Reverse Camera Anytime
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by brendanwebster911, Apr 30, 2017.
  1. Apr 30, 2017 at 12:54 PM
    brendanwebster911
    brendanwebster911 [OP] Well-Known Member
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Hey there TW! Just as the title says! Reverse Camera Anytime! Very easy to install if you can follow step by step instructions! I personally will be using mine ALL the time, I tow quite frequently and would love a way to check trailer connections while driving. I also love being able to watch my tow strap become taught while pulling a buddy out of a hole. Your specific uses may vary.
    This kit "tricks" the Head unit and backup camera into thinking the vehicle is in reverse at anytime you flip the switch. It can be activated ANYTIME, or even all the time. This kit is especially awesome because it has the ability to activate the reverse camera without triggering the reverse lights. The reverse camera and lights still work as normal while shifting the vehicle to Reverse.
    https://youtu.be/Du322YnjFZA
    Free shipping is included on all kits. These Kits have about a 30 min install and you can mount the switch anywhere you would like. (may require extending wires in certain circumstances) All you need is the ability to follow instructions, cut, strip, and splice some wires and you're all set! This kit includes all required equipment prewired, soldered, and shrink wrapped with the diode in the harness. This is NOT a "plug" and play kit. You WILL need to cut one wire, and splice into a couple more.
    $20 Basic kit Includes
    -Step by step installation guide and wiring diagram
    -1x Illuminated 3/4" round toggle switch. Round switches will mount in any 3/4" hole. 12" pre soldered and shrink-wrapped leads. Leads are long enough to mount switch above radio. If longer leads are needed please specify. Available in RED, AMBER, BLUE, and GREEN. If no color is specified you will receive a random color. Other colors are made to order and my take extra time.
    -1x Inline "Y" harness with pre soldered and shrink-wrapped diode
    -1x Wiring diagram and step by step full color installation instructions.
    $50 OEM STYLE Kit includes:
    The basic kit with a substituted "rear camera" push button OEM illuminated style switch. All switches are black with white lettering. Illumination is available in WHITE, BLUE, RED, and GREEN. Blue illumination is standard. Other colors are made to order and my take extra time. The switch is pre wired, soldered, and shrink-wrapped 5' long lead wires. Long enough to reach the cubbyhole on the left side of the steering wheel. This switch will fit inside the "blank" spots. No trimming required to fit. SPECIFY WHERE YOU ARE MOUNTING THIS SWITCH, CENTER STACK AREA OR CUBBYHOLE AREA ON DRIVERS LEFT. There are two sizes/shapes of the OEM Style Switches.
    Screen Shot 2017-01-10 at 6.21.27 PM.jpg IMG_2612.jpg IMG_1891.jpg IMG_1957.jpg
    $5 NAV IN MOTION OVVERIDE TOGGLE W/LEADS
    -Can be added to any order. This includes 1x 3/4' toggle switch. With 12" pre soldered and shrink-wrapped leads. Leads are long enough to mount switch above radio. If longer leads are needed please specify. Available in RED, AMBER, BLUE, and GREEN. If no color is specified you will receive a random color. Note: Due to the nature of this specific switch, illumination will pulse while the switch is activated due to the signals from the SSW wire. Illumination of the switch is not recommended. Instructions and wiring diagram included.
    *** NAV Mod can be substituted with an OEM Style switch, pictured above. Cost is $25 versus the $5 for the standard round switch.
    Each Kit is tested for function with a multimeter before shipping. A full color detailed installation writeup is included on all kits.
    To Order: Message me, or send a
    PayPal. Ensure to leave shipping address and the the type and color kit wanted.
    ancient11, gulzeb, Dg7leon27 and 3 others like this.
  2. Apr 30, 2017 at 1:40 PM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Take my money!! I hate the fact my passenger can't use the navigation while we're driving.
  3. Apr 30, 2017 at 1:41 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    haha well, you know......Safety First! :thumbsup:
  4. Apr 30, 2017 at 1:41 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Is there a way to add for front camera as well?
  5. Apr 30, 2017 at 1:45 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    No sir, these kits and write ups are specific to activate the rear camera. There are too many different front camera setups out there for me to make specific kits for them.
  6. Apr 30, 2017 at 1:49 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    I'd like this, willing to share instructions on how to install the gps override and back up camera? So that's $25 correct? Also how do you test them before sending?
  7. Apr 30, 2017 at 1:56 PM
    Braves95
    David
    Central PA
    I've done the GPS anytime without needing to ever use the switch again. Once. A few miles it switches and works all while driving and the GPS moves as well. But would like the anytime rear camera.
  8. Apr 30, 2017 at 1:57 PM
    9TRDTCO
  9. Apr 30, 2017 at 5:12 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    I test the switches and diodes with a multimeter before i finish the kit.
    if you shoot me your email, id be happy to send you the PDF for install.
    9TRDTCO[QUOTED] likes this.
  10. May 1, 2017 at 11:40 AM
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    Can I use it as a front camera control?
    Corneeeeelius likes this.
  11. May 1, 2017 at 11:48 AM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Any 2nd Gen love?
    tomwil likes this.
  12. May 1, 2017 at 11:54 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Yes, as long as you have a DPDT front and rear camera toggle setup. It will not work with the video RCA input types.
  13. May 1, 2017 at 11:54 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    No :(
    Sorry
    Sleipnir[QUOTED] likes this.
  14. May 1, 2017 at 12:00 PM
    Sleipnir
    I'm a horse
    Asgard
    This makes me sad :(
  15. May 1, 2017 at 12:03 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    I'm sorry.
    If I had a 2nd gen to mess with and develop a kit for, I would for sure.
    Maybe in the future! But, for now just 3rd gens
  16. May 1, 2017 at 12:09 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Come to Charlotte, I'll let you tinker with mine.
  17. May 1, 2017 at 12:10 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Haha that's only about 3 hours away.
    If you ever make it out to fort bragg, let me know!
    Bannerman[QUOTED] likes this.
  18. May 2, 2017 at 2:43 PM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Hi, Does the "Nav in motion" mod only trick the nav or will all the aps that limit use in motion work (such as Pandora which only lets you scroll through a few stations before you get the warning about stopping the vehicle)?
  19. May 2, 2017 at 2:52 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    It will allow FULL access to everything. Toggling the nav switch will allow 100% access to all features avaliable wheels the vehicle is normally stopped
    WOTaco[QUOTED] likes this.
  20. May 2, 2017 at 2:57 PM
    9TRDTCO
    I need this! Haven't had the chance to look over the instructions Brendan sent to me but I'm sure it'll be a piece of cake
