sold TPMS Reset Tool ATEQ QuickSet & Autel TS401
Discussion in 'Wheels & Tires Marketplace' started by j2k, Mar 2, 2018.
  1. Mar 2, 2018 at 12:33 PM
    j2k
    j2k [OP] Well-Known Member
    I used them to read TPMS sensors and upload codes to my 2017 Taco. Very easy to use.
    Both for 200.00 shipped.
  2. Mar 2, 2018 at 1:38 PM
    taco 16
    taco 16 Well-Known Member
    Lance
    San Diego
    2016 DCSB TRD Sport 4x4
    Don't want to buy it but would love to use it. Where are located?
    motodh and Taco_2s_day like this.
  3. Mar 3, 2018 at 8:29 AM
    Triton21x MD
    Triton21x MD Well-Known Member
    Jim
    Maryland
    Did that unit work with the factory TPMS or aftermarket sensors? I have a sensor i need to replace and don't know if i want OEM or the aftermarket units that are a lot cheaper.
  4. Mar 3, 2018 at 8:48 AM
    j2k
    I am in Los Angeles. A bit of drive for you.
  5. Mar 3, 2018 at 8:50 AM
    j2k
    I used them on factory TPMS. Dont know about aftermarket ones.
  6. Mar 3, 2018 at 8:39 PM
    taco 16
    Lance
    San Diego
    Yeah I just figured out my problem today. GLWS
  7. Mar 7, 2018 at 5:47 AM
    ted44
    ted44 Member
    Those are two separate units that do the same thing, essentially. The says it may not be compatable with Japanese vehicles and the is a less sophisticated tool that does the same thing. Did you buy one and find it did not do what you needed and buy the second because of that?
    So the ATEQ Quickset needs a computer to use it. Does the Autel TS 401 serve that function? In other words: the two units connect together to perform the task.
  8. Mar 7, 2018 at 7:46 AM
    j2k
    Not that complicated.
    ATEQ quickset can read your ECU and reprogram/upload the TPMS code, but cant read the TPMS code directly on the tires. That's where TS 401 comes in. It reads and activates the TPMS sensors mounted on the tires. I bought the TS 401 to find out the TPMS codes that came with a new set of tires.
  9. Mar 7, 2018 at 7:50 AM
    ted44
    ted44 Member
    Thanks.
  10. May 5, 2018 at 9:20 AM
    Alder932
    Alder932 Well-Known Member
    B.C., Canada
    2013 Tacoma Limited
    Last fall I successfully used an Autel TS401 (and the ATEQ QuickSet tool) for the first time when I put on my mounted snow tires. After updating the unit software today (V.5.41) the TS401 unit won't even show a Tacoma as one of the vehicle options. I then downgraded the software to V3.2 but still no Tacoma. Anyone else facing similar issues?
  11. May 5, 2018 at 12:50 PM
    Alder932
    B.C., Canada
    2013 Tacoma Limited
  12. May 5, 2018 at 12:52 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Would you sell the 401 on its own and price? I already have the quickset.
  13. May 5, 2018 at 2:17 PM
    Alder932
    B.C., Canada
    2013 Tacoma Limited
    While the 401 works fine, it is a pretty pricey tool for just reading your TPS number and checking the air pressure. And there may be alternatives that I am not aware of. Truth be told, somewhere in TW I read about another member who was using the 401 in combination with the Quickset and took that as useful advice. A final verdict on the 401 will depend upon a response from the customer representative next week, as to why the latest firmware version doesn't have Tacomas (or Tundras for that matter) in their auto databank. It was pretty frustrating to have to time travel backwards to find an older version of the download that included a Tacoma.
  14. Sep 16, 2018 at 11:23 AM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    Hey Alder,
    Its been a few months. Did customer service answer your question? or figure out the issue (No Tacoma, Tundra)
    I was thinking of updating my firmware until I saw your post. Thanks
  15. Sep 25, 2018 at 10:02 AM
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    Just an FYI. For the Autel if you don't see Tacoma you can use any other toyota equivalent that has the same TPMS. I was able to use 4runner and Tundra to pull the TPMS coding. Since I believe they use the same TPMS freq.
  16. Sep 25, 2018 at 3:43 PM
    othater
    SoCal-Walnut
    Sorry to jump in on J2K's for sale post.
    Hey Kenny,
    Did you run the firmware update?
    I recall you offered help with reading and programming TPMS in the past.
    Have you dealt with the ECU stuck in loop issue.
    I have a 06 and I think I'm stuck in the loop since I had a bad sensor and I push the reset to many times.
    I purchase a new TPMS but since I'm stuck Techstream wont read the ECU for some reason.
    My plan was to run the firmware update so I can program an Autel programmable sensor with the dead sensor ID.
    Anyone else get stuck in the ECU TPMS loop? and how did you correct it?
    Thank you
  17. Sep 26, 2018 at 9:51 AM
    Kennyluu611
    Kenny
    SoCal
    I think I ran into this issue once on an 06 as well. I think I unplugged the battery to reset the computer then ran the programming again. Before you run the programming do the read with the Quickset and see what ID are still programmed on the computer. That will give you a good indicator if the computer took the new ID or if it didn't. I remember on one of the 06 I did the computer wouldn't take the ID. So I pulled the battery and let the power drain to reset the computer and tried it again. Not sure if this will help. Regarding the update I believe by Autel was on the newest v5.4, but i'll have to confirm that. The quickset i'm not sure which version I was on. PM me on the side for any questions.
  18. Jun 7, 2019 at 10:19 AM
    Zanabazer
    Zanabazer New Member
    2018 Tacoma Limited
    I ran into the same issue a couple of you are seeing with Tacoma not being listed after a firmware update. I noticed that after the update it changed my market to Europe and Tacoma wouldn't show up I changed my market back to America in the settings and the Tacoma option popped back up.
  19. Apr 17, 2020 at 11:34 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    http://www.maxitpms.com/tpmscms/u/cms/www/201705/1719593852on.pdf
  20. Apr 18, 2020 at 5:54 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Just an FYI... there is a new update coming (I would guess). I just got a 401 direct from Autel and it has a version up from the one on the website. I was checking to make sure it was up to date and surprised to see it had a higher version number.
