SOLD!! turbo kit for 95-04 Tacoma V6 5VZ-FE SOLD!!
Discussion in 'Buy / Sell / Trade - Canada' started by Bejabbers, Feb 28, 2017.
Thread Status:
Not open for further replies.
  1. Feb 28, 2017 at 3:39 PM
    Bejabbers
    Bejabbers [OP] Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    SOLD!!
    I have a complete CX Racing turbo kit with a Turbonetics T04E-50 turbo, including a MAPECU3 tuner with a URD plug & play wiring harness.
    The turbo kit includes the headers, turbo manifold, crossover pipe, down-pipes with O2 sensors, v-band clamps, Waste-gate with dump tube,
    front mount intercooler with all associated piping and couplers, blow off valve, air filter, turbo blanket.
    The Turbonetics turbo has an F1-62 turbine, .68 AR, 3" v-band outlet, 62mm exducer, 71mm inducer with a T04E-50 compressor, 3" inlet, 2" outlet, 54mm inducer, 76mm exducer.
    The MAPECU3has the associated wiring harnesses and there is a URD plug and play ECU harness that fits a 2000 Tacoma
    I bought this with the intention of installing it on my truck, but after researching what's involved I've decided to leave my motor stock for reliability offroad.
    The cost to buy this setup new would be over $4000 CDN not including shipping and taxes.
    CX Racing turbo kit $1100 USD without their chinese turbo
    Turbonetics turbo $1100 USD
    MAPECU3 $700 USD, and the URD P&P harness $200USD.
    I am willing to part with everything for $2800 CDN OBO
    I am currently located in Trail, BC
    SOLD!!
    SOLD!!
  2. Feb 28, 2017 at 4:16 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    From wiki:
    5VZ-FE
    The 5VZ-FE is a 3.4 L (3378 cc) engine which replaced the 3VZ-E. Bore is up to 93.5 mm (3.68 in) and stroke is 82.0 mm (3.23 in) while the compression ratio stays the same as the 3VZ-FE at 9.6:1. Output is 190 hp (142 kW) at 4800 rpm with 220 lb·ft (298 Nm) of torque at 3600 rpm. It has a cast iron engine block, and aluminum DOHC cylinder heads. The 5VZ-FE uses sequential multi-port fuel injection, has four valves per cylinder with shim-over-bucket tappets and features large cast connecting rods, one-piece cast camshafts, a cast crank (unlike the 3VZ-FE, which was forged) and a cast aluminum intake manifold. This engine also features an oil cooler and a wasted spark ignition system with three coils.
    Camshafts are belt-driven. The 5VZ-FE is a non-interference engine.
    Applications:
    I hear ya.
  3. May 9, 2017 at 10:37 PM
    heisenburger
    heisenburger Member
    1998 Tacoma 3.4 4wd
    still available?
  4. Jun 13, 2017 at 8:19 PM
    Bejabbers
    Shane
Thread Status:
