Sold please delete - 2003 TRD Double Cab 143k $10K - East Coast!
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by ekul310, Feb 23, 2021.
  1. Feb 23, 2021 at 5:48 PM
    ekul310
    ekul310 [OP] Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    2003 Toyota Tacoma TRD Off Road 4x4 Double Cab
    142,500 miles - will go up as I drive it
    3.4L V6 5VZ-FE
    Automatic Transmission
    Tires/Wheels:
    255/85-16 (33 inch) Cooper Discover S/T Maxx 10 ply
    16 x 8" Vision Turbine - I have a matching 5th spare
    Front Suspension:
    SPC Front Upper Control Arms
    Old Man Emu Nitrochargers with 882 coils
    Tundra 13WL big brake upgrade
    Wheelers stainless steel extended brake lines
    New Toyota lower ball joints
    Poly steering rack bushings
    Rear Suspension:
    All Pro Offroad Standard Leaf Springs
    Bilstein 5100 series shocks
    Brand new rear brake shoes/hardware
    Extended rear brake lines
    Exterior:
    ARB front bumper with 8,000 lb Warn winch
    Trailer hitch setup for 4 flat connector & 7 round connector with electric brake controller
    Roof rack
    Frame replaced by Toyota under recall in April 2016 @105k miles
    LED bulbs in all lights except headlights
    Interior:
    Blue LED lights in gauge cluster and dash to match radio
    Aftermarket Pioneer radio with Bluetooth
    Rubber floor mats
    Other:
    Auxiliary transmission fluid cooler installed for towing
    Oil changed every 5,000 miles with Mobile 1 High Mileage 5w-30 synthetic & Toyota oil filter
    Transmission fluid serviced
    Fuel tank replaced in 2019 to fix a leak in the emissions system
    Grey wire mod
    Brand new parts included with the truck:
    ALL parts needed to do a timing belt and water pump service on the truck. Literally everything - Toyota FIPG, radiator hoses, even the Toyota sticker used to record the date/mileage of the service. Only additional thing needed is Toyota LongLife red Coolant.
    ALL parts needed to replace the valve cover gaskets. Cam seals, spark plug grommets, anything that can be replaced is included.
    Toyota oil filter and Wix air filter.
    Spicer carrier bearing for the driveshaft.
    Timing belt and water pump have been changed in the past at unknown mileage, but will need done again around 180k miles. Softopper bed cover is not included. This is the first winter I have driven in the salt with this truck and it was sitting until the beginning of February. I was in an accident in November and the truck was totaled by the insurance company. I replaced the passenger front door and fender and some suspension/steering parts. It has had the enhanced inspection and passed easily. I have the title in hand, but it is now a reconstructed "R" title.
    If I keep the truck I will be doing a few cosmetic things and asking more money for it. Things on the list include; have the pinstripe removed from the replaced door/fender, reinstall the passenger door window/vent visor, spray the undercarriage with Woolwax, and have the interior/exterior completely detailed.
    I'm looking to sell to get into a 2007 or newer 4 door Tundra with the 5.7. I might also consider a 4 door 3rd gen Dodge ram 1500/2500. Must be 5.7 Hemi or 5.9 Cummins, preferably a manual. I might be interested in other cars/trucks too so if you have something I might like let me know - worst I can do is say no. I can work a deal for a trade plus cash on either end if needed.
    I planned on keeping this truck forever but I now want something with more towing capacity. I'm pretty firm on the price. It comes with close to $1,000 in extra OEM parts
    IMG_0646.jpg IMG_0636.jpg IMG_0643.jpg IMG_0637.jpg IMG_0629.jpg IMG_0630.jpg IMG_0634.jpg IMG_0635.jpg IMG_0638.jpg IMG_0639.jpg IMG_0642.jpg IMG_0640.jpg IMG_0641.jpg IMG_0626.jpg IMG_0627.jpg IMG_0628.jpg IMG_0647.jpg IMG_0648.jpg IMG_0649.jpg
    joe25rs and sandsloth like this.
  2. Feb 28, 2021 at 12:52 PM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    Bump for some offers. I'm open to trades too! Show me who's interested
  3. Feb 28, 2021 at 3:24 PM
    cummins culprit
    cummins culprit New Member
    sharp truck text 870 834 0229 if you don't care
  4. Feb 28, 2021 at 6:01 PM
    GoFaSSter
    GoFaSSter New Member
    If you could post pics before you fixed it from the accident, that would help.
    OG_Tacoma likes this.
  5. Mar 1, 2021 at 5:34 AM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    Here are a couple from right after the accident before any repairs
    B9D353AA-493E-4613-99D0-11DC8773F21B.jpg 0F8BCD8F-1D04-4F09-B8E9-98EF8FF4E578.jpg EEC1638A-1A95-4F8A-8E05-291CCC2CE6D0.jpg
  6. Mar 1, 2021 at 10:45 AM
    Madjik_Man
    Colorado Front Range
    Solid truck. Worth more in the Colorado market.
    Where in PA are you located?
  7. Mar 1, 2021 at 4:29 PM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    I’m about 1 hour east of Pittsburgh. Having driven an old ‘84 Toyota from Denver back home I can tell you it’s about 23 hours and right at 1,500 miles hahaha
  8. Mar 2, 2021 at 10:09 AM
    Madjik_Man
    Just want to confirm that the accident occurred after the frame swap?
    What all was entailed with fixing the truck after the acccident? And did a frame shop confirm that the frame is straight post accident?
  9. Mar 2, 2021 at 7:59 PM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    The Toyota frame replacement happened in April 2016.
    Accident happened in November 2020.
    As far as body panels, I replaced the passenger front fender and passenger front door. There is also some damage on the passenger rear door, front bumper, and on both fender flairs on that side. These damages are pretty small and only cosmetic.
    Underneath, I replaced the inner and outer tie rods on the passenger side including the boot. This was all that needed to be replaced from the damages in the accident. I also installed new OEM lower ball joints and poly steering rack bushings both of which I had on my parts pile already.
    Both a frame shop and alignment guy said everything’s in spec. The SPC UCAs even allowed stock caster/camber specs.
    I’m really only trying to sell this taco because while this one was down, I bought another first gen and my DD BMW broke down. I don’t need 2 tacos and I want something capable of towing my cargo trailer and camper. Also having to get towed a few times in a couple months made me realize the value of having a good tow rig.
    Let me know if you have any more questions.
    OG_Tacoma and Madjik_Man like this.
  10. Mar 5, 2021 at 11:40 AM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    If you end up deciding to part out before selling, LMK as I'm on East Coast too.
  11. Mar 5, 2021 at 1:05 PM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    Definitely will not be parting out this truck. Thanks anyway
    OG_Tacoma[QUOTED] likes this.
  12. Mar 6, 2021 at 7:25 AM
    ekul310
    Luke
    Pennsylvania
    Stock stock stock
    Truck has been sold
    Madjik_Man likes this.
  13. Mar 6, 2021 at 11:27 AM
    OG_Tacoma
    No problem.
    Congrats! And sorry for your loss lol
