Sold Tacoma - Aftermarket and Factory Parts
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by taco 16, Jan 2, 2020.
Thread Status:
Not open for further replies.
  1. Jan 2, 2020 at 12:19 PM
    taco 16
    taco 16 [OP] Well-Known Member
    Lance
    San Diego
    2016 DCSB TRD Sport 4x4
    Hey guys I traded in my 2016 Tacoma for a 2020 Tundra. I couldn’t handle the engine-transmission combo any longer, while re-gearing to 4.88’s and Ovtune helped drastically, it wasn’t enough to fix the tacoma (for me).
    Anyway I was able to pull some items off the tacoma before trading it, listed below.
    All items listed are used with normal wear unless stated in description and priced far but I’m negotiable on price.
    All items are for local sale and pickup...San Diego CA
    Please PM me for any additional information if needed.
    HiTent Rincon Expedition Grade tent with annex $1800 - only used about 7 times.
    Tent body: 400g rip-stop poly-cotton breathable canvas, dual stitched and weather taped seams, UV and mold resistant, waterproof coating
    Rainfly: 420D Polyester Oxford, waterproof, mold resistant and UV protected, elevated rainfly with reinforced rainfly mounts
    Seasons: 4, with our 400g canvas, your tent will stand up to the weather and keep you warm and comfortable inside, summer, fall, winter, and spring.
    Mattress: Thick high-density foam with a removable/washable cotton cover
    Travel cover: 1200D Heavy duty pvc, UV protected and waterproof
    Base: Aluminum frame, Honeycomb core with diamond plate exterior
    Sleeping capacity: 3 in tent. plus more in annex under ladder with addition of Included Annex.
    Weight empty: 150lbs
    Weight capacity: 1200lbs
    Too many details to list - see HiTent website
    **one of the locking pins of tent later missing**
    Local pickup only
    *Light in tent not included*
    _____________________
    HiTent Awning $200 (79" wide and opens to about 7.5' Awning material: rip-stop polycotton canvas, UV protected and mold resistant Cover: heavy duty pvc, UV protected, waterproof). Only used awning around 3 times - Awning has Prinsu brackets attached.
    *awning on tacoma*
    *awning on tacoma*
    2005- 2020 short bed Tacoma Brute Force Fab Bed Rack $900
    • This bed cage is manufactured from 1.750 x .095 HREW round tube and is fully welded.
    • Mounts with the factory bed mounting bolts and sits directly on the inside of the bed for the most strength and support. This design is optimal for the extra weight added from a roof top tent and other accessories which the factory bed sides are not designed to handle.
    • Fits 05 & up Tacoma's
    • Side plates are CNC plasma cut from 12ga steel and features many different slotted holes for Roto-pax fuel cans, Hi-lift mounts, axe & shovel mount, ect, ect
    • Easy mounting of roof top tents
    • Mounts for lights all 4 corners
    • Brackets for spare wheel
    • Axe & shovel mount
    • Hi-Lift jack mounts
    ____________
    2016-2020 Toyota Tacoma QuickLIFT ELITE Redline Tuning Hood Struts $90.
    Good condition. You will need to buy the rivets to install the brackets, rivet size in instructions.
    Local pickup only.
    ____________
    **** SOLD ****2016-2020 Toyota Tacoma Meso chrome delete (black full kit)- Just received - new, never open package (unused) $45 ($5 savings) **** SOLD ****
    ____________
    ***SOLD*****2016-2020 Toyota Tacoma Meso extended fuse cover V2 item FCV2 (unused) $15 ***SOLD*****
    ________________
    ****SOLD**** 2016-2020 Toyota Tacoma Meso lower panel 7-switch item LSP7 (unused) $30 ****SOLD****
    ________________
    ****SOLD****2016-2020 Toyota Tacoma center console tray and organizer $15 for both ****SOLD****
    ****SOLD****2016-2020 Toyota Tacoma Custom Sunscreen shade item UVS100 (Silver) $50****SOLD****
    2016-2020 Tacoma recovery tow hook $40
    _____________
    Phone mount with Go-Pro attachment fits all Go-Pro mounts - 2016-2020 Toyota Tacoma equipped with Go-Pro mount on windshield $15
    ___________________
    2016-2020 Toyota Tacoma factory side mirror turn signals $40
    __________________
    2016-2020 Toyota Tacoma factory fog lights $40
    _____________
    2005-2020 Factory bed storage doors $60
    ______________
    ****SOLD****2005-2020 Toyota Tacoma factory bed mat (short bed) $85****SOLD****
    _______________
    2016-2020 Toyota Tacoma factory floor mats, good condition, removed within 2 weeks of purchasing truck. $40
    ___________________
    HAI Cable for 3rd gen Tacoma $50 ($15 savings). (New - Never used, never opened static bag)
    User can use it to integrate Front Camera assy and view at any time.
    User can use it for fully control Head Unit while the truck is in motions.
    User can use it to integrate Smartphone Mirroring.
    User can use it to view Rear Camera at any time.
    User can use it to integrate Media Player into Head Unit.
    See thread here:https://www.tacomaworld.com/threads...ation-override-smartphone-mirr.501617/page-33
    ****SOLD****2016-2020 Toyota Tacoma double cab (non JBL) OEM Audio Plus Sub, Amp, and Harness. $950****SOLD****
    8″ Quad Voice-Coil Woofer (sits behind driver side rear seat) and Multi-Channel 32-Bit DSP Power Amplifier with dedicated sub amplifier with gain control knob and plug and play harness with oem style connectors.
    • 8” Genuine Carbon Fiber Cone Woofer
    • 100W RMS (200 Peak)
    • Sensitivity 88.9dB (1 W,1M)
    • Frequency Response: 20 -1000 Hz
    • Plug and Play Installation
    • O.E. Automotive connectors for precision and reliable connection
    • Connectors are keyed so theres no chance to insert the wrong way
    • AMP
    • 360 Watts RMS (Continuous / @ 2-ohms)
    • Cirrus-Logic 32-Bit Digital Signal Processing
    • QUICK-SYNC WIRING HARNESS
    • Maintains all factory functionality
    • Constructed of genuine OEM connectors
    Norsemanvike likes this.
  2. Jan 2, 2020 at 12:21 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Ill take the fuse cover. PM inbound
    taco 16[OP] likes this.
  3. Jan 2, 2020 at 12:22 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I'll take the fuse cover from Meso if you'll ship
  4. Jan 2, 2020 at 12:29 PM
    taco 16
    Lance
    San Diego
    Sold already
  5. Jan 2, 2020 at 12:52 PM
    ArchitectJVM
    ArchitectJVM Well-Known Member
    Interested in the windshield cover if you can ship to 95123.
  6. Jan 2, 2020 at 12:52 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    PM’d lance :thumbsup:
  7. Jan 2, 2020 at 1:47 PM
    taco 16
    Lance
    San Diego
    PM’d - shade is pending local sale.
  8. Jan 2, 2020 at 1:57 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    Ill take the bed mat and center console. Pm coming your way
  9. Jan 2, 2020 at 2:06 PM
    RED_BEARD 4X4
    RED_BEARD 4X4 Well-Known Member
    Vista, ca
    2016 TACOMA TRD SPORT 4X4 DCLB
    Ill take the chrome delete willing to pickup on saturday in SD
  10. Jan 2, 2020 at 2:50 PM
    taco 16
    Lance
    San Diego
    Added HAI Cable for 3rd gen Tacoma. See Description and photos if original post.
    Thanks for Looking!....and buying :)
  11. Jan 2, 2020 at 3:59 PM
    Jessee26
    Jessee26 Well-Known Member
    Jessee
    Virginia
    16' TRD Sport Red
    I’ll take the meso lower panel if available.
  12. Jan 2, 2020 at 6:42 PM
    taco 16
    Lance
    San Diego
    Sent you a PM
  13. Jan 2, 2020 at 6:58 PM
    Kikeyota17
    Kikeyota17 Well-Known Member
    Enrique
    Trd pro
    I'll take the 7 Lower switch panel if still available and the meso chrome DELETE
    taco 16[QUOTED][OP] likes this.
  14. Jan 2, 2020 at 7:04 PM
    taco 16
    Lance
    San Diego
    PM sent
  15. Jan 2, 2020 at 7:11 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    How did you get a v2 Meso Fuse cover??????
  16. Jan 2, 2020 at 7:19 PM
    taco 16
    Lance
    San Diego
    I bought two a long time ago, I used one and had that one laying around for months. I forgot about it until I started digging through my mountain of taco parts.
  17. Jan 2, 2020 at 8:14 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Ill take the bed box covers if still available. Edit factory Floor Mats too if avalible.
  18. Jan 2, 2020 at 8:18 PM
    taco 16
    Lance
    San Diego
    Pm’d
  19. Jan 3, 2020 at 10:34 PM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    How much to ship bed mat to Vegas?
  20. Jan 4, 2020 at 5:45 AM
    LivinOnEdge
    Land of The Lost
    You might be better off buying one new, their pretty heavy and bulky.
Thread Status:
