SOLD: VLEDS LPR LED Backup Light - New
Discussion in 'Buy / Sell / Trade' started by scotch, Jan 13, 2019.
  1. Jan 13, 2019 at 1:23 PM
    scotch
    scotch [OP] Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma DCSB, 2010 Tundra 5.7L, 2005 4runner 4.7L
    SOLD
    New, hooked up to battery to see how it performed, never installed. Went with lights in the bumper instead. The housing is a gloss black, with a clear lens, white 5500k light. It is bright.
    Paypal please.
    Thanks
    From https://www.vleds.com/shop-products/lpr/lpr-reverse-72-w.html:
    License Plate Reverse: You are looking at our all new LPR back-up lighting system. Made of 6061 CNC'd aluminum with an exterior grade UV resistant gloss black finish and polycarbonate lens. The LPR uses 72 high output 5500K LEDs to light up the world behind you!
    Simple Installation: Tap into your back up light bulb wires, fasten the bar over your license plate and you're done!
    Safety Added: Provide yourself and others around you with more light to see, and be seen by. This Reverse Light System is brighter than any other LED replacement bulb we sell! Enjoy the simplest and brightest LED back-up system on the market... guarantee you'll love it!
    FEATURES
    Output 1800lm measured output (5X brighter than a standard reverse light)
    LED Type 72X 0.5W 2835 5500K (perfect match to all VLEDS products)
    Lens UV resistant polycarbonate
    Waterproof Potted and sealed for IP68 rating
    Fasteners 2x 304 stainless steel M6 x 1.0 fasteners included
    Body Material All aluminum CNC machined construction
    Surface Finish Gloss black UV protective coating
    Camera Enhances back-up camera and does not blow out the feed
    Efficient Current Draw ~2A @ 12V
    Driver Dual internal 8-18V constant current drivers - no box to mount!
    Connector 2 pin waterproof plug with grommet, and 6ft extension wire
    Wiring Includes DuoTap and 6ft wire extension to reach reverse light wires on any vehicle
    NOTE: For newer trucks with CAN bus or BCM's we recommend installing LED bulbs in the factory reverse light housing or remove the factory incandescent bulbs. You can also wire the LPR into the back of the trailer harness if equipped.
  2. Jan 13, 2019 at 1:40 PM
    dizda
    dizda Active Member
    2016 Tacoma OR DCSB
    dibs!
  3. Jan 13, 2019 at 1:55 PM
    scotch
    Mark
    Centennial, CO
    pm'd
