SOLD REMOVE POST PLEASE
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by TTBB2013, Oct 30, 2015.
  1. Nov 1, 2015 at 8:05 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    I have 6" of lift. The wedge \ spacer helps correct the angle of drive shaft to rear wheels. I have the OME CB drop, but it is not enough as I eat rear shaft U-joints every 6 months or so!
    nach73[QUOTED] likes this.
  2. Nov 1, 2015 at 12:04 PM
    GDOLBOI
    GDOLBOI Under Qualified And Overpaid
    Concord Ca
    2020 DBL cab LB Trd Offroad 4x4
    King, BAMF, SCS,
  3. Nov 1, 2015 at 12:36 PM
    TSmalls89
    TSmalls89 Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    PM'ed about ProComp shocks
  4. Nov 1, 2015 at 1:22 PM
    GDOLBOI
    Concord Ca
    King, BAMF, SCS,
    Does anyone know if the Low range off-road add a leafs listed on this page will work for a 2015 Toyota Tacoma
  5. Nov 2, 2015 at 7:06 AM
    TSmalls89
    Tyler
    Merrimack NH
    Pretty sure they will. 2015 runs same suspension as 2005-2014
  6. Nov 5, 2015 at 9:46 AM
    nach73
    nach73 Well-Known Member
    Nacho
    Pueblo, CO
    06' Pre-Runner TRD- Off Road
    5100's set @0 with 887 springs and 1.5 AAL. Satoshi Raptor grill, Halo Projector led Spyder headlights and syder taillights, Projector led Halo fog lights by Zack/Taco Nation, LED's everywhere else, Raceline 16x8 Assualt wrapped with Goodyear DuraTracs 285/75/16. Wet Okole seat covers, Paracord headrest handles by Cole/Dessert Dunes, Weather tech floor mats, JVC Arsenal KW-V200BT, 2 10" Kicker shallow mount, Alpine components, Alpine 1000 watt amp, interior is completely Dyna matted
    Free bump.
    I received my parts today. Everything is in awesome shape(brand new) and Xtra care was definitely taken when it came to packaging.
    :cheers:
  7. Nov 6, 2015 at 7:03 PM
    wicycletester
    wicycletester Well-Known Member
    se wisconsin
    several
    Another bump for an awesome seller. Great communication, quick shipping and packed better than when new.
  8. Nov 7, 2015 at 8:27 PM
    Techoma
    Alta Mesa, AZ
    got my stuff days ago... super fast! Thanks.
  9. Nov 9, 2015 at 5:14 PM
    Underpressure
    Underpressure INJECTION IS NICE BUT I'D RATHER BE BLOWN
    Jim
    Iowa
    07 TRD Sport
    5100's set at 2.5 in. , 2 in. AAL, CBI hidden front hitch, 2 Ramsey 8000LBS. winches, ECGS front diff bushing, TRD supercharger, TRD boost gauge, URD headers, URD pulley, T-stat, fuel pump, Methanol Injection system, "Coupe" custom TRD CAI cover, 2 PLX A/F gauges, PLX AIT and Oil pressure gauges, Autometer Pro Comp fuel pressure and Trans. temp gauges, custom built transmission and shift kit, NST overdrive SC pulley kit, TRD Ivan Stewart wheels with Firestone M/T tires, ARB compressor, front and rear lockers, more in time.
    Thank you TTBB2013 , for the great deals and excellent customer service!!!!!
  10. Nov 9, 2015 at 5:20 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    bump for great seller. fast shipping
  11. Nov 17, 2015 at 6:54 PM
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    I might like to take your U-bolts and axle plates. I'll get back to you.
  12. Dec 25, 2015 at 5:18 PM
    Flipsyde
    Flipsyde Well-Known Member
    Chad
    Fresno, CA
    06 TRD Sport DCSB 4wd
    I'll take the diff drop kit if it's still available.
  13. Jan 27, 2016 at 7:49 AM
    C4stro
    C4stro Well-Known Member
    Israel
    Calexico Ca.
    08 PreRunner SR5
    Cabin Power Out-let mod, 5100´s front rear, OME 886, 285´s, Front End Swap '08 -15
    Pm sent
  14. Mar 19, 2016 at 7:12 AM
    Terwal34
    Terwal34 Well-Known Member
    2006 toyota tacoma
    Do you still have i need u bolt plate only
  15. Mar 19, 2016 at 8:13 AM
    #35
    Terwal34
    2006 toyota tacoma
    I need only the plastic plate
  16. Mar 19, 2016 at 10:20 AM
    #36
    Terwal34
    2006 toyota tacoma
    Im only need the plate
  17. Mar 19, 2016 at 11:36 AM
    #37
    Terwal34
    2006 toyota tacoma
    Yes in sure squater black plate
  18. Mar 19, 2016 at 11:58 AM
    #38
    Terwal34
    2006 toyota tacoma
    Yes i need only the plate my u bolt are brand new but my plate i want to change
  19. Mar 19, 2016 at 12:13 PM
    #39
    Terwal34
    2006 toyota tacoma
    This part is for that rear or front i need for the rear
  20. Mar 19, 2016 at 12:25 PM
    #40
    Terwal34
    2006 toyota tacoma
    Im working at that moment Il check when get home
