://www.tacomaworld.com/threads/selecting-a-mild-lift-trd-baja-tx-pro-icon-aal.385619/
  8. Feb 20, 2018 at 6:53 PM
    #528
    308savage
    Adam
    East Tennessee
    It has an AAL. Guessing it is also Toytec. Here it is new, 10 miles on it:
  9. Feb 20, 2018 at 6:58 PM
    #529
    FastEddy59
    Eddie
    I guess I should be changing other components as well like bump stops?
  10. Feb 20, 2018 at 7:04 PM
    #530
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    3 leaf AAL or single leaf? If that has an AAL in the rear then it is a 2.5-3" spacer up front. You can measure the spacer to see. I think every 0.5" of spacer gives 1" of lift, so a 1" spacer gives 2" lift.
    The kit should come with everything you need to change to have it just like the OEM setup. I don't think the Pro kit actually comes with the extended travel (shorter) bump stops like the Baja does, or so I've heard. I've not purchased the Pro kit separately. Baja is designed for high speed desert where the extended travel would be more necessary compared to the Pro.
  11. Feb 20, 2018 at 7:10 PM
    #531
    308savage
    Adam
    East Tennessee
    Single AAL.
  12. Feb 20, 2018 at 7:14 PM
    #532
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If Toytec, then it is 1.5-2" rear lift.
  13. Feb 20, 2018 at 7:42 PM
    #533
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
    Any thoughts on the Toytec Boss leaf pack paired with these?
    I have a lead on a used pair.
  14. Feb 20, 2018 at 8:14 PM
    #534
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    Looks like they are supposed to give 2" of lift... I'm a little leary of used leaf springs personally..
  15. Feb 20, 2018 at 8:15 PM
    #535
    TrdSurgie
    TrdSurgie revised
    Oahu
    How much lift have the 2nd gen guys gotten with these?
  16. Feb 20, 2018 at 9:20 PM
    #536
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    ~1.75"
    TrdSurgie[QUOTED] likes this.
  17. Feb 20, 2018 at 10:32 PM
    #537
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    My Deaver single aal gave me a little over 1 inch of lift with the truck on the ground and a full loaded tool box,which will be perfect with this kit.
  18. Feb 21, 2018 at 1:14 AM
    #538
    lynlan1819
    Tacoma
    Lifted
    Bilstein is all I have ever ran on my trucks,not a single problem with them.
    TownvilleTim likes this.
  19. Feb 21, 2018 at 4:36 AM
    #539
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I also will feel bad putting them on my truck, salt ruins everything... Going to try to combat corrosion with Fluid Film.
  20. Feb 21, 2018 at 6:21 AM
    #540
    Hupernikao7
    Hupernikao7 Well-Known Member
    Tallahassee, FL
    13' Trd Off Road 4x4
    MB Wheels "352" 16 X 8.5 6-139.70 -6 BFG Load Range E 33's Rugged Premium Tri-Fold Tonneau Cover 25 inch LED offroad light bar Ditch Lights
    Ordered mine Monday from OEM Part World. I have been in contact with them and they said mine should ship today. Do these come with mounting hardware for the remote reservoirs?
