  1. Aug 23, 2019 at 7:45 PM
    KingTaco81
    KingTaco81 [OP] The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    $65 shipped
    Socal
    PP or venmo
    Bought this from another tw member, don't need it anymore. Used this spacer in the drive line to reduce some of the drive line vibes I was getting. It helped a whole lot.
    It bolts in between the driveshaft and rear end. Install takes about 20 min.
    It pushes the driveshaft back in to normal specs after lifting your truck. Works for 3"-6" lift 20180319_172455~2.jpg
    mcharfauros likes this.
  2. Aug 26, 2019 at 8:08 AM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
  3. Aug 27, 2019 at 8:22 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
  4. Sep 4, 2019 at 7:09 AM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
  5. Sep 6, 2019 at 9:07 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Fyi, should only be used o 2wd trucks where the slip yoke is in the transmission.
    timinNC likes this.
  6. Sep 6, 2019 at 12:48 PM
    VerteX10_
    VerteX10_ Well-Known Member
    Los Angeles, CA
    2010 Magnetic Gray Tacoma
    More to come!!
    Excuse the stupid question, but what type of vibrations would this fix? I have a 3” lift & I feel vibrations when I’m reaching 80mph.. I’m not sure what’s causing it.
  7. Sep 6, 2019 at 12:53 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    When the rear is lifted, it pulls the driveshaft further out of the transmission causing vibration and possible trans leaks. The spacer pushes the driveshaft back in to the trans making more contact with the splines and better contact with the seal.
  8. Oct 24, 2019 at 2:51 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
  9. Oct 28, 2019 at 12:52 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
  10. Apr 13, 2020 at 11:45 PM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
  11. Apr 14, 2020 at 9:56 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    ive got about 6" of lift and cant get rid of my vibes despite angles being correct. is this my solution?
  12. Apr 14, 2020 at 10:57 AM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    The guy I bought from had it on 6" lift. Said it worked on his rig. I can look for the member name if you'd like and send him a pm.
  13. Apr 14, 2020 at 11:30 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    that would be great!
  14. Apr 14, 2020 at 12:31 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Yes. I installed one on a 6" lifted taco and his vibrations disappeared. It allows the ds splines to make full contact.
    KingTaco81[OP] likes this.
  15. Apr 14, 2020 at 12:51 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    do you have measurements of whay your driveline distance was? im seriously considering this.
  16. Apr 14, 2020 at 12:59 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    I don't have measurements but I can tell you that we had to shift back the carrier bearing as far back as it would go and the rubber inside the cb was stretched back at least another 1/2"-3/4". After the spacer install, I was able to shift the cb all the way forward to it's usual position.
    We swapped cb about 4 times in two years due to the ds alignment.
    Before that, we tried cb shims, axle shims to no avail. The spacer cured the terrible take off shudder that was happening. All smooth now.
    Setup was alcan 6" leaf springs, pro comp 6" DB lift, Bilstein 5125 rear, pro comp mx 2.75" coilover front.
    Newlife and KingTaco81[OP] like this.
  17. Apr 15, 2020 at 10:41 AM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    Wednesday bump
  18. Apr 15, 2020 at 10:47 AM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
