Thread Status:
Not open for further replies.
  1. Nov 18, 2018 at 11:39 PM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    Item: 2nd Gen Tacoma (12-15) Headlights
    Price: SOLD
    Contact: PM
    - Set of retrofits i bought off another member awhile back. Headlights are in good condition. Wiring harness for the LED and Shroud are included. Morimoto products were used. All tabs are intact.
    - Here are the flaws though.
    • Will need to open the driver side to adjust the projector since it is facing down way to much.
    • Also, HID bulbs on that side will need replacement (Not major).
    • Slight UV peel on the clear coat, needs some buffing.
    Overall a good set of headlights to practice on for the newcomers to retrofitting and etc.
  2. Nov 19, 2018 at 7:10 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Bumparoo
  3. Nov 19, 2018 at 7:14 AM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Would you consider shipping to CT?
  4. Nov 19, 2018 at 7:15 AM
    surfandturf
    CT
    2014 TRD DCLB
    Are they toyota or aftermarket housings?
    Bot_Chu[OP] likes this.
  5. Nov 19, 2018 at 7:21 AM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    OEM housings what I understand. Shipping would murder the cost of these headlights quite honestly. So local for now.
  6. Nov 19, 2018 at 1:06 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    The projector will adjust horizontal and vertical using the factory adjusters unless they are broken.
  7. Nov 19, 2018 at 4:58 PM
    raco.the.taco
    raco.the.taco Well-Known Member
    Chad
    Denver, CO
    Locked, Geared & 1/2 Long Traveled
    Pelfreybilt Front Bumper, All-Pro Rear Bumper & Sliders, 35's, Toytect Boss Coilovers, JBA UCA's, DTF SUA Kit w/ E30 Deavers, Wheelers superbumps, Front & Rear Locked, 4.56 Gears
    Could you post a picture of the back? Interested to see how well they are sealed.
  8. Nov 19, 2018 at 5:07 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    They look good.
  9. Nov 19, 2018 at 10:31 PM
    Bot_Chu
    Bot_Chu [OP] Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
Thread Status:
