*SOLD*
Discussion in '3rd Gen Tacomas For Sale (2016-2023)' started by Dajova, Jan 28, 2019.
Thread Status:
Not open for further replies.
  1. Jan 28, 2019 at 8:52 PM
    Dajova
    Dajova [OP] Well-Known Member
    2017 MGM TRDOR
    2017 TRD Off Road DCSB MGM 4x4
    33k Miles. Selling because I miss having a fast, sporty car as my primary vehicle.
    Located in Fort Worth, TX. Willing to meet someone within 300 miles if the price is right.
    All service done at dealership - have receipts for everything including mods. Only mild off road use.
    About 6k worth of mods and improvements:
    Truck bed
    - Truck cover usa bed cover
    - OEM bed mat
    - custom rack that works with bed cover (shovels, axe, etc)
    Armor
    - SDHQ chromoly steel sliders
    - TRD pro front skid
    - pelfrybilt tranny skid
    - RCI lower control arm skids
    Lights
    - LED headlight bulbs (GTR)
    - Baja designs fogs
    - Baja designs ditch lights
    - SDHQ ditch light mounts
    - LED reverse lights
    - tinted reflectors in front and rear
    Other Exterior
    - 4runner TRD pro wheels
    - 31'' KO2 tires with 20k miles on them
    - Custom bedside sticker
    - blacked out badge
    - window tint
    - black bumper caps
    - TRD license plate frames
    Interior
    - Weather tech mats
    - TRD pro shift knob
    - ditch light switch with OEM look
    - Various red accents
    - Blacked out steering wheel emblem
    - Door sill protectors
    If you need more interior pics just let me know. It's in good shape and has a few (removable) red accents.
    Asking 32.5k OBO.
    20190113_163948.jpg 20190113_160657.jpg 20190113_161816.jpg 20190113_161000.jpg 20190113_161051.jpg 20190113_161217.jpg 20190113_160816.jpg 20190113_160800.jpg 20190113_160925.jpg 20190114_180558.jpg
    Northsound1 likes this.
  2. Jan 28, 2019 at 8:53 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Added your location to the title
  3. Jan 29, 2019 at 4:50 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    FYI...Your title also list it as a DCLB which would be a long bed, should be listed as DCSB. GLWS...
    Silverspool likes this.
  4. Jan 29, 2019 at 5:40 AM
    Dajova
    2017 MGM TRDOR
    Damn, good catch - sorry! Fixed it.
    alexplb likes this.
  5. Feb 7, 2019 at 10:20 AM
    Dajova
    2017 MGM TRDOR
    Bump! Price reduced to 33k.
  6. Feb 7, 2019 at 12:47 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Keeping my eye on this
  7. Feb 7, 2019 at 9:39 PM
    Bill12s
    Bill12s Member
    William
    2 zone climate control or traditional controls?
  8. Feb 8, 2019 at 6:25 AM
    Dajova
    2017 MGM TRDOR
    Let me know if you have any questions.
    Normal climate controls.
    Additional interior pics added.
  9. Feb 8, 2019 at 7:03 AM
    Overland&UpMoutains
    Parker
    Deleware
    What grill is that
  10. Feb 8, 2019 at 3:08 PM
    Dajova
    2017 MGM TRDOR
  11. Feb 15, 2019 at 2:14 PM
    Dajova
    2017 MGM TRDOR
    Bump!
  12. Feb 16, 2019 at 9:46 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Clean truck. I see it on craigslist fairly often lately.
  13. Feb 18, 2019 at 12:22 PM
    Dajova
    2017 MGM TRDOR
    Thanks man, I've really enjoyed having it. Yep - I've got this thing posted all over the place!
  14. Feb 21, 2019 at 5:21 AM
    Dajova
    2017 MGM TRDOR
    Bump!
  15. Feb 21, 2019 at 5:45 AM
    Northsound1
    Northsound1 Member
    Ohio
    2018 Off Road MGM DCSB
    Hey Jared, can I ask you is your truck lifted or stock Off Road suspension? Id like to set mine up like yours, looks great. Your 31" tires...what size is that? Like 265 70 17?
  16. Feb 25, 2019 at 6:06 AM
    Dajova
    2017 MGM TRDOR
    Sorry for slow reply. It's stock off road suspension with 265/70/R17 K02s.
  17. Feb 26, 2019 at 6:26 AM
    Dajova
    2017 MGM TRDOR
    Bump!
  18. Feb 27, 2019 at 2:49 PM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    Nice truck! Not to derail but do you mind sharing how tall you are? There's a refreshing amount of leg room behind your seats and I'm curious what to expect. I'm in the process of shopping for a Tacoma and all the photos I see online seem to be with the front seats slammed back.
  19. Feb 27, 2019 at 3:20 PM
    Dajova
    2017 MGM TRDOR
    Lmao. Not the kind of question I was expecting but sure, I don't mind - 5' 6'' so this is probably most rear leg room one could expect. I think the older Tacomas have seats lower to the floor of the truck so that might further contribute to the seats being further back.
  20. Feb 27, 2019 at 4:40 PM
    mtskibum16
    PNW
    Thanks for the info haha. Just seems like most 3rd gen pics I see of the back seats (usually dealer pics of new trucks) have the front seats slammed all the way back.
Thread Status:
