SOLD Please delete RS3200 “Plug ‘n’ Play” Keyless entry
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Lil Puke, Nov 27, 2020.
  1. Nov 27, 2020 at 9:42 AM
    Lil Puke
    Lil Puke [OP] Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    Hey folks,
    I have an RS3200 Keyless Entry brain and harness for sale. The unit came out of a 2004 double cab tacoma. Unit has plugs for GBS, but does not come with sensors. No key fob either.
    To confirm fitment, go take a look at your in-dash fuse box. If it has a blocky rectangular pigtail under the fuses (2nd to last photo for example), this unit will fit. If your fuse box has a long flat pigtail under the fuses (last photo for example) this unit WILL NOT fit.
    $100 OBO..... It’s Black Friday, I’ll cover shipping to the lower 48. :thumbsup::thumbsup:FB5CB7FF-ADCC-4976-B63C-2AE4CBA181DB.jpg 62555171-E1E2-48C7-AD68-D632F21A672C.jpg 1D2F742B-AE18-43F6-9337-E8F56C4E244D.jpgBDEE052C-287F-462F-9712-9F490DDA98CE.jpg 545FD9E0-8976-4C8A-9551-3E32AA7E3175.jpg
  2. Nov 27, 2020 at 9:52 AM
    Davis85WV
    Davis85WV Well-Known Member
    Justin
    WV
    2002 DC TRD OR
    5speed swapped, Toytec boss lift, JBA uca's, Procomp Rockwells, Falken Wild Peaks 285/75/17, Snugtop, Afe CAI, Magnaflow muffler, Compustar Keyless and Remote start, Huskyliners, Ultragauge scan tool, Pioneer dd, LCE short throw shift kit, Marlin Clutch, Factory roof racks,
  3. Nov 27, 2020 at 10:01 AM
    Lil Puke
    Oregon
    ‘99 Taco
    I contacted him and unfortunately he’s looking for the RS3000. Shucks
  4. Nov 27, 2020 at 10:52 AM
    Billison_
    Billison_ Why does beer pair so well with wheeling?
    Billy
    ‘01 Ext Cab With Spension
    I changed the air freshener to a new one, one time.
    I’ll actually check my fuse block when I get home because pretty sure I have the second to last fuse block.. and when you say it doesn’t have the gbs sensor you mean the little thing that can go in a switch blank?
  5. Nov 27, 2020 at 11:04 AM
    Lil Puke
    Oregon
    ‘99 Taco
    GBS as in Glass Breakage Sensor.
    It doesn’t have an actual “alarm” that I know of, but it does have the available pigtails to install. I think there’s a write-up around here on them, I’ll see if I can find it and then I’ll post the link to this same comment.
    EDIT: here is the link that @ThunderOne posted back in 2017.
    https://www.tacomaworld.com/threads/tvip-upgrade-to-stock-rs3200-alarm-system-2003-2004.524376/
  6. Dec 3, 2020 at 7:44 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I bought my truck used and it came with a broken key fob. So I’m assuming my truck already has this unit? It does have the pigtail in the second to last pic. But I’m not sure if anything you have would be any benefit to me. I’m tired of having to use my key in the door
  7. Dec 3, 2020 at 8:08 AM
    Lil Puke
    Oregon
    ‘99 Taco
    Sounds like you’re probably all set up. Unless it’s an aftermarket install, you’ll find it behind the drivers side kickpanel.
