  1. Feb 23, 2018 at 1:13 PM
    Jon8251
    Jon8251 [OP] Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    5K miles on them on pavement only. $200. Located in southern MD.
  2. Feb 23, 2018 at 1:38 PM
    1bluefin
    1bluefin Well-Known Member
    JOHNSTOWN, N.Y.
    2011 SR5 DBL CAB 6' BOX WHT
    Soft Topper, ICON 3 leaf progressive pack, Running Bilsteins, Cooper AT3 265/75R16
    Hi, will these fit an SR5 2011 4door long bed? Will they add lift over stock SR5 shocks and springs? Please advise your thoughts. Steve
  3. Feb 23, 2018 at 1:43 PM
    Jon8251
    Jon
    Southern MD
    Yes, these will fit 2nd Gens and will give you approximately 1" of lift in the front.
  4. Feb 23, 2018 at 2:04 PM
    1bluefin
    JOHNSTOWN, N.Y.
    Ok thanks. I'm looking for an economical fix because I broke a ebach 620 lb coil spring and my truck will not pass inspection now. I have Bilstein 5100 and Eback coils on now but I have to replace it and was thinking this would be an economical fix as my truck has 90,000 miles on it. I would like to retain some lift as I'm running oversized tires on it as well 265/70/r17.
    Really don't want to buy smaller tires at this point just for a broken spring.
  5. Feb 24, 2018 at 5:39 AM
    meangene21
    meangene21 Well-Known Member
    Gene
    Virginia
    2008 Double Cab SR5 4x4
    How much is shipping to 24556v
  6. Feb 24, 2018 at 5:42 AM
    Jon8251
    Jon
    Southern MD
    I have a tentative buyer right now. If that falls through, you'll be next.
  7. Feb 24, 2018 at 5:51 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    FYI Those tires are oversize but don’t require a lift.
    @1bluefin
  8. Feb 24, 2018 at 6:20 AM
    1bluefin
    JOHNSTOWN, N.Y.
    LJ, great good to know thanks for the info on the tire size.
  9. Feb 25, 2018 at 6:36 AM
    1bluefin
    JOHNSTOWN, N.Y.
    Hi LJ . looking at the picture can you tell me which one is the drivers side ? the one with the paint dots or the one without.??
  10. Feb 25, 2018 at 7:13 AM
    Jon8251
    Jon
    Southern MD
    They both actually have dots on them. I went back through the pics I took during my install and was able to determine the one with the brown and grey/silver dot is the driver side and the red and green goes on the passenger. The part number for the shock itself is the same.
  11. Feb 25, 2018 at 7:21 AM
    1bluefin
    JOHNSTOWN, N.Y.
    Ok Jon thank you for the answer I appreciate it that's a big help.
  12. Feb 25, 2018 at 8:23 AM
    L J
    Illinois
    Good thing that the OP took pics as I did not know the answer. Now I need to confirm mine are correct. Thanks Jon!
