sold
Discussion in 'Buy / Sell / Trade' started by TacoTaro, Sep 4, 2015.
  1. Sep 4, 2015 at 12:27 PM
    TacoTaro
    TacoTaro [OP] Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    Sold
  2. Sep 5, 2015 at 3:12 PM
    Taco Mark86
    Taco Mark86 Well-Known Member
    Mark
    NC
    09 DCSB with some mods
    Magnaflow, Fox RR/ Camburg UCA up front, Bilsten 5100 and some kind of AAL/ leaf pack in the back?, Light bar w/ Hella, and an air freshener
    How much lift will these provide?
  3. Sep 5, 2015 at 3:13 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    To my knowledge, they work with any 2.5" diameter coilover, Icon, Fox, King, SAW, etc. They're meant for adjustable coilovers so lift amount is relative.
  4. Sep 6, 2015 at 12:06 AM
    TacoTaro
    Los Angeles
    04 DC 4x4
    Correct. You can adjust the preload to get the ride height you want.
  5. Sep 6, 2015 at 9:39 AM
    Taco Mark86
    Mark
    NC
    Just curious because I know some of the eibach coils are rated for different lift heights (1.6" & 2.5").
    Anybody running King coils on Fox 2.5s that can provide some insight?
  6. Sep 6, 2015 at 11:38 AM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    This would actually be an upgrade for any of the other 2.5" coilovers, as king runs 14" springs and the rest are 13". More height with less preload = better ride.
  7. Sep 7, 2015 at 2:04 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I have 650lb sprigs on my Kings with very little preload on them and have 3" of lift.
    I wonder how 600lb springs would feel compared to my setup.
  8. Sep 7, 2015 at 2:09 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Probably substantially softer lol. Where did you get 650lb coils?
  9. Sep 7, 2015 at 2:14 PM
    TacoTaro
    Los Angeles
    04 DC 4x4
    I noticed a big difference between 600 and 650.
    This is a great opportunity for you to try it out for very little cash. You may have too much spring if you have 3 inches with little preload.
  10. Sep 7, 2015 at 2:18 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    My thought too. I have 3/4" of preload, and I'm pretty sure I'm just around stock height, if not barely above it.
  11. Sep 7, 2015 at 2:19 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Wouldn't the ride end up being the same since I'd have to put more preload on the springs?
    I got the springs from DSM
  12. Sep 7, 2015 at 2:21 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Well do you like having 3" of lift? If yes, them you're probably fine. Do some decent off roading, then take a look at your shocks. If you're not using all of your travel, Spring is too stiff, or valving is too stiff. Assuming you have the factory king valving, it's probably not a valving issue.
    If you're bottoming out a lot, get a stiffer spring.
  13. Sep 7, 2015 at 2:38 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    I like having 3" of lift, so I guess I'll stick with them if the ride is gonna end up being the same.
    Don't get me wrong, they ride smooth, I was just curious if 600lb would make a big difference.
  14. Sep 8, 2015 at 9:44 PM
    TacoTaro
    Los Angeles
    04 DC 4x4
  15. Sep 9, 2015 at 10:47 AM
    jimbo623
    jimbo623 Jimbo
    Pueblo
    11 TRD Off Road
    Grillcraft Grill, Hella Black Magics, ICON shocks w/ remote reservoir, Total Chaos UCAs, Tom Woods Drive Shaft, TSB springs, LED Dome light, Redline Hood struts, Slotted rotors, WheatherTech Mats, Ultra Gauge, and Illuminated 4x4 switch
  16. Sep 16, 2015 at 11:01 PM
    TacoTaro
    Los Angeles
    04 DC 4x4
