SOLD: Rotiform USF 17x9.5 Forged Wheels (Los Angeles)
Discussion in 'Wheels & Tires Marketplace' started by urban, Sep 29, 2022.
  1. Sep 29, 2022 at 6:53 PM
    urban
    urban [OP] Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    As description says set of custom 1 of 1 set of Rotiform USF. Definitely a unique set of wheels. I've only seen a set of flat face USFs on a third gen 4 runner, never seen a truck with a concave set like these. The six point design really compliments retro Toyota 4x4 style IMO. Should Should fit most 6 lug Toyota trucks and are the perfect fitment if you wanna go wide. They fit 305's with only about 1/4 of an inch of tread sticking out from the fender, I can probably dig up photos if you want to see. Available in Los Angeles area. DISCLAIMER, they will need paint/powdercoat, Read down for full description.
    x4 Rotiform USF wheels.
    Backspace: 5"
    Bolt pattern: 6x139.7mm
    Center bore: 106.1mm
    Wheel pockets perfectly fit APR part number ARP 100-7715 (2.6" long studs for lexus IS300) Standard studs will also work fine but nice to know you can run em' and have a clean look (I run my stock rims with snow tires and 13mm spacers)
    Also included x1 custom steel spare.
    Size: 19x9" Matching custom offset steel wheel. I think its like 4.75" backspacing because it's half an inch narrower. Has a BF Goodrich KO2 A/T (305/65r17) with 85% tread. Perfectly good for a spare.
    I had to buy a new set of wheels while these ones out to get warranty work so I no longer need them. One wheel got re-barreled (the one with the silver lip) so they all need to get repainted or powder coated. When the one wheel was getting barreled the other three also went in to be inspected if that give you some peace of mind. I have choose not to do this so you can choose whatever weird color your silly heart desires.
    Black? Lime green? Magenta? Electric two stage blue with glitter? The options are yours.
    This is reflected in the price which is 50% original cost -$600 to get them recoated plus the spare for free basically. Looking to get $1400. I can refer you too a good place to get them refinished as well.
    Currently three of them look like this (three stage black, purple to gold color shift pears):
    And the one that was re-barreled:
