Sold- YES THEY ARE REALLY SOLD.. tires $100 for 4
Discussion in 'Wheels & Tires Marketplace' started by NYCTaco52, Jul 9, 2019.
Thread Status:
Not open for further replies.
  1. Aug 23, 2019 at 7:54 AM
    #1281
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Give me some tire options while we're on the subject, please.
    Totally stock OR.
    Go...
    Hobbs and SRH like this.
  2. Aug 23, 2019 at 7:56 AM
    #1282
    SRH
    SRH My horns hold up my halo
    Shauna
    2018 Sport
    The ones you have...... you’re welcome
  3. Aug 23, 2019 at 7:57 AM
    #1283
    tcjacado
    tcjacado Well-Known Member
    Cooper or falken
    StayinStock[QUOTED] likes this.
  4. Aug 23, 2019 at 7:58 AM
    #1284
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Kinda what I was thinking.
    tcjacado[QUOTED] likes this.
  5. Aug 23, 2019 at 8:00 AM
    #1285
    SRH
    Shauna
    2018 Sport
    I put 4 new Coopers on my sons OR. Shortly thereafter, he sold his Tacoma, for what he calls, his dad car. Lol.
    Hobbs and tcjacado[QUOTED] like this.
  6. Aug 23, 2019 at 8:09 AM
    #1286
    tcjacado
    I had coopers on my 2nd gen and loved them.
    Hobbs and StayinStock[QUOTED] like this.
  7. Aug 23, 2019 at 9:20 AM
    #1287
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Funny guy
    SRH[QUOTED] and Hobbs like this.
  8. Aug 23, 2019 at 10:19 AM
    #1288
    NYCTaco52
    NYCTaco52 [OP] Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    In person, the difference between 255 and 285 is hard to even tell.
    tcjacado and Hobbs[QUOTED] like this.
  9. Aug 23, 2019 at 10:20 AM
    #1289
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    :puke:
    I wish my dad would put tires on my car... he laughs at me when I ask
    StayinStock, Hobbs and Spare Parts like this.
  10. Aug 23, 2019 at 10:20 AM
    #1290
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    You sure about that???
    I run Cooper ST Max 285's and haven't seen a 255/80 with a similar width.
    :rasta:
  11. Aug 23, 2019 at 10:23 AM
    #1291
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    StayinStock and tcjacado[QUOTED] like this.
  12. Aug 23, 2019 at 10:23 AM
    #1292
    Spare Parts
    Southern Maine
    18 inch Firestones with new rims.
  13. Aug 23, 2019 at 10:36 AM
    #1293
    tcjacado
    Looks like a 4 mm offset on those according to my research.
  14. Aug 23, 2019 at 10:44 AM
    #1294
    Spare Parts
    Southern Maine
    K, so that’s what the 4mm represents. I thought it might be, but wasn’t sure. Because there isn’t a minus sign, I am going to assume it’s a +4 offset, what ever that means. That will be tonight’s lesson.
  15. Aug 23, 2019 at 10:46 AM
    #1295
    tcjacado
    This wheel is designed to re-use the OE 17" Tires P265/70R17 113S
    Spare Parts[QUOTED] likes this.
  16. Aug 23, 2019 at 10:50 AM
    #1296
    Spare Parts
    Southern Maine
    K, so the positive off set pulls the wheel closer to the truck, or more under, where as negative push it out.
  17. Aug 23, 2019 at 10:52 AM
    #1297
    tcjacado
    I believe so.. that thread link I posted has a diagram in the first post that shows what positive and negative offset do.
  18. Aug 23, 2019 at 10:53 AM
    #1298
    Spare Parts
    Southern Maine
    I figured these would be a minimal change from OEM. The sport came with P265/65/R17, which is why I can gain a little height with the 70s.
    Thanks for all the help, I am making progress in not buying the wrong tire.
  19. Aug 23, 2019 at 10:55 AM
    #1299
    Spare Parts
    Southern Maine
    I’ll check it out.
    This is what I found
    WHAT IS WHEEL OFFSET AND BACKSPACING?
    So you’ve managed to save up the cash to start building your truck. First things first, you end up searching the internet trying to find your bolt pattern, backspacing, hub size, and more. But more importantly, you’re trying to figure out what wheels and tires are going to fit your truck. Does diameter matter? Does width matter? Unfortunately, it’s just not that easy. Things like backspacing and offset can be as unique as the wheel that matches your truck. So how can you be sure what you want will fit and look exactly how you want it to? That’s where we come in.
    Now, If you aren’t the reading type and just want a quick answer - You can always search our fitment gallery by your Year/ Make/ Model here.
    If you want to become a subject matter expert, let's dive into this.
    Wheel sizes are normally listed as 22x12 -51mm or 18x9 +25mm, etc, but what do all of those numbers even mean?
    [​IMG][​IMG][​IMG]
    The first number listed is the diameter in inches. So a 22x12 -51mm would be a 22” diameter wheel. The second set of numbers listed is the width in inches, so a 22x12 -51mm would be a 12” wide wheel. The third set of numbers is where it gets tricky. That number is the offset of the wheel in mm. So a 22x12 -51mm would be a -51mm offset.
    So there’s wheel diameter, wheel width, and a “positive” or “negative” offset. What is offset? Offset is the distance in millimeters (mm) + or - from the hub (where you bolt the wheel to the vehicle) to the true center of the wheel.
    A “negative” offset is where the mounting surface of the wheel is closer to the inside (brake side) of the wheel. In the truck world, many custom truck wheels come in aggressive negative offsets. The more negative the offset, the more aggressive stance you will get. This means the wheels will “poke” outside of the fenders. “Poke” or “Stance” is when the wheel and tire stick outside of your fender. A negative offset is what can create a larger lip or concave style, which will push the tire out.
    A “positive” offset is where the mounting surface of the wheel is closer to the outside (fender side) of the wheel. This pushes the wheel in toward the brakes which can “sink” the tire and wheel into the fender well opening.
    [​IMG][​IMG]
    [​IMG][​IMG]
  20. Aug 23, 2019 at 11:40 AM
    #1300
    My Name is Rahl
    Wow. Thanks, mang! I am totally screenshotting this, because this is the first time someone has actually explained it without the technical jargon!
Thread Status:
