!!sold!! Street tacos beefed blocks !!sold!!
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by jmarquez808, May 30, 2018.
  1. May 30, 2018 at 1:05 PM
    jmarquez808
    jmarquez808 [OP] Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Brand new unused 4 inch blocks tapered with offset pins. These are from streetacos.com you know the ones tnat take forever to get because they are good shit. This qas for my regular cab 2007.
    75 shipped with no wait.
  2. May 30, 2018 at 2:49 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  3. May 30, 2018 at 3:39 PM
    jmarquez808
    Jess
    Hawaii
    Replied
  4. May 30, 2018 at 11:48 PM
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    How much taper?
  5. May 30, 2018 at 11:51 PM
    jmarquez808
    Jess
    Hawaii
    Im not sure as far as i can remember brian only offered one set type of taper that was proper for the size of block for the angle of the axle at that height. Its a small amount of taper.
  6. May 30, 2018 at 11:53 PM
    camojared
    Jared
    SE Ohio
    If you could measure some time that would be great, I'm running 3 degree shims currently and would be nice to know if I could just replace everything with those!
  7. May 30, 2018 at 11:58 PM
    jmarquez808
    Jess
    Hawaii
    Just checked, its a 1/4" taper
  8. May 31, 2018 at 12:03 AM
    camojared
    Jared
    SE Ohio
    Thanks let me do some checking!
  9. May 31, 2018 at 12:18 AM
    jmarquez808
    Jess
    Hawaii
    Sounds good
  10. May 31, 2018 at 9:08 AM
    jmarquez808
    Jess
    Hawaii
