Sold please delete
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by Billison_, Oct 3, 2022.
Thread Status:
Not open for further replies.
  1. Oct 3, 2022 at 3:01 PM
    Billison_
    Billison_ [OP] Why does beer pair so well with wheeling?
    Billy
    ‘01 Ext Cab With Spension
    I changed the air freshener to a new one, one time.
    The time has come that this truck needs to find a new home. 2001 Toyota Tacoma Off-road. This truck is solid. I’d continue to build it but priorities are shifting and I am going to go a different route. I have a ton of extras with this truck and most of it is brand new.
    The truck itself has been a desert truck it’s whole life, NO RUST, I am the second owner, and the truck has 142k miles on it.
    I recently had a full ac service done and it blows colldddddddddd. I also had the shocks rebuilt and bench tuned by RH Fab here in Las Vegas.
    Upgrades:
    • BxBuilt Laser Led Retrofit Headlights w/TRD etching.
    • Shrockworks Bumper
    • Come up Seal slim winch 9,500lbs. (Is not yet wired as i was going to wire it to a kill switch.
    • ADS 2.5 remote resi extended mid travel shocks up front with a bit of machining for extra travel.
    • Total Chaos Uniballs UCAs (new bushings)
    • Relocated shocks in rear: ADS 2.5 Triple bypass shocks with Deaver j59 springs.
    • Ubolt flip kit with duro bumps in all 4 corners.
    • Drilled and slotted rotors up front with freshly painted drums in rear to go with wheels.
    • BAMF weld on sliders with a little kick out.
    • 7/16s Stainless Steel Skid Plate
    • GhostShip rear tire gate with old school 4wd badge.
    • TYP Metal door handles
    • Mickey Thompson III 15” wheels wrapped in Toyo MTs 33x10.5R15
    • Redline Tuning hood struts
    • North Star battery w/ Aluminum battery Tie down (from a tw member just can’t remember name)
    • ARB breather relocation
    • Honda windshield nozzles
    • ABS HAS BEEN REMOVED AND PROPORTIONING VALVE HAS BEEN INSTALLED. Brakes work amazing but off-roading is terrible with the abs. Just know that when buying that you have no ABS. Looks semi oem as I plumbed mostly everything with Toyota non-ABS lines.
    • ARB Snorkel
    • Pioneer touchscreen head unit with apple carplay.
    • Marlin crawler short shifter
    • Redline Leather shifter boot.
    • Wetokole Seat covers with TRD emblem.
    Extra Parts Not installed
    • Switch pro with SDHQ Bezel
    • Powertrays universal Mount for switch pro
    • Come up seal slim winch 9,500 lbs (winch is installed in bumper but not wired up. I have all the cables and remotes for the winch in original box.
    • I have inline fuses and winch power cut off switch to install inline with winch.
    • Cut off switch 2nd gen mount
    • Big 7 cable upgrades for truck.
    • Extra cv that has not been rebuilt.
    • Baja design lights inside bumper but I have original box.
    • Budbuilt track bar
    • Fsm
    I had big plans for the truck but as I mentioned I am going to pursue a different direction. I have been collecting all these parts and items to install but with work being busy I just ended up collecting all of them. I am asking for the entire package $18,000. I’m open to offers.
  2. Oct 3, 2022 at 11:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What size are the Toyos? Are you still on stock 4.10 gears?
  3. Oct 4, 2022 at 4:17 AM
    Billison_
    Billy
    33x10.5r15 and stock gearing
  4. Oct 5, 2022 at 11:12 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Did you have to cut or bend much to fit that size tire?
    Nice truck BTW.
  5. Oct 6, 2022 at 6:40 AM
    Billison_
    Billy
    Pinch weld mod was done and the tires naturally trimmed the fenders haha I would trim as needed. I got the right offset with these wheels so nothing major had to be done.
    TacomaFNG likes this.
  6. Oct 6, 2022 at 10:57 AM
    Nessal
    Texas/Bay Area
    What offset are your wheels? Mine are -19 offset and I'm trying to fit that same size.
  7. Oct 6, 2022 at 1:58 PM
    Digiratus
    Roaming the PNW
    The RedHead
    For comparison purposes, to be able to effectively use an offset number, you must also know the rim width.
  8. Oct 7, 2022 at 4:51 AM
    Billison_
    Billy
    Pmd!
  9. Oct 17, 2022 at 4:12 PM
    Billison_
    Billy
    Reduced price to 18k. Open to offers.
  10. Oct 28, 2022 at 9:50 AM
    Billison_
    Billy
    Reduced price to 16k.
  11. Nov 11, 2022 at 6:58 AM
    Billison_
    Billy
  12. Nov 11, 2022 at 7:01 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Nice Truck!
  13. Nov 12, 2022 at 1:17 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Dang I feel like this is a steal at that price
  14. Nov 14, 2022 at 4:31 AM
    Billison_
    Billy
Thread Status:
